Learnincurve Posted May 25, 2021 Posted May 25, 2021 Hi, Just want to check what the recommended approach is with today's dist-upgrade. I noticed that armbian-bsp-cli-pine64 was held back, so tried a manual install to see what the problem was. Seems like apt wants to remove linux-focal-root-current-pine64 to upgrade armbian-bsp-cli-pine64. Is this a temporary dependency issue? Obviously not performing the upgrade unless informed of the correct approach. BR.
Igor Posted May 25, 2021 Posted May 25, 2021 3 hours ago, Learnincurve said: Seems like apt wants to remove linux-focal-root-current-pine64 to upgrade armbian-bsp-cli-pine64. That is expected, yes. We replaced linux-*-root* package with a new one. The content is (almost) identical. 3 hours ago, Learnincurve said: recommended approach is with today's dist-upgrade. Use the usual way: apt update & apt upgrade.
