Guest Posted May 31, 2021 Posted May 31, 2021 I usually attach a GPS module to OrangePi One to act as a GPS ntp server . GPS serial data can use any UART port. but PPS pulse can use PA7 or UART_RTS, I most connect to PA7, works very well. Recently I bought a GPS modules for Rasberry Pi, it connect the PPS to pin 12, in One it's PD14 But when I set param_pps_pin=PD14 in armbianEnv.txt , it can't work at all . see /sys/kernel/debug/gpio , there is no GPIO 110 (PD14) at all. So don't use PD14 as a PPS pulse input.
Werner Posted May 31, 2021 Posted May 31, 2021 Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs). With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported. Your report is invalid for one or more of the following reasons (non-exhaustive list): it is for an unsupported board or image (CSC/EOS/WIP/edge) it is for software that is not supported (such as userspace modules installed on top of the core operating system) it has been logged in the wrong forum (for example requests for help that are not actual bug reports) it lacks requested data (armbianmonitor output) it could have been easily solved by a quick search and/or reading documentation Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
