voka 2 Posted October 27, 2021 Share Posted October 27, 2021 Armbianmonitor: http://ix.io/3D2i /var/log/Xorg.0.log: [ 59.326] (EE) AIGLX error: sun4i-drm does not export required DRI extension [ 59.550] (II) IGLX: Loaded and initialized swrast [ 59.550] (II) GLX: Initialized DRISWRAST GL provider for screen 0 [ 59.550] (II) Initializing extension XFree86-VidModeExtension [ 59.551] (II) Initializing extension XFree86-DGA [ 59.553] (II) Initializing extension XFree86-DRI [ 59.553] (II) Initializing extension DRI2 [ 59.564] (II) modeset(0): Damage tracking initialized [ 59.565] (II) modeset(0): Setting screen physical size to 508 x 285 [ 60.561] (II) config/udev: Adding input device sunxi-ir (/dev/input/event1) [ 60.561] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 60.561] (II) LoadModule: "libinput" [ 60.562] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so [ 60.624] (II) Module libinput: vendor="X.Org Foundation" [ 60.624] compiled for 1.20.4, module version = 0.29.0 [ 60.624] Module class: X.Org XInput Driver [ 60.624] ABI class: X.Org XInput driver, version 24.1 [ 60.624] (II) Using input driver 'libinput' for 'sunxi-ir' [ 60.624] (**) sunxi-ir: always reports core events [ 60.624] (**) Option "Device" "/dev/input/event1" [ 60.625] (**) Option "_source" "server/udev" [ 60.703] (II) event1 - sunxi-ir: is tagged by udev as: Keyboard Pointingstick [ 60.708] (II) event1 - sunxi-ir: device is a pointer [ 60.708] (II) event1 - sunxi-ir: device is a keyboard [ 60.710] (II) event1 - sunxi-ir: device removed [ 60.749] (II) libinput: sunxi-ir: needs a virtual subdevice [ 60.749] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c21800.ir/rc/rc0/input1/event1" [ 60.749] (II) XINPUT: Adding extended input device "sunxi-ir" (type: MOUSE, id 6) 0 Quote Link to post Share on other sites More sharing options...
0 voka 2 Posted October 29, 2021 Author Share Posted October 29, 2021 Possible solution, did not check https://forum.clockworkpi.com/t/apt-full-upgrade-getting-the-new-software-updates-from-debian/5664 0 Quote Link to post Share on other sites More sharing options...
0 ning 39 Posted October 30, 2021 Share Posted October 30, 2021 please update your Xserver 0 Quote Link to post Share on other sites More sharing options...
0 voka 2 Posted November 1, 2021 Author Share Posted November 1, 2021 Install Armbian 21.11.0-trunk X.Org X Server version 1.20.11 Still black screen and same error how to upgrade xorg to a new version? 0 Quote Link to post Share on other sites More sharing options...
0 OLEGIM 0 Posted November 6, 2021 Share Posted November 6, 2021 Guys, help. I installed the armbian 21.08.1 Focal XFCE base image and ran it. Video over HDMI shows black screen. After the update, nothing has changed. I tried several actions that were written on the forum, but nothing helped. What steps need to be taken to fix this? armbian 21.08.1 Focal XFCE armbianmonitor -u http://ix.io/3E9k journalctl -p 3 -xe -- Logs begin at Fri 2021-11-05 22:16:31 UTC, end at Fri 2021-11-05 22:25:01 UTC. -- Nov 05 22:16:31 cubietruck kernel: sun4i-drm display-engine: attempt to add DMA range to existing map Nov 05 22:16:31 cubietruck kernel: debugfs: Directory '1c22c00.codec' with parent 'sun4i-codec' already present! Nov 05 22:16:32 cubietruck kernel: phy id_det change to device Nov 05 22:16:32 cubietruck kernel: Bluetooth: hci0: BCM: firmware Patch file not found, tried: Nov 05 22:16:32 cubietruck kernel: Bluetooth: hci0: BCM: 'brcm/BCM20702A1.hcd' Nov 05 22:16:32 cubietruck kernel: Bluetooth: hci0: BCM: 'brcm/BCM.hcd' Nov 05 22:17:11 cubietruck kernel: ieee80211 phy0: brcmf_p2p_create_p2pdev: timeout occurred Nov 05 22:17:11 cubietruck kernel: ieee80211 phy0: brcmf_cfg80211_add_iface: add iface p2p-dev-wlan0 type 10 failed: err=-5 Nov 05 22:17:11 cubietruck wpa_supplicant[1651]: Failed to create interface p2p-dev-wlan0: -5 (Input/output error) Nov 05 22:17:11 cubietruck wpa_supplicant[1651]: nl80211: Failed to create a P2P Device interface p2p-dev-wlan0 Nov 05 22:17:15 cubietruck kernel: lima 1c40000.gpu: mmu page fault at 0x28fc340 from bus id 0 of type read on gpmmu Nov 05 22:17:15 cubietruck kernel: lima 1c40000.gpu: gp task error int_state=0 status=a Nov 05 22:17:16 cubietruck lightdm[1946]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory Nov 05 22:17:16 cubietruck lightdm[1946]: PAM adding faulty module: pam_kwallet.so Nov 05 22:17:16 cubietruck lightdm[1946]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory Nov 05 22:17:16 cubietruck lightdm[1946]: PAM adding faulty module: pam_kwallet5.so Nov 05 22:17:27 cubietruck lightdm[2018]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory Nov 05 22:17:27 cubietruck lightdm[2018]: PAM adding faulty module: pam_kwallet.so Nov 05 22:17:27 cubietruck lightdm[2018]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory Nov 05 22:17:27 cubietruck lightdm[2018]: PAM adding faulty module: pam_kwallet5.so Nov 05 22:21:38 cubietruck lightdm[2045]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory Nov 05 22:21:38 cubietruck lightdm[2045]: PAM adding faulty module: pam_kwallet.so Nov 05 22:21:38 cubietruck lightdm[2045]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory Nov 05 22:21:38 cubietruck lightdm[2045]: PAM adding faulty module: pam_kwallet5.so Nov 05 22:21:41 cubietruck lightdm[2047]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory Nov 05 22:21:41 cubietruck lightdm[2047]: PAM adding faulty module: pam_kwallet.so Nov 05 22:21:41 cubietruck lightdm[2047]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory Nov 05 22:21:41 cubietruck lightdm[2047]: PAM adding faulty module: pam_kwallet5.so Nov 05 22:21:58 cubietruck bluetoothd[1609]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98) Nov 05 22:21:58 cubietruck bluetoothd[1609]: RFCOMM server failed for :1.88/Profile/HSPHSProfile/00001108-0000-1000-8000-00805f9b34fb: rfcomm_bind: Address already in use (98) Xorg logs cat /var/log/Xorg.0.log Скрытый текст [ 