y52 Posted September 25, 2021 Posted September 25, 2021 Hello, I was trying updating/upgrading Armbian on espressobin v.5 Linux kernel 4.19.56-mvebu64 #5.89 SMP PREEMPT Tue Jun 25 22:27:47 CEST 2019 aarch64 GNU/Linux and ran into confusion with initramfs-tools package. updating packages raises an error : Processing triggers for initramfs-tools (0.130) ... update-initramfs: Generating /boot/initrd.img-4.19.56-mvebu64 E: busybox or busybox-static, version 1:1.22.0-17~ or later, is required but not installed update-initramfs: failed for /boot/initrd.img-4.19.56-mvebu64 with 1. dpkg: error processing package initramfs-tools (--configure): subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1) root@espressobin:~# dpkg -C The following packages are only half configured, probably due to problems configuring them the first time. The configuration should be retried using dpkg --configure <package> or the configure menu option in dselect: initramfs-tools generic modular initramfs generator (automation) root@espressobin:~# apt-cache show initramfs-tools Package: initramfs-tools Version: 0.130 Installed-Size: 105 Maintainer: Debian kernel team <debian-kernel@lists.debian.org> Architecture: all Provides: linux-initramfs-tool Depends: initramfs-tools-core (= 0.130), linux-base Suggests: bash-completion Conflicts: linux-initramfs-tool, usplash (<< 0.5.50) Breaks: console-setup (<< 1.72), cryptsetup (<< 2:1.6.6-4~), e2fsprogs (<< 1.42.13), elilo (<< 3.12-3.1~), initscripts (<< 2.88dsf-59.3~), lilo (<< 22.8-8.2~), lvm2 (<< 2.02.111-2.1~), s390-tools (<< 1.8.3-2~), systemd-sysv (<< 186), upstart Description: generic modular initramfs generator (automation) Description-md5: f406a6ad4452bdc36e9957a711143c2e Multi-Arch: foreign Tag: admin::boot, admin::filesystem, admin::install, admin::kernel, implemented-in::shell, interface::commandline, role::program, scope::application, scope::utility, works-with::archive Section: utils Priority: optional Filename: pool/main/i/initramfs-tools/initramfs-tools_0.130_all.deb Size: 65976 MD5sum: 19760d5fe943a82127871846bf188e76 SHA256: b5a2071f6d5bd25d894097717e1efd9441b6253c238220d014511e01ae81cbff Is initramfs-tools required on that system? 'apt autoremove' suggests removing other packages, including linux-stretch-root-next-espressobin : root@espressobin:~# apt remove initramfs-tools Reading package lists... Done Building dependency tree Reading state information... Done The following packages were automatically installed and are no longer required: initramfs-tools-core klibc-utils libklibc Use 'apt autoremove' to remove them. The following packages will be REMOVED: initramfs-tools linux-stretch-root-next-espressobin 0 upgraded, 0 newly installed, 2 to remove and 174 not upgraded. 1 not fully installed or removed. After this operation, 109 kB disk space will be freed. Do you want to continue? [Y/n] Y^C root@espressobin:~# apt-cache show linux-stretch-root-next-espressobin Package: linux-stretch-root-next-espressobin Status: install ok installed Priority: optional Section: kernel Installed-Size: 1 Maintainer: Igor Pecovnik <igor.pecovnik@****l.com> Architecture: arm64 Version: 5.90 Replaces: zram-config, base-files, armbian-tools-stretch Provides: armbian-bsp Depends: bash, linux-base, u-boot-tools, initramfs-tools, python3-apt Recommends: bsdutils, parted, util-linux, toilet Suggests: armbian-config Conflicts: armbian-bsp Description: Armbian tweaks for stretch on espressobin (next branch) Description-md5: 89a961dbb58e2aad95259300d73b63b8 How could initramfs-tools