Solution andreygoncalves Posted June 8, 2021 Solution Posted June 8, 2021 Hello guys. Could you help me resolv a problem with orange pi (armbian)? The problem is the following: I created a small script in Python that read a I/O of orange Pi, that is read the state of a button(switch). If I execute it on terminal It works fine... But my problem is when I put in inicialization of SO(/lib/systemd/system/rc-local.service ), the linux created a process correctly but when a press the button not happen anything. root@orangepizero:~# ps -aux|grep press root 1306 83.7 1.9 11268 4852 ? Rs 18:54 0:38 /usr/bin/python /usr/local/sbin/press_button.py SO of Orange Pi Zero: Linux orangepizero 5.10.21-sunxi #21.02.3 SMP Mon Mar 8 00:28:04 UTC 2021 armv7l GNU/Linux Obs: I tried put the script in rc.local, used crontab too, put in init.d.... but always the same problem, the linux created the process but dont happen anything when I pressed the button... But if I execute on bash the script It read the button correctly. Script python: import os import sys from pyA20.gpio import gpio from pyA20.gpio import port from time import sleep #initialize the linphonecsh os.system("linphonecsh init") os.system("linphonecsh register --username 8000 --host 10.100.14.210 --password 8000") os.system("linphonecsh soundcard playback 0") os.system("linphonecsh soundcard capture 0") os.system("linphonecsh soundcard ring 0") #initialize the gpio module / initialise le GPIO gpio.init() button = port.PA12 #setup the port gpio.setcfg(button, gpio.INPUT) while True: if gpio.input(button)==0: sleep(1) print("button pressed") os.system("./test_autodial.sh") I'm already suspecting that it's a problem with this OS version. Hope someone can help me. Thank you very much.
Werner Posted June 9, 2021 Posted June 9, 2021 Moved to Common issues / peer to peer technical support