60.941] X.Org X Server 1.20.11 X Protocol Version 11, Revision 0 [ 60.941] Build Operating System: linux Ubuntu [ 60.941] Current Operating System: Linux cubietruck 5.10.60-sunxi #21.08.1 SMP Wed Aug 25 18:19:32 UTC 2021 armv7l [ 60.941] Kernel command line: root=UUID=6013a5e8-5c4b-4aaa-bf84-e8ba72a01877 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=e25f374d-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 [ 60.942] Build Date: 06 July 2021 10:17:51AM [ 60.942] xorg-server 2:1.20.11-1ubuntu1~20.04.2 (For technical support please see http://www.ubuntu.com/support) [ 60.942] Current version of pixman: 0.38.4 [ 60.942] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 60.942] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 60.943] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Nov 5 22:30:16 2021 [ 61.080] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 61.081] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 61.140] (==) No Layout section. Using the first Screen section. [ 61.141] (==) No screen section available. Using defaults. [ 61.141] (**) |-->Screen "Default Screen Section" (0) [ 61.141] (**) | |-->Monitor "<default monitor>" [ 61.143] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 61.143] (**) Option "BlankTime" "0" [ 61.143] (**) Option "StandbyTime" "0" [ 61.143] (**) Option "SuspendTime" "0" [ 61.143] (**) Option "OffTime" "0" [ 61.143] (==) Automatically adding devices [ 61.144] (==) Automatically enabling devices [ 61.144] (==) Automatically adding GPU devices [ 61.144] (==) Automatically binding GPU devices [ 61.144] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 61.257] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 61.258] Entry deleted from font path. [ 61.336] (==) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, built-ins [ 61.339] (==) ModulePath set to "/usr/lib/xorg/modules" [ 61.339] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 61.339] (II) Loader magic: 0x584008 [ 61.339] (II) Module ABI versions: [ 61.339] X.Org ANSI C Emulation: 0.4 [ 61.339] X.Org Video Driver: 24.1 [ 61.339] X.Org XInput driver : 24.1 [ 61.339] X.Org Server Extension : 10.0 [ 61.345] (++) using VT number 7 [ 61.345] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 61.366] (II) xfree86: Adding drm device (/dev/dri/card0) [ 61.373] (II) xfree86: Adding drm device (/dev/dri/card1) [ 61.377] (II) no primary bus or device found [ 61.377] falling back to /sys/devices/platform/display-engine/drm/card0 [ 61.377] (II) LoadModule: "glx" [ 61.386] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 61.496] (II) Module glx: vendor="X.Org Foundation" [ 61.496] compiled for 1.20.11, module version = 1.0.0 [ 61.496] ABI class: X.Org Server Extension, version 10.0 [ 61.496] (==) Matched modesetting as autoconfigured driver 0 [ 61.497] (==) Matched fbdev as autoconfigured driver 1 [ 61.497] (==) Assigned the driver to the xf86ConfigLayout [ 61.497] (II) LoadModule: "modesetting" [ 61.497] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so [ 61.506] (II) Module modesetting: vendor="X.Org Foundation" [ 61.507] compiled for 1.20.11, module version = 1.20.11 [ 61.508] Module class: X.Org Video Driver [ 61.508] ABI class: X.Org Video Driver, version 24.1 [ 61.508] (II) LoadModule: "fbdev" [ 61.509] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 61.531] (II) Module fbdev: vendor="X.Org Foundation" [ 61.532] compiled for 1.20.1, module version = 0.5.0 [ 61.533] Module class: X.Org Video Driver [ 61.533] ABI class: X.Org Video Driver, version 24.0 [ 61.535] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 61.535] (II) FBDEV: driver for framebuffer: fbdev [ 61.601] (II) modeset(0): using drv /dev/dri/card0 [ 61.601] (WW) Falling back to old probe method for fbdev [ 61.601] (II) Loading sub module "fbdevhw" [ 61.602] (II) LoadModule: "fbdevhw" [ 61.602] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 61.610] (II) Module fbdevhw: vendor="X.Org Foundation" [ 61.611] compiled for 1.20.11, module version = 0.0.2 [ 61.611] ABI class: X.Org Video Driver, version 24.1 [ 61.657] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support [ 61.658] (II) modeset(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 61.658] (==) modeset(0): Depth 24, (==) framebuffer bpp 32 [ 61.658] (==) modeset(0): RGB weight 888 [ 61.658] (==) modeset(0): Default visual is TrueColor [ 61.659] (II) Loading sub module "glamoregl" [ 61.659] (II) LoadModule: "glamoregl" [ 61.659] (II) Loading /usr/lib/xorg/modules/libglamoregl.so [ 61.777] (II) Module glamoregl: vendor="X.Org Foundation" [ 61.777] compiled for 1.20.11, module version = 1.0.1 [ 61.777] ABI class: X.Org ANSI C Emulation, version 0.4 [ 65.210] (II) modeset(0): glamor X acceleration enabled on Mali400 [ 65.210] (II) modeset(0): glamor initialized [ 65.245] (II) modeset(0): Output HDMI-1 has no monitor section [ 65.276] (II) modeset(0): EDID for output HDMI-1 [ 65.276] (II) modeset(0): Manufacturer: AOC Model: 2716 Serial#: 16843009 [ 65.276] (II) modeset(0): Year: 2016 Week: 0 [ 65.276] (II) modeset(0): EDID Version: 1.3 [ 65.276] (II) modeset(0): Digital Display Input [ 65.277] (II) modeset(0): Max Image Size [cm]: horiz.: 60 vert.: 34 [ 65.277] (II) modeset(0): Gamma: 2.20 [ 65.277] (II) modeset(0): No DPMS capabilities specified [ 65.277] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 [ 65.277] (II) modeset(0): Default color space is primary color space [ 65.277] (II) modeset(0): First detailed timing is preferred mode [ 65.277] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600 [ 65.277] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329 [ 65.277] (II) modeset(0): Supported established timings: [ 65.277] (II) modeset(0): 640x480@60Hz [ 65.277] (II) modeset(0): 800x600@60Hz [ 65.277] (II) modeset(0): 1024x768@60Hz [ 65.277] (II) modeset(0): Manufacturer's mask: 0 [ 65.278] (II) modeset(0): Supported detailed timing: [ 65.278] (II) modeset(0): clock: 148.5 MHz Image