MartinKeppler Posted August 18, 2016 Posted August 18, 2016 Good Morning, I'm using the 5" LCD of LeMaker designed for Banana Pi. For some reason I changed from legacy Kernel to vanilla kernel. But now in the vanilla kernel touch screen driver isn't available anymore. In legacy kernel it the ft5x_ts module. Is there an other way to make my Display working with touch again? Displays: http://wiki.lemaker.org/BananaPro/Pi:LCD_Module Martin
Igor Posted August 18, 2016 Posted August 18, 2016 It's possible but I can only give you a hint since I never try this to make it work. You need to do two things, enable LCD in u-boot and add this to Banana device tree. At least you know what you need to look for. 1
MartinKeppler Posted August 22, 2016 Author Posted August 22, 2016 Ok, I'm searching. Is there a difference between enabling LCD in u-boot and in script.bin? I was using the modifications from banana_pi_5lcd.fex to generate a new script.bin. But the LCD doesn't turn on. I'm still on HDMI.
Igor Posted August 22, 2016 Posted August 22, 2016 Yes, those are different areas. Forget about .fex when you are using Vanilla kernel. FEX settings are used in old 3.4 kernel and enabling in .fex and loading touch driver is usually enough. 1
MartinKeppler Posted August 24, 2016 Author Posted August 24, 2016 Thanks Igor. I'm watching. I think, I got much to read and learn now.
MartinKeppler Posted August 25, 2016 Author Posted August 25, 2016 Final question to this topic. Enabling LCD in u-boot, means to change the dts or to change the config and rebuild the u-boot?
Igor Posted August 25, 2016 Posted August 25, 2016 Change a config and rebuilt uboot is required. Wrote on mobile phone 1
MartinKeppler Posted September 22, 2016 Author Posted September 22, 2016 Hi, after getting the LCD - Display working, I now try to get touch working. In sun7i-a20-bananapi.dts, I added: &i2c3 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c3_pins_a>; edt: edt-ft5x06@38 { compatible = "edt,edt-ft5x06"; reg = <0x38>; interrupt-parent = <&pio>; interrupts = <7 9 IRQ_TYPE_EDGE_FALLING>; wake-gpios = <7 7 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; pinctrl-0 = <&edt_ft5x06_pins>; touchscreen-size-x = <800>; touchscreen-size-y = <480>; touchscreen-inverted-x; touchscreen-swapped-x-y; }; }; directly after &i2c2 { pinctrl-names = "default"; pinctrl-0 = <&i2c2_pins_a>; status = "okay"; }; also added: edt_ft5x06_pins: edt_ft5x06_pins@0 { allwinner,pins = "PH7", "PH9"; allwinner,function = "gpio_out"; allwinner,drive = <SUN4I_PINCTRL_40_MA>; allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; }; after led_pins_bananapi: led_pins@0 { allwinner,pins = "PH24"; allwinner,function = "gpio_out"; allwinner,drive = <SUN4I_PINCTRL_10_MA>; allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; }; But unfortunately, touch doesn't work. Any ideas, what went wrong? Maybe not the correct registers or something... Got this from a patch: https://github.com/igorpecovnik/lib/blob/master/patch/kernel/sunxi-next/bananapipro_lemaker_lcd.patch.disabled But patch is for Bananapi pro Hope to get some help.
MartinKeppler Posted September 23, 2016 Author Posted September 23, 2016 I've been testing a bit arround and find out, that my entries of DTS File aren't in the platform devicetree. I think it must be there in /sys/devices/platform/soc@01c00000 but there are only 1c2ac00.i2c and 1c2b400.i2c Any Ideas? I think there is a problem with the driver or something, so it's couldn't be loaded. Could it be, that is an option to be activated in Kernel config? Yours, Martin
MartinKeppler Posted September 28, 2016 Author Posted September 28, 2016 Little update: Found out, that driver modul edt-ft5x06 isn't compiled to my build of kernel. One reason why it doesn't work. $ modprope edt-ft5x06 Returns: modprobe: FATAL: Module edt-ft5x06 not found. How can I activate this driver in menuconfig of my kernel? Yours, Martin
MartinKeppler Posted September 29, 2016 Author Posted September 29, 2016 After searching arround, I saw, that edt-ft5x06 wasn't compiled. First I added CONFIG_TOUCHSCREEN_EDT_FT5X06=m to Bananapi_defconfig. But that doesn't help. In Kconfig at /drivers/touchscreen/ I saw, that there must be a menu point in menuconfig. And there it is: menuconfig > Device Drivers > Input Device Support > Touchscreens > EDT FocalTech FT5x06 I2C Touchscreen support Set it to [*] (means compile as kernel modul) Now, at /sys/devices/platform/soc@01c00000 there is a node for the I²C3 1c2b800.i2c Thats a beginning. But touch still doesn't work.
MartinKeppler Posted September 30, 2016 Author Posted September 30, 2016 Got three messages in boot up now: OF: /soc@01c00000/i2c@01c2b800/edt-ft5x06@38: could not get #gpio-cells for /clocks/cpu@01c20054 edt_ft5x06 2-0038: Failed to request GPIO wake pin, error -22 edt_ft5x06: probe of 2-0038 failed with error -22 Any ideas?
MartinKeppler Posted September 30, 2016 Author Posted September 30, 2016 After deleting wake-gpios = <7 7 GPIO_ACTIVE_LOW>; the touch works. But why? I saw in the old fex files, PH7 was also declared as wake up pin. Can somebody please help me to explain this? Yours, Martin
MartinKeppler Posted October 3, 2016 Author Posted October 3, 2016 You had a good idea. PH7 = 7 * 32 + 7 = gpio231. Correct? With echo 231 > /sys/class/gpio/export I get the gpio231 and can use it. So, if my calc wasn't wrong, PH7 isn't used by anything. Is it possible, that 7 7 isn't PH7? wake-gpios = <7 7 GPIO_ACTIVE_LOW>; Maybe there must be another declaration to make it right.
