dru Posted July 19, 2021 Posted July 19, 2021 I own an orange pi PC PLUS for about a year and when I got it, I tested it and it worked fine when it booted up from the internal MMC, then I tried to make a server and I think I messed up something with the LAMP I was trying to make so I stashed the PI to play with it later. Now when I turn on the PI, it only loops and never loads the OS, so I downloaded Focal and buster from this link and burned them to an SD and it also loops in this screen, https://imgur.com/WzikUoo what could be wrong? my idea is to reinstall the OS to the internal MMC so I can then install home assistant. thanks in advanced.
Igor Posted July 19, 2021 Posted July 19, 2021 12 minutes ago, dru said: what could be wrong? Regression in u-boot. Will be fixed in sources when this https://github.com/armbian/build/pull/3036 is merged. Images and updates are going to be updated soon. If you need faster.
Solution Igor Posted July 20, 2021 Solution Posted July 20, 2021 Another option is to boot images from archive.