dependency on busybox be overcome? Could initramfs-tools and linux-stretch-root-next-espressobin be removed at all from the running system? My /boot directory content : root@espressobin:~# ls -al /boot total 31716 drwxr-xr-x 3 root root 4096 Sep 25 17:05 . drwxr-xr-x 25 root root 4096 Jul 2 22:34 .. -rw-r--r-- 1 root root 221 Sep 25 07:17 armbianEnv.txt -rw-r--r-- 1 root root 1536 Feb 9 2019 armbian_first_run.txt.template -rw-r--r-- 1 root root 38518 Feb 9 2019 boot.bmp -rw-rw-r-- 1 root root 1047 Feb 9 2019 boot.cmd -rw-r--r-- 1 root root 4882 Feb 9 2019 boot-desktop.png -rw-rw-r-- 1 root root 1119 Feb 9 2019 boot.scr -rw-r--r-- 1 root root 139058 Jun 25 2019 config-4.19.56-mvebu64 lrwxrwxrwx 1 root root 19 Aug 8 2019 dtb -> dtb-4.19.56-mvebu64 drwxr-xr-x 3 root root 4096 Aug 8 2019 dtb-4.19.56-mvebu64 lrwxrwxrwx 1 root root 19 Feb 9 2019 dtb.old -> dtb-4.19.20-mvebu64 lrwxrwxrwx 1 root root 23 Aug 8 2019 Image -> vmlinuz-4.19.56-mvebu64 -rw-r--r-- 1 root root 6200589 Sep 28 2020 initrd.img-4.19.56-mvebu64 -rw-r--r-- 1 root root 0 Aug 8 2019 .next -rw-r--r-- 1 root root 3366255 Jun 25 2019 System.map-4.19.56-mvebu64 lrwxrwxrwx 1 root root 23 Sep 28 2020 uInitrd -> uInitrd-4.19.56-mvebu64 -rw-r--r-- 1 root root 6200653 Sep 28 2020 uInitrd-4.19.56-mvebu64 -rwxr-xr-x 1 root root 16488960 Jun 25 2019 vmlinuz-4.19.56-mvebu64
tparys Posted September 26, 2021 Posted September 26, 2021 EspressoBin is currently in CSC support, so best to submit bugs/questions in in Peer to Peer Support. Also need to submit armbianmonitor output. It seems dumb, but there's a lot of necessary information in there. 17 hours ago, y52 said: Processing triggers for initramfs-tools (0.130) ... update-initramfs: Generating /boot/initrd.img-4.19.56-mvebu64 E: busybox or busybox-static, version 1:1.22.0-17~ or later, is required but not installed However, in this case, it tells you exactly what died. You've somehow uninstalled busybox (directly or indirectly), and initramfs-tools can't work properly without it. 17 hours ago, y52 said: Is initramfs-tools required on that system? Could initramfs-tools and linux-stretch-root-next-espressobin be removed at all from the running system? Not advisable. The initramfs-tools package generates the initrd file for the kernel, which is generally a required part of the boot process. You'll want to get this fixed, and probably not reboot in the meantime until you do. 1
Heisath Posted September 27, 2021 Posted September 27, 2021 Probably 'apt install busybox' is the easiest / straightforward way to fix your immediate problem. Regarding further problems with upgrading from Stretch: Espressobin is CSC and Debian Stretch (along with all armbian 5.90) is long out of support/maintenance. You can try upgrading to something more modern (buster / bullseye) but are on your own. Or reinstall / redownload more current image.
y52 Posted September 27, 2021 Author Posted September 27, 2021 Thanks to everybody. 'apt install busybox' indeed fixed the issue. I was not sure that initramfs image is regenerated on this arm board, as the kernel remains static and boot process is dependent on u-boot settings. A side note : It is not feasible not rebooting My espressobin is rebooting on its own every day or two and it happens since I bought it. I've never been able finding out what causes those intempestive reboots. The system doesn't raise any errors. It would be interesting finding in Peer to Peer Support someone's experience upgrading from Stretch to something more modern. Has anybody achieved it?