Size: 596 x 335 mm [ 65.278] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 65.278] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0 [ 65.278] (II) modeset(0): Serial No: [ 65.278] (II) modeset(0): Ranges: V min: 24 V max: 60 Hz, H min: 30 H max: 140 kHz, PixClock max 305 MHz [ 65.278] (II) modeset(0): Monitor name: AG271UG [ 65.278] (II) modeset(0): Number of EDID sections to follow: 1 [ 65.278] (II) modeset(0): EDID (in hex): [ 65.278] (II) modeset(0): 00ffffffffffff0005e3162701010101 [ 65.279] (II) modeset(0): 001a0103803c22780eee91a3544c9926 [ 65.279] (II) modeset(0): 0f505421080001010101010101010101 [ 65.279] (II) modeset(0): 010101010101023a801871382d40582c [ 65.279] (II) modeset(0): 4500544f2100001e000000ff000a2020 [ 65.279] (II) modeset(0): 20202020202020202020000000fd0018 [ 65.279] (II) modeset(0): 3c1e8c1e010a202020202020000000fc [ 65.279] (II) modeset(0): 00414732373155470a20202020200187 [ 65.279] (II) modeset(0): 020323c149901f04130312015d5f2309 [ 65.279] (II) modeset(0): 0701830100006c030c001000003c2010 [ 65.279] (II) modeset(0): 40030100000000000000000000000000 [ 65.279] (II) modeset(0): 00000000000000000000000000000000 [ 65.279] (II) modeset(0): 00000000000000000000000000000000 [ 65.279] (II) modeset(0): 00000000000000000000000000000000 [ 65.280] (II) modeset(0): 00000000000000000000000000000000 [ 65.280] (II) modeset(0): 00000000000000000000000000000043 [ 65.280] (--) modeset(0): HDMI max TMDS frequency 300000KHz [ 65.280] (II) modeset(0): Printing probed modes for output HDMI-1 [ 65.281] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 65.281] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 65.281] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e) [ 65.281] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 65.281] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 65.281] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 65.281] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 65.281] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 65.281] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 65.281] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 65.281] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 65.281] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 65.281] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 65.281] (II) modeset(0): Output HDMI-1 connected [ 65.282] (II) modeset(0): Using exact sizes for initial modes [ 65.282] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0 [ 65.282] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0) [ 65.282] (==) modeset(0): DPI set to (96, 96) [ 65.282] (II) Loading sub module "fb" [ 65.282] (II) LoadModule: "fb" [ 65.283] (II) Loading /usr/lib/xorg/modules/libfb.so [ 65.290] (II) Module fb: vendor="X.Org Foundation" [ 65.291] compiled for 1.20.11, module version = 1.0.0 [ 65.291] ABI class: X.Org ANSI C Emulation, version 0.4 [ 65.291] (II) UnloadModule: "fbdev" [ 65.291] (II) Unloading fbdev [ 65.291] (II) UnloadSubModule: "fbdevhw" [ 65.292] (II) Unloading fbdevhw [ 65.597] (==) modeset(0): Backing store enabled [ 65.598] (==) modeset(0): Silken mouse enabled [ 65.618] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc. [ 65.619] (==) modeset(0): DPMS enabled [ 65.620] (II) modeset(0): [DRI2] Setup complete [ 65.621] (II) modeset(0): [DRI2] DRI driver: sun4i-drm [ 65.621] (II) modeset(0): [DRI2] VDPAU driver: sun4i-drm [ 65.621] (II) Initializing extension Generic Event Extension [ 65.623] (II) Initializing extension SHAPE [ 65.624] (II) Initializing extension MIT-SHM [ 65.626] (II) Initializing extension XInputExtension [ 65.628] (II) Initializing extension XTEST [ 65.629] (II) Initializing extension BIG-REQUESTS [ 65.631] (II) Initializing extension SYNC [ 65.632] (II) Initializing extension XKEYBOARD [ 65.634] (II) Initializing extension XC-MISC [ 65.635] (II) Initializing extension SECURITY [ 65.637] (II) Initializing extension XFIXES [ 65.638] (II) Initializing extension RENDER [ 65.640] (II) Initializing extension RANDR [ 65.643] (II) Initializing extension COMPOSITE [ 65.644] (II) Initializing extension DAMAGE [ 65.646] (II) Initializing extension MIT-SCREEN-SAVER [ 65.647] (II) Initializing extension DOUBLE-BUFFER [ 65.649] (II) Initializing extension RECORD [ 65.650] (II) Initializing extension DPMS [ 65.652] (II) Initializing extension Present [ 65.653] (II) Initializing extension DRI3 [ 65.655] (II) Initializing extension X-Resource [ 65.656] (II) Initializing extension XVideo [ 65.658] (II) Initializing extension XVideo-MotionCompensation [ 65.658] (II) Initializing extension SELinux [ 65.658] (II) SELinux: Disabled on system [ 65.658] (II) Initializing extension GLX [ 65.660] (EE) AIGLX error: sun4i-drm does not export required DRI extension [ 65.791] (II) IGLX: Loaded and initialized swrast [ 65.792] (II) GLX: Initialized DRISWRAST GL provider for screen 0 [ 65.792] (II) Initializing extension XFree86-VidModeExtension [ 65.793] (II) Initializing extension XFree86-DGA [ 65.795] (II) Initializing extension XFree86-DRI [ 65.795] (II) Initializing extension DRI2 [ 65.806] (II) modeset(0): Damage tracking initialized [ 65.806] (II) modeset(0): Setting screen physical size to 508 x 285 [ 66.431] (II) config/udev: Adding input device HID 05ac:0256 (/dev/input/event2) [ 66.432] (**) HID 05ac:0256: Applying InputClass "libinput keyboard catchall" [ 66.432] (II) LoadModule: "libinput" [ 66.433] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so [ 66.473] (II) Module libinput: vendor="X.Org Foundation" [ 66.474] compiled for 1.20.4, module version = 0.29.0 [ 66.474] Module class: X.Org XInput Driver [ 66.474] ABI class: X.Org XInput driver, version 24.1 [ 66.474] (II) Using input driver 'libinput' for 'HID 05ac:0256' [ 66.474] (**) HID 05ac:0256: always reports core events [ 66.474] (**) Option "Device" "/dev/input/event2" [ 66.474] (**) Option "_source" "server/udev" [ 66.557] (II) event2 - HID 05ac:0256: is tagged by udev as: