Does armbian applied overlays-00-add-oc-opp-rk3399.patch by default in NanoPi r4s?
Go to solution Solved by Junkman,
Hi all, I'm new to armbian, I have a nanopi r4s SBC, and I want to know that if armbian nanopi r4s enabled(applied) `overlays-00-add-oc-opp-rk3399.patch` by default?
i.e. https://github.com/armbian/build/blob/master/patch/kernel/archive/rockchip64-5.10/overlays-00-add-oc-opp-rk3399.patch
I really need this patch to bootst up performance, otherwise I have to build armbian by myself.
Edited by Junkman
On 10/13/2021 at 2:59 AM, Werner said:
OC is not enabled by default but you can simply enable is via armbian-config.
I've check the DT, the overclock patch hasn't applied to the kernel DT. it using the default clock, and in armbian-config, the maximum clock speed allowable is 1.8GHz.
        opp07 {
            opp-hz = <0x00 0x6b49d200>;
            opp-microvolt = <0x124f80>;
10 minutes ago, Werner said:
Hm odd. It seems like overlay support is completely gone or I am blind...
I didn't know it could be done with armbian-config. I always did it manually in /boot/armbianEnv.txt
overlay_prefix=rockchip
overlays=rk3399-opp-2ghz
  • Solution
Thanks you guys! @Werner, @NicoD
Here is how I did this:
$ sudo armbian-add-overlay rk3399-oc.dts
$ ls -1 /boot/overlay-user/
rk3399-oc.dtbo
$ cat /boot/armbianEnv.txt
verbosity=1
bootlogo=false
rootdev=UUID=6c8153dd-e3ae-4b9c-8ea2-9c34a84bbed8
rootfstype=ext4
console=serial
user_overlays=rk3399-oc
$ reboot
$ sudo apt install -y armbian-config
$ sudo armbian-config # System -> CPU (Choose new CPU freq)
# Done
