skinkie Posted July 12, 2021 Posted July 12, 2021 (edited) Armbianmonitor: http://ix.io/3sLb Using the WiFi functionality eventually the system get disconnected, and scanning won't work anymore. Spoiler [270488.523815] ------------[ cut here ]------------ [270488.523829] WARNING: CPU: 1 PID: 14323 at drivers/net/wireless/xradio/scan.c:511 xradio_scan_work+0x3b5/0x40c [xradio_wlan] [270488.523971] Modules linked in: aes_arm_bs crypto_simd ccm xradio_wlan wireguard mac80211 curve25519_neon libchacha20poly1305 cfg80211 chacha_neon poly1305_arm libblake2s ftdi_sio sun4i_gpadc_iio industrialio rfkill usbserial blake2s_arm libcurve25519_generic sun8i_thermal ip6_udp_tunnel libarc4 udp_tunnel uio_pdrv_genirq uio cpufreq_dt zram sch_fq_codel sunrpc ip_tables x_tables autofs4 pwrseq_simple sunxi phy_generic [270488.524339] CPU: 1 PID: 14323 Comm: kworker/u8:0 Tainted: G W 5.12.13-sunxi #trunk.77 [270488.524368] Hardware name: Allwinner sun8i Family [270488.524391] Workqueue: xradio_wq xradio_scan_work [xradio_wlan] [270488.524498] [<c010cb55>] (unwind_backtrace) from [<c010957d>] (show_stack+0x11/0x14) [270488.524555] [<c010957d>] (show_stack) from [<c098bdf3>] (dump_stack+0x77/0x84) [270488.524599] [<c098bdf3>] (dump_stack) from [<c011aec1>] (__warn+0xad/0xc0) [270488.524642] [<c011aec1>] (__warn) from [<c0985a7f>] (warn_slowpath_fmt+0x43/0x7c) [270488.524691] [<c0985a7f>] (warn_slowpath_fmt) from [<bfa238b9>] (xradio_scan_work+0x3b5/0x40c [xradio_wlan]) [270488.524803] [<bfa238b9>] (xradio_scan_work [xradio_wlan]) from [<c012f00f>] (process_one_work+0x18b/0x3f8) [270488.524929] [<c012f00f>] (process_one_work) from [<c012f37f>] (worker_thread+0x103/0x400) [270488.524985] [<c012f37f>] (worker_thread) from [<c01349d9>] (kthread+0x109/0x10c) [270488.525047] [<c01349d9>] (kthread) from [<c0100159>] (ret_from_fork+0x11/0x38) [270488.525087] Exception stack(0xcdb77fb0 to 0xcdb77ff8) [270488.525113] 7fa0: 00000000 00000000 00000000 00000000 [270488.525140] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [270488.525163] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000 [270488.525264] ---[ end trace 86df4a2963dc43b7 ]--- [270488.525288] xradio SCAN-ERR: scan failed, status=-22. [270488.530565] xradio SCAN-ERR: Scan failed (-22). [270493.540816] xradio WSM-ERR: wsm_generic_confirm failed for request 0x0007. [270493.547956] xradio SCAN-WRN: xradio_scan_start,wsm_scan failed! [270493.547980] ------------[ cut here ]------------ Edited July 12, 2021 by TRS-80 put long output inside spoiler
TRS-80 Posted July 12, 2021 Posted July 12, 2021 This is well known issue, in fact it is stated right on download page for the device: https://www.armbian.com/orange-pi-zero/ Quote Onboard wireless module (XR819) has poor software support so wireless connection issues are expected
jernej Posted July 23, 2021 Posted July 23, 2021 Here is early work for proper XR819 mainline support. Tests reports are welcome, to see if it is actually any better than vendor driver. I got reasonable speed using it and only problem I can see is that suspend doesn't work. Of course, developer tests rarely last more than a few minutes, so long term stability isn't known. Note, I extracted pretty recent FW binaries from H616 Android box, which should be better than old ones, in theory. 1