Keyboard [ 66.558] (II) event2 - HID 05ac:0256: device is a keyboard [ 66.559] (II) event2 - HID 05ac:0256: device removed [ 66.584] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.0/0003:05AC:0256.0001/input/input2/event2" [ 66.585] (II) XINPUT: Adding extended input device "HID 05ac:0256" (type: KEYBOARD, id 6) [ 66.585] (**) Option "xkb_model" "pc105" [ 66.585] (**) Option "xkb_layout" "us" [ 66.606] (II) event2 - HID 05ac:0256: is tagged by udev as: Keyboard [ 66.607] (II) event2 - HID 05ac:0256: device is a keyboard [ 66.618] (II) config/udev: Adding input device HID 05ac:0256 Mouse (/dev/input/event3) [ 66.619] (**) HID 05ac:0256 Mouse: Applying InputClass "libinput pointer catchall" [ 66.619] (II) Using input driver 'libinput' for 'HID 05ac:0256 Mouse' [ 66.619] (**) HID 05ac:0256 Mouse: always reports core events [ 66.619] (**) Option "Device" "/dev/input/event3" [ 66.619] (**) Option "_source" "server/udev" [ 66.639] (II) event3 - HID 05ac:0256 Mouse: is tagged by udev as: Mouse [ 66.641] (II) event3 - HID 05ac:0256 Mouse: device is a pointer [ 66.643] (II) event3 - HID 05ac:0256 Mouse: device removed [ 66.673] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input3/event3" [ 66.673] (II) XINPUT: Adding extended input device "HID 05ac:0256 Mouse" (type: MOUSE, id 7) [ 66.674] (**) Option "AccelerationScheme" "none" [ 66.674] (**) HID 05ac:0256 Mouse: (accel) selected scheme none/0 [ 66.675] (**) HID 05ac:0256 Mouse: (accel) acceleration factor: 2.000 [ 66.675] (**) HID 05ac:0256 Mouse: (accel) acceleration threshold: 4 [ 66.694] (II) event3 - HID 05ac:0256 Mouse: is tagged by udev as: Mouse [ 66.695] (II) event3 - HID 05ac:0256 Mouse: device is a pointer [ 66.707] (II) config/udev: Adding input device HID 05ac:0256 Consumer Control (/dev/input/event4) [ 66.707] (**) HID 05ac:0256 Consumer Control: Applying InputClass "libinput keyboard catchall" [ 66.708] (II) Using input driver 'libinput' for 'HID 05ac:0256 Consumer Control' [ 66.708] (**) HID 05ac:0256 Consumer Control: always reports core events [ 66.708] (**) Option "Device" "/dev/input/event4" [ 66.708] (**) Option "_source" "server/udev" [ 66.728] (II) event4 - HID 05ac:0256 Consumer Control: is tagged by udev as: Keyboard [ 66.729] (II) event4 - HID 05ac:0256 Consumer Control: device is a keyboard [ 66.731] (II) event4 - HID 05ac:0256 Consumer Control: device removed [ 66.744] (II) libinput: HID 05ac:0256 Consumer Control: needs a virtual subdevice [ 66.744] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input4/event4" [ 66.745] (II) XINPUT: Adding extended input device "HID 05ac:0256 Consumer Control" (type: MOUSE, id 8) [ 66.745] (**) Option "AccelerationScheme" "none" [ 66.745] (**) HID 05ac:0256 Consumer Control: (accel) selected scheme none/0 [ 66.745] (**) HID 05ac:0256 Consumer Control: (accel) acceleration factor: 2.000 [ 66.746] (**) HID 05ac:0256 Consumer Control: (accel) acceleration threshold: 4 [ 66.765] (II) event4 - HID 05ac:0256 Consumer Control: is tagged by udev as: Keyboard [ 66.766] (II) event4 - HID 05ac:0256 Consumer Control: device is a keyboard [ 66.777] (II) config/udev: Adding input device HID 05ac:0256 System Control (/dev/input/event5) [ 66.777] (**) HID 05ac:0256 System Control: Applying InputClass "libinput keyboard catchall" [ 66.777] (II) Using input driver 'libinput' for 'HID 05ac:0256 System Control' [ 66.778] (**) HID 05ac:0256 System Control: always reports core events [ 66.778] (**) Option "Device" "/dev/input/event5" [ 66.778] (**) Option "_source" "server/udev" [ 66.799] (II) event5 - HID 05ac:0256 System Control: is tagged by udev as: Keyboard [ 66.801] (II) event5 - HID 05ac:0256 System Control: device is a keyboard [ 66.802] (II) event5 - HID 05ac:0256 System Control: device removed [ 66.816] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input5/event5" [ 66.816] (II) XINPUT: Adding extended input device "HID 05ac:0256 System Control" (type: KEYBOARD, id 9) [ 66.816] (**) Option "xkb_model" "pc105" [ 66.817] (**) Option "xkb_layout" "us" [ 66.837] (II) event5 - HID 05ac:0256 System Control: is tagged by udev as: Keyboard [ 66.838] (II) event5 - HID 05ac:0256 System Control: device is a keyboard [ 66.846] (II) config/udev: Adding input device sunxi-ir (/dev/input/event1) [ 66.847] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 66.847] (II) Using input driver 'libinput' for 'sunxi-ir' [ 66.847] (**) sunxi-ir: always reports core events [ 66.847] (**) Option "Device" "/dev/input/event1" [ 66.847] (**) Option "_source" "server/udev" [ 66.860] (II) event1 - sunxi-ir: is tagged by udev as: Keyboard Pointingstick [ 66.862] (II) event1 - sunxi-ir: device is a pointer [ 66.863] (II) event1 - sunxi-ir: device is a keyboard [ 66.866] (II) event1 - sunxi-ir: device removed [ 66.896] (II) libinput: sunxi-ir: needs a virtual subdevice [ 66.896] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c21800.ir/rc/rc0/input1/event1" [ 66.896] (II) XINPUT: Adding extended input device "sunxi-ir" (type: MOUSE, id 10) [ 66.897] (**) Option "AccelerationScheme" "none" [ 66.897] (**) sunxi-ir: (accel) selected scheme none/0 [ 66.898] (**) sunxi-ir: (accel) acceleration factor: 2.000 [ 66.898] (**) sunxi-ir: (accel) acceleration threshold: 4 [ 66.910] (II) event1 - sunxi-ir: is tagged by udev as: Keyboard Pointingstick [ 66.913] (II) event1 - sunxi-ir: device is a pointer [ 66.913] (II) event1 - sunxi-ir: device is a keyboard [ 66.925] (II) config/udev: Adding input device axp20x-pek (/dev/input/event0) [ 66.926] (**) axp20x-pek: Applying InputClass "libinput keyboard catchall" [ 66.926] (II) Using input driver 'libinput' for 'axp20x-pek' [ 66.926] (**) axp20x-pek: always reports core events [ 66.926] (**) Option "Device" "/dev/input/event0" [ 66.926] (**) Option "_source" "server/udev" [ 66.946] (II) event0 - axp20x-pek: is tagged by udev as: Keyboard [ 66.947] (II) event0 - axp20x-pek: device is a keyboard [ 66.950] (II) event0 - axp20x-pek: device removed [ 