KERNEL_CONFIGURE ignore my .config
kentAVR
I want configure kernel using ArmbianMini2.config
I build armbian with KERNEL_CONFIGURE=yes
When menuconfig ask me about settings there are nothing about CONFIG_BMP280. But in my ArmbianMini2.config i set
CONFIG_BMP280=n
In Linux menuconfig after loading ArmbianMini2.config and save armbian rename ArmbianMini2.config to ArmbianMini2.config.old.
I look at ArmbianMini2.config.old
CONFIG_BMP280=n
I look at ArmbianMini2.config or build/output/config/linux-rockchip64-current.config
CONFIG_BMP280=m
How it can be? There are also a lot of options where =n transform to =m...
ArmbianMini2.config ArmbianMini2.config.old linux-rockchip64-current.config
Link to comment
Share on other sites
On 7/3/2021 at 9:11 PM, Werner said:
Official docs are here:https://docs.armbian.com/
Did you try to save your config after altering with default name? .config to say?
menuconfig is strange magic!
Look!
1) I set my settings of kernel.
2) I save my settings of kernel to file /home/a/Documents/myArmbians/8armbian/linux-rockchip64-current.config
3) I load settings from /home/a/Documents/myArmbians/8armbian/linux-rockchip64-current.config
4) I verify settings and its ok
5) I do Exit, armbian save my settings (and block file) and write me
[ o.k. ] Exporting new kernel config [ /home/a/Documents/myArmbians/8armbian/build/output/config/linux-rockchip64-current.config ]
6) I am going to file from 5) and verify and... My settings is reseted! WTF?
So right magic way is:
3) Exit and STOP (Ctrl+Z) armbian build system.
4) put file from step 2) to /home/a/Documents/myArmbians/8armbian/build/userpatches/linux-rockchip64-current.config
5) wating message from armbian
6) do not stop build! Just go to this file and verify. Usually it contains my settings.
P.S. I use Orange Pi 4B
Link to comment