Heisath Posted September 28, 2021 Posted September 28, 2021 Sure I went from stretch to buster to bullseye. There's lots of instructions on the web (basically update/upgrade your current system, change apt sources, then update/upgrade again and fix errors as they appear). I did that on my clearfogpro relatively flawless, although I absolutely recommend having a backup It is pretty much the same as any other debian system. For stability on espressobin, I'd recommend checking the threads in the A380/A3700 subforum. Maybe helpful threads: https://forum.armbian.com/forum/32-armada-a388-a3700/
lampra Posted September 28, 2021 Posted September 28, 2021 On 9/27/2021 at 12:57 PM, y52 said: upgrading from Stretch to something more modern. I used the Debian manual to upgrade from Stretch to Buster but not on espressobin. You may face some minor issues with python (from 2.7 to 3) but nothing very serious on the system itself. Though, you need to check first the dependencies of other software that you have installed.IIRW, I had some issues with owncloud which I had installed before the nextcloud fork. There is also a major upgrade of uboot and boot.cmd on recent builds so you might need to flash the latest uboot also Are you booting from the sd card or from sata? You could probably try first with a dual boot system i e. set the priority in the uboot environmental variables and test the new builds for some time before upgrading your current system. Or you could keep your current system as is and try to setup/install the needed software on a new (eg 21.08) release and use dualboot if needed. About the stability, I also had issues on my v5 board, so I moved to openwrt 19.07 which is rock solid using overlay but of limited abilities. I am planning a test migration back to armbian in the next months now that the mainline kernel includes the recent patches. Openwrt has also produced uboot builds (look at the supplementary files) for recent distros
y52 Posted September 29, 2021 Author Posted September 29, 2021 15 hours ago, lampra said: major upgrade of uboot and boot.cmd on recent builds Are they part of Armbian now or Debian? I initially upgraded uboot from Armbian to sustain compatibility between uboot and OS build. Where are uboot binaries now ? 15 hours ago, lampra said: Are you booting from the sd card or from sata? I found SD card unreliable. Once the system crashed again due to the SD card failure, I moved to SATA SSD.
lampra Posted September 29, 2021 Posted September 29, 2021 1 hour ago, y52 said: Where are uboot binaries now You can find here the uboot binaries from armbian and here the boot.cmd-src. I expect that they are no longer maintained. The binaries from openwrt should be compatible with armbian, I expect that you will need to use the armbian boot.cmd-src though, or modify it according to your needs and boot environment as described here. PS: Could you post here your current uboot version, your boot.cmd and your current uboot environment?
y52 Posted September 30, 2021 Author Posted September 30, 2021 On 9/29/2021 at 5:14 PM, lampra said: PS: Could you post here your current uboot version, your boot.cmd and your current uboot environment? Here is what I have : bubt u-boot/181226.flash-image-ddr3-2g-2cs-1000_800.bin spi usb Marvell>> bubt u-boot/181226.flash-image-ddr3-2g-2cs-1000_800.bin spi usb Burning U-BOOT image "u-boot/181226.flash-image-ddr3-2g-2cs-1000_800.bin" from "usb" to "spi" USB0: Register 2000104 NbrPorts 2 Starting the controller USB XHCI 1.00 USB1: USB EHCI 1.00 scanning bus 0 for devices... 