MowTee Posted June 15, 2021 Posted June 15, 2021 (edited) Armbianmonitor: http://ix.io/3q2F Hi all, My Hard Drive in my HC2 is not found or not readable. Before I was on Armbian Buster with Kernel 4.14 and everything was working fine. I switched and am now running Armbian Focal 21.05.2 with Kernel 5.4.116 . HDD is btrfs formatted. /proc/filesystems lists btrfs so this is not the problem. /dev/sda exists, but sda will not be listed when I lsblk. Dmesg shows a Read Capacity(16) failed. Not posting the whole dmesg log b/c armbianmonitor is attached. Grateful for any help or hints =) Edited June 15, 2021 by MowTee
Solution Igor Posted June 15, 2021 Solution Posted June 15, 2021 2 minutes ago, MowTee said: HDD is btrfs formatted I highly suspect this is something to do with filesystem driver incompatibility between kernel 4.14.y and 5.4.y. We don't support BTRFS even commercially, but you can find commercial support elsewhere https://en.wikipedia.org/wiki/Btrfs#Commercial_support Perhaps there is a way to upgrade somehow ... 7 minutes ago, MowTee said: Grateful for any help or hints =) Plan B will only cost you your time. Starting from 4.14.y, coping elsewhere, starting with 5.4.y ... or staying on 4.14.y.
MowTee Posted June 17, 2021 Author Posted June 17, 2021 Could not reply right away b/c of new member restrictions. Can confirm Kernel 4.14.y works, also for Focal. Thx for quick and intuitively correct answer
