Odroid HC2 - Armbian - failure retrieving kernel
Go to solution Solved by VictorC,
few days ago I did apt upgrade of my armbian system on Odroid HC2 and there was a reboot req cause of new kernel, so I did reboot it.
It wont boot with this error (sorry for missing letters, my LCD is not able to reposition the screen output, attached usb kbd is not working, dont know why, so I just took a pict by my phone):
h to partitions #0, OK
is current device ing mmc 0:1...
/boot/extlinux/extlinux.conf
eving file: /boot/extlinux/extlinux.conf ytes read in 2 ms (149.4 KiB/s)
Armbian
eving file: /boot/uInitrd 776 bytes read in 782 ms (20.2 MiB/s)
eving file: /boot/Image d to load '/boot/Image'
ing Armbian for failure retrieving kernel
T FAILED: continuing... U-Boot script /boot/boot.scr
bytes read in 3 ms (2.3 MiB/s) ecuting script at 08000000
776 bytes read in 760 ms (20.7 MiB/s) d to load '/boot/Image'
bytes read in 8 ms (8.8 MiB/s)
d to load '/boot/dtb/am logic/overlay/-fixup.scr' inux ARM64 Image magic!
'T FAILED: continuing... ing disk sdeffe05000.blk...
did not respond to voltage select! : -110 ing disk mmc@ffe07000.blk...
mmc@ffe07000.blk not ready
2 disks
I system partition Irder not defined
oot manager: Cannot load any image
did not respond to voltage select!:
evice 2 not found
c device at slot 2
ing USB...
sbeff500000: Register 3000140 NbrPorts 3 ing the controller
HCI 1.10
ing bus usbeff500000 for devices... 1 USB Device(s) fou scanning usb for storage devices... 0 Storage Device C
e 0: unknown device meteff3f0000 Waiting for PHY auto negotiation to comple
not initialize PHY etherneteff3f0000 ng environment variable: pxeuuid
eving file: /boot/extlinux/pxelinux.cfg/01-00-1e-06-49 meteff3f0000 Waiting for PHY auto negotiation to comple not initialize PHY etherneteff3f0000
-110
How can I fix it? Card is readable with no problem, tested with another pc...
Thanks lot for help.
VicC
 ################### Logwatch 7.4.3 (04/27/16) ####################
        Processing Initiated: Fri Sep  3 07:37:59 2021
        Date Range Processed: yesterday
                              ( 2021-Sep-02 )
                              Period is day.
        Detail Level of Output: 0
        Type of Output/Format: mail / text
        Logfiles for Host:
 --------------------- dpkg status changes Begin ------------------------
 Upgraded:
    armbian-bsp-cli-odroidhc4:arm64 21.05.8 => 21.08.1
    armbian-config:all 21.05.8 => 21.08
    armbian-firmware:all 21.05.8 => 21.08
    armbian-zsh:all 21.05.8 => 21.08
    linux-dtb-current-meson64:arm64 21.05.8 => 21.08.1
    linux-libc-dev:arm64 21.05.8 => 21.08.1
    openmediavault:all 5.6.13-1 => 5.6.14-1
Edited by VictorC
This doesn't looks like stock Armbian (we don't use extlinux kernel loading on this device) and title is HC2 while BSP files shows HC4.
  • Solution
sorry, my mistake, I was writing about HC4...
Finally I had to recover data from my last ddfull backup, so it is working now, booting from sd card again with no problem...
Initial instalation was done 6 months ago, from this source https://www.armbian.com/odroid-hc4
VicC
