Fun? :-) Because it is so sophisticated? Built-in RAID/LVM? Snapshots?
On all my Linux computers where there is space for more than one disk I use LVM on top of software RAID. Now I wanted to give ZFS a try as it seams to be really ready.
And also because I spent several years of my life as admin of Solaris systems with zones on ZFS and it was fun.
For having a rootfs, a bit more work has to be done.
Fun? :-)
We pushed it very far but here fun stops - its impossible to waste months working only on this and without receiving anything in return. Bills has to be paid ... If you have strength, capacity and will to pick it up and push forward:
https://github.com/armbian/build/pull/2414
https://github.com/armbian/build/pull/2410
This is needed if you want to have zfs rootfs.
If after reading conversations you pointed me to, I don’t understand what the problem is, means I don’t have enough expertise in this area to be able to really help.
I don’ t want to waste your precious time, but one thing bugs me:
root@odroidhc4:/boot# lsinitramfs initrd.img-5.10.57-meson64|grep -i zfs
conf/conf.d/zfs
etc/default/zfs
etc/zfs
etc/zfs/zfs-functions
etc/zfs/zpool.cache
scripts/local-top/zfs
scripts/zfs
usr/bin/zfsunlock
usr/lib/aarch64-linux-gnu/libzfs.so.4
usr/lib/aarch64-linux-gnu/libzfs.so.4.0.0
usr/lib/aarch64-linux-gnu/libzfs_core.so.3
usr/lib/aarch64-linux-gnu/libzfs_core.so.3.0.0
usr/lib/modules/5.10.57-meson64/updates/dkms/zfs.ko
usr/sbin/mount.zfs
usr/sbin/zfs
So it looks like the necessary stuff is there and AFAIK u-boot understand ZFS (will verify it).
What am I missing?
Be gracious with me, just want to understand.
AFAIK ZFS for linux will never be ready unless Oracle resolves licensing issues. BTRFS has these features (except some RAID modes perhaps) and is stable.
I'm working on it, but I make no promises.
I've written a script that generates a btrfs-, zfs-, or xfs-based Armbian image from a default (ext4-based) Armbian image. It works on ODroid N2+ and NanoPi Neo3. It probably works on others, but I haven't tried them yet.
At present, the generated image uses a boot partition of ext4 and a root partition of ext4/btrfs/xfs/zfs. So, it's not purely ___fs; it does use boot partition of good old ext4.
The zfs image doesn't work yet. It will.
Are you looking to run your OS on a 100% zfs filesystem, or are you willing to use an ext4 boot partition and a zfs root partition?
Sorry the poor answer time, I am in a quite complicated move process. I haven't had much time to "work" on it.
Boot from any FS would be OK for me, just have ZFS for the OS/user would do it.
Would you mind to share more details on what you achived with us?
I'm attaching a bash script that generates a ZFS-based Armbian OS image. It works (for me). Try it out and let me know how you get on. I'm in the process of porting it to Python, but the existing bash script is... not terrible. For some reason, I've failed to persuade this website to notify me when someone replies to this thread.
fructify.20211011.sh.gz
