it is strange but after reboot xrdp doesn't start:
root@rockpi-4c:~# systemctl status xrdp
● xrdp.service - xrdp daemon
   Loaded: loaded (/lib/systemd/system/xrdp.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Fri 2021-07-09 09:20:10 UTC; 9s ago
     Docs: man:xrdp(8)
           man:xrdp.ini(5)
  Process: 2484 ExecStartPre=/bin/sh /usr/share/xrdp/socksetup (code=exited, status=0/SUCCESS)
  Process: 2492 ExecStart=/usr/sbin/xrdp $XRDP_OPTIONS (code=exited, status=1/FAILURE)
Jul 09 09:20:10 rockpi-4c systemd[1]: Starting xrdp daemon...
Jul 09 09:20:10 rockpi-4c systemd[1]: xrdp.service: Control process exited, code=exited, status=1/FAILURE
Jul 09 09:20:10 rockpi-4c systemd[1]: xrdp.service: Failed with result 'exit-code'.
Jul 09 09:20:10 rockpi-4c systemd[1]: Failed to start xrdp daemon.
I re-enabled it via armbian-config but it didn't help.
it is fresh installed OS on eMMC 16Gb without any changes except instructions from 1st message in https://forum.armbian.com/topic/16516-rk3399-legacy-multimedia-framework/
