ljones0 Posted August 15, 2021 Share Posted August 15, 2021 Hello all! And no by an old arm box I don't mean a box full of proshetic limbs! :-) . I'm referring to this device: http://rikomagic.co.uk/linux_mini_pcs.html https://www.cnx-software.com/2014/09/25/rikomagic-announces-mk902ii-le-ubuntu-mini-pc-powered-by-rockchip-rk3288-soc/ The device was badged as a "RKM Mk902II" and claims to have a rk3288. Dug it out today (it has sat unused and untouched for quite a while). Found that its plsatic box which has that strange gunk that is applied to to the box to make it look "shiny" has started to break down so it has become sticky. Anyway since I am clearing things out I thought I'd have one last go at booting a different OS on this device. I have never head much luck ever since I bought one of these devices booting it off a microsd card. Something called linuxium could do this and I have an old 4GB microsd which will boot .... an ancient version of ubuntu. But this was all a long time ago. I did see here that there is a version of armbian for the rk3288. But it did not boot correctly (no display) but if I look at that armbian image I see there are several .dtb files in /boot/dtb . Snag is - is how can you find out which one your system uses? Is there some kind of special tool? Is it the case that not all rk3288s are exactly the same? (BTW this device is not a firefly device, nor a R69 it is ..... unknown!). Any help much appreciated! ljones 0 Quote Link to comment Share on other sites More sharing options...
jock Posted August 15, 2021 Share Posted August 15, 2021 You can try the instructions for another board (xt-q8l-v10) I worked on: https://forum.armbian.com/topic/7141-csc-armbian-for-rk3288-tv-box-boards-q8/ If it works for you, probably the basic things should work ok (usb, hdmi, sdcard, emmc, ...) but other peripherals like wifi, bluetooth, etc... may not work out of the box. Maybe it can be a starting point for further studies. AFAIR the rikomagic was somehow famous some years ago, and maybe there is a device tree already available in the linux kernel, but I'm not sure. 0 Quote Link to comment Share on other sites More sharing options...
ljones0 Posted September 4, 2021 Author Share Posted September 4, 2021 I did give it a go, but it still refused to boot alas x.x Probably best nowadays this thing goes to the bin really especially as it is a few years old. ljones 0 Quote Link to comment Share on other sites More sharing options...
hexdump Posted September 4, 2021 Share Posted September 4, 2021 @ljones0 - before you dump it, then maybe give this image a try: https://github.com/hexdump0815/imagebuilder/tree/main/systems/orbsmart_s92_beelink_r89 if it worked with the old linuxium image, there is a good chance that it might work good luck and best wishes - hexdump 0 Quote Link to comment Share on other sites More sharing options...
