daccio Posted August 15, 2016 Posted August 15, 2016 Orange Pi One is not booting with Debian Jessie Server image http://www.armbian.com/orange-pi-one/ http://mirror.igorpecovnik.com/Armbian_5.14_Orangepione_Debian_jessie_3.4.112.7z But there is no problem booting with the Debian Jessie image made by Boris Lovosevic https://drive.google.com/open?id=0B1hyW7T0dqn6c3BNOWRwRnZZUTQ One month ago I got to boot another Orange Pi One with the image available at armbian.com/orange-pi-one/ but not any more This is the way I dd to SD card sudo dd if=Armbian_5.14_Orangepione_Debian_jessie_3.4.112.raw of=/dev/rdisk2 bs=1m I would really appreciate your help I am the maker of this demo and Instructable Swift + Orange Pi + LEDs Semaphore http://www.instructables.com/id/Swift-Orange-Pi-LEDs-Semaphore/
tkaiser Posted August 15, 2016 Posted August 15, 2016 But there is no problem booting with the Debian Jessie image made by Boris Lovosevic Then at least it's not a problem with insufficient power supply Armbian uses mainline u-boot while loboris relied on Allwinner's old u-boot version from 2011.09 -- in case you have any USB peripherals connected please try rebooting without connecting them (sometimes u-boot misinterprets signals sent from USB devices as keystrokes and then stops autoboot and waits for commands... indefinitely -- we disabled USB in u-boot for H3 devices but IIRC this fix is not included in our old 5.14 OS images). The other known show-stopper are bad SD cards -- Armbian does things differently than loboris since we resize the rootfs on 1st boot and in case you use a counterfeit or faulty card things might get stuck here. Anyway: Serial console output would be helpful and in case you use a new or different SD card, simply test it prior to useage: http://docs.armbian.com/User-Guide_Getting-Started/#how-to-prepare-a-sd-card In case you're not using homebrew, MacPorts or the like on your OS X machine you find here statically linked f3 binaries: http://kaiser-edv.de/tmp/JcyTCE/ -- use disk utility to format the SD card with OS X and then change to the mountpoint and let f3write/f3read do their job. 1
manuti Posted August 16, 2016 Posted August 16, 2016 I agree with tkaiser, poor microSD cards are the main reason for problems. And sometimes things related with this : bad SD card writers used to prepare the OS, hardware problems in the microSD slot in the Orange Pi,...
beic Posted September 14, 2016 Posted September 14, 2016 This is the way I dd to SD card sudo dd if=Armbian_5.14_Orangepione_Debian_jessie_3.4.112.raw of=/dev/rdisk2 bs=1m I have the same issue, but how can I do it on Windows platform, is there some settings in Rufus?!
