jdum Posted May 25, 2021 Posted May 25, 2021 (edited) Hi I would like to install the following module: mt7601u Unfortunatly i need kernel-hearders at least for this , i think My hardware is an Orange Pi Zero HC2+ My system realease is as follow PRETTY_NAME="Armbian 21.05.2 Buster" NAME="Debian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" Any idea ? Edited May 25, 2021 by jdum Small mistake
NicoD Posted May 25, 2021 Posted May 25, 2021 1 minute ago, jdum said: Unfortunatly i need kernel-hearders at least for this , i think Open armbian-config sudo armbian-config Go to software -> Headers_Install
Igor Posted May 25, 2021 Posted May 25, 2021 Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs). With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported. Your report is invalid for one or more of the following reasons (non-exhaustive list): it is for an unsupported board or image (CSC/EOS/WIP/edge) it is for software that is not supported (such as userspace modules installed on top of the core operating system) it has been logged in the wrong forum (for example requests for help that are not actual bug reports) it lacks requested data (armbianmonitor output) it could have been easily solved by a quick search and/or reading documentation Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