2 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found reading u-boot/181226.flash-image-ddr3-2g-2cs-1000_800.bin Image checksum...OK! SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB 676040 bytes written, 212992 bytes skipped in 12.491s, speed 72876 B/s Done! Marvell>> version U-Boot 2018.03-devel-18.12.3-gc9aa92c-armbian (Dec 26 2018 - 13:45:06 +0100) aarch64-linux-gnu-gcc (Linaro GCC 7.3-2018.05) 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] GNU ld (Linaro_Binutils-2018.05) 2.28.2.20170706 Marvell>> reset WTMI-devel-18.12.0-a0a1cb8 WTMI: system early-init SVC REV: 3, CPU VDD voltage: 1.155V NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.5(release):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL1: Built : 13:48:02, Dec 26 2018 NOTICE: BL1: Booting BL2 NOTICE: BL2: v1.5(release):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL2: Built : 13:48:04, Dec 26 2018 NOTICE: BL1: Booting BL31 NOTICE: BL31: v1.5(release):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL31: Built : 13:4 U-Boot 2018.03-devel-18.12.3-gc9aa92c-armbian (Dec 26 2018 - 13:45:06 +0100) Model: Marvell Armada 3720 Community Board ESPRESSOBin CPU 1000 [MHz] L2 800 [MHz] TClock 200 [MHz] DDR 800 [MHz] DRAM: 2 GiB Comphy chip #0: Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link down MMC: sdhci@d0000: 0 Loading Environment from SPI Flash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Marvell Armada 3720 Community Board ESPRESSOBin Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 1119 bytes read in 14 ms (77.1 KiB/s) ## Executing script at 06d00000 243 bytes read in 5 ms (46.9 KiB/s) 15690240 bytes read in 673 ms (22.2 MiB/s) 5981154 bytes read in 270 ms (21.1 MiB/s) ** File not found /boot/dtb/marvell/armada-3720-community.dtb ** 8607 bytes read in 10 ms (839.8 KiB/s) ## Loading init Ramdisk from Legacy Image at 01100000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 5981090 Bytes = 5.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 06000000 Booting using the fdt blob at 0x6000000 Loading Ramdisk to 7f076000, end 7f62a3a2 ... OK Using Device Tree in place at 0000000006000000, end 000000000600519e Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 4.18.8-mvebu64 (root@nightly) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #259 SMP PREEMPT Wed Sep 19 11:14:00 CEST 2018 [ 0.000000] Machine model: Globalscale Marvell ESPRESSOBin Board [ 0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options '') [ 0.000000] bootconsole [ar3700_uart0] enabled Loading, please wait... starting version 239 root@espressobin:~# cat /boot/boot.cmd # DO NOT EDIT THIS FILE # # Please edit /boot/armbianEnv.txt to set supported parameters # # default values setenv rootdev "/dev/mmcblk0p1" setenv verbosity "1" setenv rootfstype "ext4" # additional values setenv ethaddr "F0:AD:4E:03:64:7F" load ${boot_interface} ${devnum}:1 ${scriptaddr} ${prefix}armbianEnv.txt env import -t ${scriptaddr} ${filesize} setenv bootargs "$console root=${rootdev} rootfstype=${rootfstype} rootwait loglevel=${verbosity} usb-storage.quirks=${usbstoragequirks} mtdparts=spi0.0:1536k(uboot),64k(uboot-environment),-(reserved) ${extraargs}" setenv fdt_name_a dtb/marvell/armada-3720-community.dtb setenv fdt_name_b dtb/marvell/armada-3720-espressobin.dtb ext4load $boot_interface 0:1 $kernel_addr ${prefix}$image_name ext4load $boot_interface 0:1 $initrd_addr ${prefix}$initrd_image ext4load $boot_interface 0:1 $fdt_addr ${prefix}$fdt_name_a ext4load $boot_interface 0:1 $fdt_addr ${prefix}$fdt_name_b booti $kernel_addr $initrd_addr $fdt_addr # mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr root@espressobin:~# ls -al /boot/dtb/marvell/ total 124 drwxr-xr-x 2 root root 4096 Aug 8 2019 . drwxr-xr-x 3 root root 4096 Aug 8 2019 .. -rw-r--r-- 1 root root 9158 Jun 25 2019 armada-3720-db.dtb -rw-r--r-- 1 root root 8942 Jun 25 2019 armada-3720-espressobin.dtb And finally "uboot environment" : Marvell>> printenv arch=arm baudrate=115200 board=mvebu_armada-37xx board_name=mvebu_armada-37xx boot_a_script=ext4load ${boot_interface} ${devnum}:1 ${scriptaddr} ${prefix}boot.scr;source ${scriptaddr}; boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootaa64.