Allwinner H3 audio codec on OrangePi Zero Plus2 H3
Go to solution Solved by HenkK,
When searching the forum on this topic I find a number of hits saying the mainline kernel does not have support for the SOC codec, but these topics are kind of old and I find it hard to find the current status.
In the past I have been able to use the onboard audio codec. However, I have been forced to upgrade and I now find that with the kernel I get from Armbian, I do not see the audio (ALSA) device nodes for the codec, only for HDMI. When looking at the kernel configuration, it should be in (SUN8I_CODEC and SUN8I_CODEC_ANALOG are both 'y'), but alas. Does anyone know if and how I can enable the audio codec so I can have analog audio output?
I built Armbian myself, using:
This (last) commit:
commit 5f2e23e9081104653093633f34ce716a46ac46f7
Author: Piotr Szczepanik <piter75@gmail.com>
Date:   Wed Sep 8 09:54:06 2021 +0200
    Disabled hs400 on Helios64 (hopefully only temporarily) (#3126)
This command line:
./compile.sh BOARD=orangepizeroplus2-h3 RELEASE=buster KERNEL_ONLY=no KERNEL_CONFIGURE=no BUILD_MINIMAL=no BRANCH=current
This resulting /etc/armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD_NAME="Orange Pi Zero Plus 2"
BOARDFAMILY=sun8i
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=5f2e23e90
DISTRIBUTION_CODENAME=buster
DISTRIBUTION_STATUS=supported
VERSION=21.11.0-trunk
LINUXFAMILY=sunxi
ARCH=arm
IMAGE_TYPE=user-built
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
DESKTOP=xfce
BRANCH=current
It seems I did not look properly when looking up which versions (bullseye, buster, etc) are supported for this one. I may have ended up on the wrong page and concluded 'buster' was the safest one. Now, browsing on armbian.com I see that 'focal' is the first choice and 'buster' is not even mentioned. I am going to build focal now. This will not give me a different kernel, though.
  • Solution
OK, I come from a time when 1.3.17 was the stable kernel version and Slackware was the distribution of choice. I have done my share of kernel hacking over the years, but... device trees and overlays are still magic to me. It turns out I had to seek my answer in that corner: audio-codec had to be enabled in armbian-config (which changes the overlays in armbianEnv.txt).
Likewise ;)
My distribution of choice was also Slackware - IIRC v1.0 / there was not much choices at that time - in my case, Linux kernel has not even 1.0 :P
A lot has change since.
With totally limited resources we are trying to make this very complicated, purpose driven and diverse ecosystem as simple as possible.
https://docs.armbian.com/User-Guide_FAQ/
https://docs.armbian.com/#what-is-armbian
And I think you are doing a wonderful job. :)
For the purpose I am using the OPi0+2, a debian-like setup is too bloated, so my rootfs comes from buildroot. However, it is my experience that the kernel and uboot I get from Armbian are much more stable, so I use those. Also when I want to figure out how something works (for instance, analog audio :) ) I immediately revert to Armbian.