66.968] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c2ac00.i2c/i2c-1/1-0034/axp20x-pek/input/input0/event0" [ 66.968] (II) XINPUT: Adding extended input device "axp20x-pek" (type: KEYBOARD, id 11) [ 66.968] (**) Option "xkb_model" "pc105" [ 66.968] (**) Option "xkb_layout" "us" [ 66.987] (II) event0 - axp20x-pek: is tagged by udev as: Keyboard [ 66.988] (II) event0 - axp20x-pek: device is a keyboard [ 67.054] (**) HID 05ac:0256 Consumer Control: Applying InputClass "libinput keyboard catchall" [ 67.055] (II) Using input driver 'libinput' for 'HID 05ac:0256 Consumer Control' [ 67.055] (**) HID 05ac:0256 Consumer Control: always reports core events [ 67.055] (**) Option "Device" "/dev/input/event4" [ 67.055] (**) Option "_source" "_driver/libinput" [ 67.055] (II) libinput: HID 05ac:0256 Consumer Control: is a virtual subdevice [ 67.055] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input4/event4" [ 67.055] (II) XINPUT: Adding extended input device "HID 05ac:0256 Consumer Control" (type: KEYBOARD, id 12) [ 67.056] (**) Option "xkb_model" "pc105" [ 67.056] (**) Option "xkb_layout" "us" [ 67.057] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 67.058] (II) Using input driver 'libinput' for 'sunxi-ir' [ 67.058] (**) sunxi-ir: always reports core events [ 67.058] (**) Option "Device" "/dev/input/event1" [ 67.058] (**) Option "_source" "_driver/libinput" [ 67.058] (II) libinput: sunxi-ir: is a virtual subdevice [ 67.058] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c21800.ir/rc/rc0/input1/event1" [ 67.058] (II) XINPUT: Adding extended input device "sunxi-ir" (type: KEYBOARD, id 13) [ 67.058] (**) Option "xkb_model" "pc105" [ 67.059] (**) Option "xkb_layout" "us" [ 78.675] (II) modeset(0): Disabling kernel dirty updates, not required. Armbian 21.08.3 Focal with Linux 5.10.60-sunxi (latest upgrade) nothing changes armbianmonitor -u http://ix.io/3E9J journalctl -p 3 -xe -- Logs begin at Sat 2021-11-06 00:07:50 UTC, end at Sat 2021-11-06 00:25:01 UTC. -- Nov 06 00:07:50 cubietruck kernel: sun4i-drm display-engine: attempt to add DMA range to existing map Nov 06 00:07:50 cubietruck kernel: debugfs: Directory '1c22c00.codec' with parent 'sun4i-codec' already present! Nov 06 00:07:50 cubietruck kernel: phy id_det change to device Nov 06 00:07:50 cubietruck kernel: Bluetooth: hci0: BCM: firmware Patch file not found, tried: Nov 06 00:07:50 cubietruck kernel: Bluetooth: hci0: BCM: 'brcm/BCM20702A1.hcd' Nov 06 00:07:50 cubietruck kernel: Bluetooth: hci0: BCM: 'brcm/BCM.hcd' Nov 06 00:08:21 cubietruck kernel: ieee80211 phy0: brcmf_p2p_create_p2pdev: timeout occurred Nov 06 00:08:21 cubietruck kernel: ieee80211 phy0: brcmf_cfg80211_add_iface: add iface p2p-dev-wlan0 type 10 failed: err=-5 Nov 06 00:08:21 cubietruck wpa_supplicant[1720]: Failed to create interface p2p-dev-wlan0: -5 (Input/output error) Nov 06 00:08:21 cubietruck wpa_supplicant[1720]: nl80211: Failed to create a P2P Device interface p2p-dev-wlan0 Nov 06 00:08:24 cubietruck kernel: lima 1c40000.gpu: mmu page fault at 0x28fc2c0 from bus id 0 of type read on gpmmu Nov 06 00:08:25 cubietruck kernel: lima 1c40000.gpu: gp task error int_state=0 status=a Nov 06 00:08:25 cubietruck lightdm[1948]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory Nov 06 00:08:25 cubietruck lightdm[1948]: PAM adding faulty module: pam_kwallet.so Nov 06 00:08:25 cubietruck lightdm[1948]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory Nov 06 00:08:25 cubietruck lightdm[1948]: PAM adding faulty module: pam_kwallet5.so Nov 06 00:08:36 cubietruck lightdm[2422]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory Nov 06 00:08:36 cubietruck lightdm[2422]: PAM adding faulty module: pam_kwallet.so Nov 06 00:08:36 cubietruck lightdm[2422]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory Nov 06 00:08:36 cubietruck lightdm[2422]: PAM adding faulty module: pam_kwallet5.so Nov 06 00:14:36 cubietruck bluetoothd[1620]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98) Nov 06 00:14:36 cubietruck bluetoothd[1620]: RFCOMM server failed for :1.88/Profile/HSPHSProfile/00001108-0000-1000-8000-00805f9b34fb: rfcomm_bind: Address already in use (98) cat /var/log/Xorg.0.log Скрытый текст [ 53.125] X.Org X Server 1.20.11 X Protocol Version 11, Revision 0 [ 53.126] Build Operating System: linux Ubuntu [ 53.126] Current Operating System: Linux cubietruck 5.10.60-sunxi #21.08.2 SMP Tue Sep 14 16:28:44 UTC 2021 armv7l [ 53.126] Kernel command line: root=UUID=68b481b7-93d9-4f63-9190-cae97742a56f rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=e25f374d-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 [ 53.126] Build Date: 06 July 2021 10:17:51AM [ 53.126] xorg-server 2:1.20.11-1ubuntu1~20.04.2 (For technical support please see http://www.ubuntu.com/support) [ 53.126] Current version of pixman: 0.38.4 [ 53.127] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 53.127] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 53.127] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Nov 6 00:08:19 2021 [ 53.183] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 53.183] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 53.192] (==) No Layout section. Using the first Screen section. [ 53.193] (==) No screen section available. Using defaults. [ 53.193] (**) |-->Screen "Default Screen Section" (0) [ 53.193] (**) | |-->Monitor "<default monitor>" [ 53.196] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 53.196] (**) Option "BlankTime" "0" [ 53.196] (**) Option "StandbyTime" "0" [ 53.196] (**) Option "SuspendTime" "0" [ 53.196] (**) Option "OffTime" "0" [ 53.197] (==) Automatically adding devices [ 53.197] (==) Automatically enabling devices [ 53.197] (==) Automatically adding GPU devices [ 53.197] (==) Automatically binding GPU devices [ 53.197] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 53.227] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 53.228] Entry deleted from font path. [ 