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf boot_net_pci_enum=pci enum boot_net_usb_start=usb start boot_prefixes=/ /boot/ boot_script_dhcp=boot.scr.uimg boot_scripts=boot.scr.uimg boot.scr boot_targets=usb sata mmc1 mmc0 bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done bootcmd_dhcp=run boot_net_usb_start; run boot_net_pci_enum; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00011:UNDI:003000;setenv bootp_arch 0xb;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci; bootcmd_mmc0=setenv devnum 0; setenv boot_interface mmc; run scan_dev_for_boot; bootcmd_mmc1=setenv devnum 1; setenv boot_interface mmc; run scan_dev_for_boot; bootcmd_nfs=run get_images; run set_bootargs; booti $kernel_addr_r $ramdisk_addr_r $fdt_addr_r bootcmd_pxe=run boot_net_usb_start; run boot_net_pci_enum; dhcp; if pxe get; then pxe boot; fi bootcmd_sata=setenv devnum 0; scsi scan; scsi dev 0; setenv boot_interface scsi; run scan_dev_for_boot; bootcmd_scsi0=setenv devnum 0; run scsi_boot bootcmd_usb=setenv devnum 0; usb start;setenv boot_interface usb; run scan_dev_for_boot; bootcmd_usb0=setenv devnum 0; run usb_boot bootdelay=2 console=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 cpu=armv8 distro_bootcmd=setenv scsi_need_init; for target in ${boot_targets}; do run bootcmd_${target}; done efi_dtb_prefixes=/ /dtb/ /dtb/current/ eth1addr=00:51:82:11:22:01 eth2addr=00:51:82:11:22:02 eth3addr=00:51:82:11:22:03 ethact=neta@30000 ethaddr=00:51:82:11:22:00 ethprime=eth0 extra_params=pci=pcie_bus_safe fdt_addr=0x6000000 fdt_addr_r=0x6f00000 fdt_high=0xffffffffffffffff fdt_name=fdt.dtb fdtcontroladdr=7f7142d8 gatewayip=10.4.50.254 get_images=tftpboot $kernel_addr_r $image_name; tftpboot $fdt_addr_r $fdt_name; run get_ramdisk get_ramdisk=if test "${ramdisk_name}" != "-"; then tftpboot $ramdisk_addr_r $ramdisk_name; else setenv ramdisk_addr_r -;fi hostname=marvell image_name=boot/Image initrd_addr=0x1100000 initrd_image=uInitrd initrd_size=0x2000000 ipaddr=0.0.0.0 kernel_addr=0x7000000 kernel_addr_r=0x7000000 load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile} loadaddr=0x8000000 mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi netdev=eth0 netmask=255.255.255.0 pxefile_addr_r=0x6e00000 ramdisk_addr_r=0xa000000 ramdisk_name=- root=root=/dev/nfs rw rootpath=/srv/nfs scan_dev_for_boot=for prefix in ${boot_prefixes}; do echo ${prefix};run boot_a_script; done scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootaa64.efi; then echo Found EFI removable media binary efi/boot/bootaa64.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done scriptaddr=0x6d00000 scsi_boot=run scsi_init; if scsi dev ${devnum}; then setenv devtype scsi; run scan_dev_for_boot_part; fi scsi_init=if ${scsi_need_init}; then setenv scsi_need_init false; scsi scan; fi serverip=0.0.0.0 set_bootargs=setenv bootargs $console $root ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:none nfsroot=$serverip:$rootpath $extra_params $cpuidle soc=mvebu stderr=serial@12000 stdin=serial@12000 stdout=serial@12000 usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi vendor=Marvell Environment size: 5204/65532 bytes 1
Werner Posted October 27, 2021 Posted October 27, 2021 Moved to Common issues / peer to peer technical support
