I have a Forlinx OKA40i-C development board that has an arm R40 as its Soc.
I use the latest Linux kernel (5.14.2  that contains "lima" for mali400 GPU ) and the latest Debian (11 aka bullseye that contains mesa project).
but when I want to use GPU, like run the "kmscube" command  I encounter this error
DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory
if you know anybody that can help me with this problem, please please introduce him/her to me.
ps. I checked the #linux-sunxi channel that you suggested, nobody help me.
I desperately need your help.
Moved into new (off)topic since R40 has nothing to do with H3 and Armbian does not officially support any board with this SoC.
Make sure you have big enough CMA region, either via kernel config or using kernel argument. I suggest 128 MiB, but if it still doesn't work, try bigger.