53.252] (==) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, built-ins [ 53.252] (==) ModulePath set to "/usr/lib/xorg/modules" [ 53.252] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 53.253] (II) Loader magic: 0x5b4008 [ 53.253] (II) Module ABI versions: [ 53.253] X.Org ANSI C Emulation: 0.4 [ 53.253] X.Org Video Driver: 24.1 [ 53.253] X.Org XInput driver : 24.1 [ 53.253] X.Org Server Extension : 10.0 [ 53.272] (++) using VT number 7 [ 53.272] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 53.291] (II) xfree86: Adding drm device (/dev/dri/card0) [ 53.319] (II) xfree86: Adding drm device (/dev/dri/card1) [ 53.324] (II) no primary bus or device found [ 53.325] falling back to /sys/devices/platform/display-engine/drm/card0 [ 53.325] (II) LoadModule: "glx" [ 53.332] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 53.385] (II) Module glx: vendor="X.Org Foundation" [ 53.385] compiled for 1.20.11, module version = 1.0.0 [ 53.385] ABI class: X.Org Server Extension, version 10.0 [ 53.386] (==) Matched modesetting as autoconfigured driver 0 [ 53.386] (==) Matched fbdev as autoconfigured driver 1 [ 53.386] (==) Assigned the driver to the xf86ConfigLayout [ 53.386] (II) LoadModule: "modesetting" [ 53.404] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so [ 53.407] (II) Module modesetting: vendor="X.Org Foundation" [ 53.407] compiled for 1.20.11, module version = 1.20.11 [ 53.408] Module class: X.Org Video Driver [ 53.408] ABI class: X.Org Video Driver, version 24.1 [ 53.408] (II) LoadModule: "fbdev" [ 53.409] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 53.418] (II) Module fbdev: vendor="X.Org Foundation" [ 53.418] compiled for 1.20.1, module version = 0.5.0 [ 53.418] Module class: X.Org Video Driver [ 53.418] ABI class: X.Org Video Driver, version 24.0 [ 53.418] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 53.418] (II) FBDEV: driver for framebuffer: fbdev [ 53.505] (II) modeset(0): using drv /dev/dri/card0 [ 53.505] (WW) Falling back to old probe method for fbdev [ 53.506] (II) Loading sub module "fbdevhw" [ 53.506] (II) LoadModule: "fbdevhw" [ 53.506] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 53.508] (II) Module fbdevhw: vendor="X.Org Foundation" [ 53.508] compiled for 1.20.11, module version = 0.0.2 [ 53.508] ABI class: X.Org Video Driver, version 24.1 [ 53.575] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support [ 53.577] (II) modeset(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 53.577] (==) modeset(0): Depth 24, (==) framebuffer bpp 32 [ 53.577] (==) modeset(0): RGB weight 888 [ 53.578] (==) modeset(0): Default visual is TrueColor [ 53.578] (II) Loading sub module "glamoregl" [ 53.578] (II) LoadModule: "glamoregl" [ 53.579] (II) Loading /usr/lib/xorg/modules/libglamoregl.so [ 53.754] (II) Module glamoregl: vendor="X.Org Foundation" [ 53.754] compiled for 1.20.11, module version = 1.0.1 [ 53.755] ABI class: X.Org ANSI C Emulation, version 0.4 [ 56.018] (II) modeset(0): glamor X acceleration enabled on Mali400 [ 56.018] (II) modeset(0): glamor initialized [ 56.086] (II) modeset(0): Output HDMI-1 has no monitor section [ 56.129] (II) modeset(0): EDID for output HDMI-1 [ 56.129] (II) modeset(0): Manufacturer: AOC Model: 2716 Serial#: 16843009 [ 56.130] (II) modeset(0): Year: 2016 Week: 0 [ 56.130] (II) modeset(0): EDID Version: 1.3 [ 56.130] (II) modeset(0): Digital Display Input [ 56.130] (II) modeset(0): Max Image Size [cm]: horiz.: 60 vert.: 34 [ 56.130] (II) modeset(0): Gamma: 2.20 [ 56.130] (II) modeset(0): No DPMS capabilities specified [ 56.130] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 [ 56.130] (II) modeset(0): Default color space is primary color space [ 56.130] (II) modeset(0): First detailed timing is preferred mode [ 56.130] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600 [ 56.130] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329 [ 56.130] (II) modeset(0): Supported established timings: [ 56.130] (II) modeset(0): 640x480@60Hz [ 56.130] (II) modeset(0): 800x600@60Hz [ 56.130] (II) modeset(0): 1024x768@60Hz [ 56.130] (II) modeset(0): Manufacturer's mask: 0 [ 56.131] (II) modeset(0): Supported detailed timing: [ 56.131] (II) modeset(0): clock: 148.5 MHz Image Size: 596 x 335 mm [ 56.131] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 56.131] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0 [ 56.131] (II) modeset(0): Serial No: [ 56.131] (II) modeset(0): Ranges: V min: 24 V max: 60 Hz, H min: 30 H max: 140 kHz, PixClock max 305 MHz [ 56.131] (II) modeset(0): Monitor name: AG271UG [ 56.131] (II) modeset(0): Number of EDID sections to follow: 1 [ 56.131] (II) modeset(0): EDID (in hex): [ 56.132] (II) modeset(0): 00ffffffffffff0005e3162701010101 [ 56.132] (II) modeset(0): 001a0103803c22780eee91a3544c9926 [ 56.133] (II) modeset(0): 0f505421080001010101010101010101 [ 56.133] (II) modeset(0): 010101010101023a801871382d40582c [ 56.133] (II) modeset(0): 4500544f2100001e000000ff000a2020 [ 56.133] (II) modeset(0): 20202020202020202020000000fd0018 [ 56.133] (II) modeset(0): 3c1e8c1e010a202020202020000000fc [ 56.133] (II) modeset(0): 00414732373155470a20202020200187 [ 56.133] (II) modeset(0): 020323c149901f04130312015d5f2309 [ 56.133] (II) modeset(0): 0701830100006c030c001000003c2010 [ 56.133] (II) modeset(0): 40030100000000000000000000000000 [ 56.133] (II) modeset(0): 00000000000000000000000000000000 [ 56.133] (II) modeset(0): 00000000000000000000000000000000 [ 56.133] (II) modeset(0): 00000000000000000000000000000000 [ 56.133] (II) modeset(0): 00000000000000000000000000000000 [ 56.133] (II) modeset(0): 00000000000000000000000000000043 [ 56.134] (--) modeset(0): HDMI max TMDS frequency 300000KHz [ 56.134] (II) modeset(0): Printing probed modes for output HDMI-1 [ 56.134] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 56.134] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 56.134] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e) [ 56.134] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 