Hello, No access to GPIO without root. It is necessary for Moonraker.
in group
grep gpio /etc/group
gpio:x:1001:isp
isp@3dprinter:~$ echo 10 /sys/class/gpio/export
but
isp@3dprinter:~$ ls -lL /sys/class/gpio/
total 0
-rwxrwx--- 1 root gpio 4096 сен 25 23:10 export
drwxr-xr-x 3 root root    0 сен 25 23:10 gpiochip0
drwxr-xr-x 3 root root    0 сен 25 23:10 gpiochip352
-rwxrwx--- 1 root gpio 4096 сен 25 23:10 unexport
 and
isp@3dprinter:~$ sudo cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl:
 gpio-17  (                    |orangepi:red:status ) out lo
 gpio-20  (                    |reg_vcc_wifi        ) out hi
 gpio-166 (                    |cd                  ) in  lo ACTIVE LOW
 gpio-204 (                    |usb0_id_det         ) in  hi IRQ
gpiochip1: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl:
 gpio-358 (                    |vdd-cpux            ) out lo
 gpio-359 (                    |reset               ) out hi ACTIVE LOW
 gpio-362 (                    |orangepi:green:pwr  ) out hi
 if i make
echo 10 | sudo tee /sys/class/gpio/export
 then all ok
 gpio-10  (                    |sysfs               ) in  lo
 rc.local:
chown -R root:gpio /sys/class/gpio
chmod -R 770 /sys/class/gpio
99-gpio.rules
SUBSYSTEM=="gpio", PROGRAM="/bin/sh -c 'chown -R root:gpio /sys/class/gpio && chmod -R 770 /sys/class/gpio'"
SUBSYSTEM=="gpio", PROGRAM="/bin/sh -c 'chown -R root:gpio /sys/devices/platform/soc/1c20800.pinctrl/gpiochip0/gpio && chmod -R 770 /sys/devices/platform/soc/1c20800.pinctrl/gpiochip0/gpio'"
 What am I doing wrong? I need to access GPIO without root to work with Moonraker. Thanks!
Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs).  With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported.  Your report is invalid for one or more of the following reasons (non-exhaustive list):
  • it is for an unsupported board or image (CSC/EOS/WIP/edge)
  • it is for software that is not supported (such as userspace modules installed on top of the core operating system)
  • it has been logged in the wrong forum (for example requests for help that are not actual bug reports)
  • it lacks requested data (armbianmonitor output)
  • it could have been easily solved by a quick search and/or reading documentation
Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
  • Werner changed the title to [Invalid] - GPIO non-access root
  • Werner unlocked this topic
