I was running Armbian on my cubietruck, I believe Bionic Ubuntu.
I wanted to upgrade to latest kernel, so I did a
- apt-get update
- apt-get upgrade
- ambian-config
and selected the lastest kernel
And that was it. When rebooting, I end up with a try to contact a tftp server.
The cubietruck has an SDCard and an SSD.
Is there an easy fix or do I need to reinstall it completely, please?
If I need to reinstall, do I have to backup all data, or is existing data preserved? (Traccar installation)
Regards, Tomte
Cubietruck is A20 SoC? If so IIRC there was some issue with boot loop. Not sure if related. Without full serial log there is pretty much nothing we can do about.
yes, it is a A20.
thanks for your answer, here you go:
=> boot
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3708 bytes read in 21 ms (171.9 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
202 bytes read in 17 ms (10.7 KiB/s)
** File not found /boot/uInitrd **
7967848 bytes read in 692 ms (11 MiB/s)
43983 bytes read in 41 ms (1 MiB/s)
5532 bytes read in 123 ms (43 KiB/s)
Applying kernel provided DT fixup script (sun7i-a20-fixup.scr)
## Executing script at 44000000
Wrong Ramdisk Image Format
Ramdisk image is corrupt or invalid
SCRIPT FAILED: continuing...
Card did not respond to voltage select!
scanning bus for devices...
  Device 0: (0:0) Vendor: ATA Prod.: SanDisk SDSSDP12 Rev: 2.0.
            Type: Hard Disk
            Capacity: 122104.3 MB = 119.2 GB (250069680 x 512)
Found 1 device(s).
            Type: Hard Disk
... is now current device
Scanning scsi 0:1...
Device 0: device type unknown
** Bad device usb 0 **
Speed: 1000, full duplex
BOOTP broadcast 1
DHCP client bound to address 192.168.180.97 (15 ms)
Using ethernet@01c50000 device
TFTP from server 192.168.180.1; our IP address is 192.168.180.97
Filename 'boot.scr.uimg'.
Load address: 0x43100000
Loading: *
Edited by Tomte
missing Info
So I reflashed the SDCard with a current buster, but I can not boot.
It is ending up in a boot loop.  Please, what can I do?
U-Boot SPL 2021.04-armbian (May 06 2021 - 17:01:36 +0000)
DRAM: 2048 MiB
CPU: 912000000Hz, AXI/AHB/APB: 3/2/2
Trying to boot from MMC1
U-Boot 2021.04-armbian (May 06 2021 - 17:01:36 +0000) Allwinner Technology
CPU:   Allwinner A20 (SUN7I)
Model: Cubietech Cubietruck
I2C:   ready
DRAM:  2 GiB
MMC:   mmc@1c0f000: 0, mmc@1c12000: 1
Loading Environment from FAT... Card did not respond to voltage select! : -110
HDMI connected: Setting up a 1600x1200 dvi console (overscan 0x0)
In:    serial
Out:   vga
Err:   vga
Allwinner mUSB OTG (Peripheral)
Net:   eth0: ethernet@1c50000, eth1: usb_ether
230454 bytes read in 22 ms (10 MiB/s)
starting USB...
Bus usb@1c14000: USB EHCI 1.00
Bus usb@1c14400: USB OHCI 1.0
Bus usb@1c1c000: USB EHCI 1.00
Bus usb@1c1c400: USB OHCI 1.0
scanning bus usb@1c14000 for devices... 1 USB Device(s) found
scanning bus usb@1c14400 for devices... 2 USB Device(s) found
scanning bus usb@1c1c000 for devices... 1 USB Device(s) found
scanning bus usb@1c1c400 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
Scanning mmc 0:1...
3967 bytes read in 3 ms (1.3 MiB/s)
154 bytes read in 3 ms (49.8 KiB/s)
9932361 bytes read in 848 ms (11.2 MiB/s)
7973464 bytes read in 681 ms (11.2 MiB/s)
43983 bytes read in 8 ms (5.2 MiB/s)
5532 bytes read in 9 ms (599.6 KiB/s)
## Executing script at 45000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    9932297 Bytes = 9.5 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
data abort
pc : [<bef89cec>]          lr : [<00000011>]
reloc pc : [<4a013cec>]    lr : [<8b08a011>]
sp : baf4aa18  ip : 00000000     fp : befdd678
r10: 00000020  r9 : baf55ec0     r8 : befea28c
r7 : 6c616972  r6 : 00000010     r5 : 2756f9ea  r4 : baf59070
r3 : baf59078  r2 : baf59068     r1 : baf9f920  r0 : 00000019
Flags: nzCv  IRQs off  FIQs off  Mode SVC_32 (T)
Code: d005 f027 0501 441d (686d) 07ed
Resetting CPU ...
resetting ...
DRAM: 2048 MiB
Boot loop is a known issue. Either wait for next release or build an image yourself from master which has a workaround included.
Wow, that was quick.
Ok, how long would I have to wait? Can I use an old release? which one?
I don't have a running build environment.
Regards, Tomte
I went back to:
Armbian_21.02.3_Cubietruck_buster_current_5.10.21.img.xz
That one is booting. Did "Freeze"
Thanks!