56.134] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 56.134] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 56.135] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 56.135] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 56.135] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 56.135] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 56.135] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 56.135] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 56.135] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 56.135] (II) modeset(0): Output HDMI-1 connected [ 56.135] (II) modeset(0): Using exact sizes for initial modes [ 56.135] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0 [ 56.135] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0) [ 56.135] (==) modeset(0): DPI set to (96, 96) [ 56.135] (II) Loading sub module "fb" [ 56.136] (II) LoadModule: "fb" [ 56.136] (II) Loading /usr/lib/xorg/modules/libfb.so [ 56.146] (II) Module fb: vendor="X.Org Foundation" [ 56.146] compiled for 1.20.11, module version = 1.0.0 [ 56.146] ABI class: X.Org ANSI C Emulation, version 0.4 [ 56.146] (II) UnloadModule: "fbdev" [ 56.146] (II) Unloading fbdev [ 56.147] (II) UnloadSubModule: "fbdevhw" [ 56.147] (II) Unloading fbdevhw [ 56.334] (==) modeset(0): Backing store enabled [ 56.335] (==) modeset(0): Silken mouse enabled [ 56.339] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc. [ 56.340] (==) modeset(0): DPMS enabled [ 56.341] (II) modeset(0): [DRI2] Setup complete [ 56.341] (II) modeset(0): [DRI2] DRI driver: sun4i-drm [ 56.341] (II) modeset(0): [DRI2] VDPAU driver: sun4i-drm [ 56.341] (II) Initializing extension Generic Event Extension [ 56.343] (II) Initializing extension SHAPE [ 56.344] (II) Initializing extension MIT-SHM [ 56.346] (II) Initializing extension XInputExtension [ 56.347] (II) Initializing extension XTEST [ 56.349] (II) Initializing extension BIG-REQUESTS [ 56.351] (II) Initializing extension SYNC [ 56.352] (II) Initializing extension XKEYBOARD [ 56.354] (II) Initializing extension XC-MISC [ 56.355] (II) Initializing extension SECURITY [ 56.357] (II) Initializing extension XFIXES [ 56.358] (II) Initializing extension RENDER [ 56.359] (II) Initializing extension RANDR [ 56.362] (II) Initializing extension COMPOSITE [ 56.363] (II) Initializing extension DAMAGE [ 56.365] (II) Initializing extension MIT-SCREEN-SAVER [ 56.366] (II) Initializing extension DOUBLE-BUFFER [ 56.368] (II) Initializing extension RECORD [ 56.369] (II) Initializing extension DPMS [ 56.370] (II) Initializing extension Present [ 56.372] (II) Initializing extension DRI3 [ 56.373] (II) Initializing extension X-Resource [ 56.374] (II) Initializing extension XVideo [ 56.376] (II) Initializing extension XVideo-MotionCompensation [ 56.376] (II) Initializing extension SELinux [ 56.376] (II) SELinux: Disabled on system [ 56.376] (II) Initializing extension GLX [ 56.378] (EE) AIGLX error: sun4i-drm does not export required DRI extension [ 56.499] (II) IGLX: Loaded and initialized swrast [ 56.500] (II) GLX: Initialized DRISWRAST GL provider for screen 0 [ 56.500] (II) Initializing extension XFree86-VidModeExtension [ 56.501] (II) Initializing extension XFree86-DGA [ 56.503] (II) Initializing extension XFree86-DRI [ 56.503] (II) Initializing extension DRI2 [ 56.513] (II) modeset(0): Damage tracking initialized [ 56.513] (II) modeset(0): Setting screen physical size to 508 x 285 [ 57.046] (II) config/udev: Adding input device HID 05ac:0256 (/dev/input/event2) [ 57.046] (**) HID 05ac:0256: Applying InputClass "libinput keyboard catchall" [ 57.046] (II) LoadModule: "libinput" [ 57.047] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so [ 57.072] (II) Module libinput: vendor="X.Org Foundation" [ 57.072] compiled for 1.20.4, module version = 0.29.0 [ 57.072] Module class: X.Org XInput Driver [ 57.072] ABI class: X.Org XInput driver, version 24.1 [ 57.072] (II) Using input driver 'libinput' for 'HID 05ac:0256' [ 57.072] (**) HID 05ac:0256: always reports core events [ 57.073] (**) Option "Device" "/dev/input/event2" [ 57.073] (**) Option "_source" "server/udev" [ 57.123] (II) event2 - HID 05ac:0256: is tagged by udev as: Keyboard [ 57.124] (II) event2 - HID 05ac:0256: device is a keyboard [ 57.127] (II) event2 - HID 05ac:0256: device removed [ 57.144] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.0/0003:05AC:0256.0001/input/input2/event2" [ 57.145] (II) XINPUT: Adding extended input device "HID 05ac:0256" (type: KEYBOARD, id 6) [ 57.145] (**) Option "xkb_model" "pc105" [ 57.145] (**) Option "xkb_layout" "us" [ 57.166] (II) event2 - HID 05ac:0256: is tagged by udev as: Keyboard [ 57.167] (II) event2 - HID 05ac:0256: device is a keyboard [ 57.179] (II) config/udev: Adding input device HID 05ac:0256 Mouse (/dev/input/event3) [ 57.179] (**) HID 05ac:0256 Mouse: Applying InputClass "libinput pointer catchall" [ 57.179] (II) Using input driver 'libinput' for 'HID 05ac:0256 Mouse' [ 57.179] (**) HID 05ac:0256 Mouse: always reports core events [ 57.180] (**) Option "Device" "/dev/input/event3" [ 57.180] (**) Option "_source" "server/udev" [ 57.200] (II) event3 - HID 05ac:0256 Mouse: is tagged by udev as: Mouse [ 57.202] (II) event3 - HID 05ac:0256 Mouse: device is a pointer [ 57.204] (II) event3 - HID 05ac:0256 Mouse: device removed [ 57.240] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input3/event3" [ 57.241] (II) XINPUT: Adding extended input device "HID 05ac:0256 Mouse" (type: MOUSE, id 7) [ 57.242] (**) Option "AccelerationScheme" "none" [ 57.242] (**) HID 05ac:0256 Mouse: (accel) selected scheme none/0 [ 57.242] (**) HID 05ac:0256 Mouse: (accel) acceleration factor: 2.000 [ 57.242] (**) HID 05ac:0256 Mouse: (accel) acceleration threshold: 4 [ 57.262] (II) event3 - HID 05ac:0256 Mouse: is tagged by udev as: Mouse [ 57.263] (II) event3 - HID 05ac:0256 Mouse: device is a pointer [ 57.291] (II) config/udev: Adding input device HID 05ac:0256 Consumer Control (/dev/input/event4) [ 57.291] (**) HID 05ac:0256 Consumer Control: Applying InputClass "libinput keyboard catchall" [ 57.292] (II) Using input driver 'libinput' for 'HID 05ac:0256 Consumer Control' [ 57.292] (**) HID 05ac:0256 Consumer Control: always reports core events [ 57.292] (**) Option "Device" "/dev/input/event4" [ 57.292] (**) Option "_source" "server/udev" [ 57.311] (II) event4 - HID 05ac:0256 Consumer Control: is tagged by udev as: Keyboard [ 57.313] (II) event4 - HID 05ac:0256 Consumer Control: device is a keyboard [ 57.314] (II) event4 - HID 05ac:0256 Consumer Control: device removed [ 57.328] (II) libinput: HID 05ac:0256 Consumer Control: needs a virtual subdevice [ 57.328] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input4/event4" [ 57.329] (II) XINPUT: Adding extended input device "HID 05ac:0256 Consumer Control" (type: MOUSE, id 8) [ 57.329] (**) Option "AccelerationScheme" "none" [ 57.329] (**) HID 05ac:0256 Consumer Control: (accel) selected scheme none/0 [ 57.329] (**) HID 05ac:0256 Consumer Control: (accel) acceleration factor: 2.000 [ 57.329] (**) HID 05ac:0256 Consumer Control: (accel) acceleration threshold: 4 [ 57.348] (II) event4 - HID 05ac:0256 Consumer Control: is tagged by udev as: Keyboard [ 57.349] (II) event4 - HID 05ac:0256 Consumer Control: device is a keyboard [ 57.360] (II) config/udev: Adding input device HID 05ac:0256 System Control (/dev/input/event5) [ 57.360] (**) HID 05ac:0256 System Control: Applying InputClass "libinput keyboard catchall" [ 57.360] (II) Using input driver 'libinput' for 'HID 05ac:0256 System Control' [ 57.360] (**) HID 05ac:0256 System Control: always reports core events [ 57.361] (**) Option "Device" "/dev/input/event5" [ 57.361] (**) Option "_source" "server/udev" [ 57.381] (II) event5 - HID 05ac:0256 System Control: is tagged by udev as: Keyboard [ 57.382] (II) event5 - HID 05ac:0256 System Control: device is a keyboard [ 57.383] (II) event5 - HID 05ac:0256 System Control: device removed [ 57.396] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input5/event5" [ 57.396] (II) XINPUT: Adding extended input device "HID 05ac:0256 System Control" (type: KEYBOARD, id 9) [ 57.396] (**) Option "xkb_model" "pc105" [ 57.396] (**) Option "xkb_layout" "us" [ 57.422] (II) event5 - HID 05ac:0256 System Control: is tagged by udev as: Keyboard [ 57.423] (II) event5 - HID 05ac:0256 System Control: device is a keyboard [ 57.431] (II) config/udev: Adding input device sunxi-ir (/dev/input/event1) [ 57.432] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 57.432] (II) Using input driver 'libinput' for 'sunxi-ir' [ 57.432] (**) sunxi-ir: always reports core events [ 57.432] (**) Option "Device" "/dev/input/event1" [ 57.432] (**) Option "_source" "server/udev" [ 57.445] (II) event1 - sunxi-ir: is tagged by udev as: Keyboard Pointingstick [ 57.448] (II) event1 - sunxi-ir: device is a pointer [ 57.448] (II) event1 - sunxi-ir: device is a keyboard [ 57.451] (II) event1 - sunxi-ir: device removed [ 57.488] (II) libinput: sunxi-ir: needs a virtual subdevice [ 57.488] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c21800.ir/rc/rc0/input1/event1" [ 57.488] (II) XINPUT: Adding extended input device "sunxi-ir" (type: MOUSE, id 10) [ 57.489] (**) Option "AccelerationScheme" "none" [ 57.490] (**) sunxi-ir: (accel) selected scheme none/0 [ 57.490] (**) sunxi-ir: (accel) acceleration factor: 2.000 [ 57.490] (**) sunxi-ir: (accel) acceleration threshold: 4 [ 57.502] (II) event1 - sunxi-ir: is tagged by udev as: Keyboard Pointingstick [ 57.505] (II) event1 - sunxi-ir: device is a pointer [ 57.505] (II) event1 - sunxi-ir: device is a keyboard [ 57.517] (II) config/udev: Adding input device axp20x-pek (/dev/input/event0) [ 57.518] (**) axp20x-pek: Applying InputClass "libinput keyboard catchall" [ 57.518] (II) Using input driver 'libinput' for 'axp20x-pek' [ 57.518] (**) axp20x-pek: always reports core events [ 57.518] (**) Option "Device" "/dev/input/event0" [ 57.518] (**) Option "_source" "server/udev" [ 57.536] (II) event0 - axp20x-pek: is tagged by udev as: Keyboard [ 57.537] (II) event0 - axp20x-pek: device is a keyboard [ 57.540] (II) event0 - axp20x-pek: device removed [ 57.560] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c2ac00.i2c/i2c-1/1-0034/axp20x-pek/input/input0/event0" [ 57.560] (II) XINPUT: Adding extended input device "axp20x-pek" (type: KEYBOARD, id 11) [ 57.560] (**) Option "xkb_model" "pc105" [ 57.560] (**) Option "xkb_layout" "us" [ 57.579] (II) event0 - axp20x-pek: is tagged by udev as: Keyboard [ 57.580] (II) event0 - axp20x-pek: device is a keyboard [ 57.659] (**) HID 05ac:0256 Consumer Control: Applying InputClass "libinput keyboard catchall" [ 57.659] (II) Using input driver 'libinput' for 'HID 05ac:0256 Consumer Control' [ 57.659] (**) HID 05ac:0256 Consumer Control: always reports core events [ 57.659] (**) Option "Device" "/dev/input/event4" [ 57.659] (**) Option "_source" "_driver/libinput" [ 57.659] (II) libinput: HID 05ac:0256 Consumer Control: is a virtual subdevice [ 57.692] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input4/event4" [ 57.692] (II) XINPUT: Adding extended input device "HID 05ac:0256 Consumer Control" (type: KEYBOARD, id 12) [ 57.692] (**) Option "xkb_model" "pc105" [ 57.692] (**) Option "xkb_layout" "us" [ 57.693] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 57.694] (II) Using input driver 'libinput' for 'sunxi-ir' [ 57.694] (**) sunxi-ir: always reports core events [ 57.694] (**) Option "Device" "/dev/input/event1" [ 57.694] (**) Option "_source" "_driver/libinput" [ 57.694] (II) libinput: sunxi-ir: is a virtual subdevice [ 57.694] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c21800.ir/rc/rc0/input1/event1" [ 57.694] (II) XINPUT: Adding extended input device "sunxi-ir" (type: KEYBOARD, id 13) [ 57.694] (**) Option "xkb_model" "pc105" [ 57.694] (**) Option "xkb_layout" "us" [ 69.038] (II) modeset(0): Disabling kernel dirty updates, not required. 0 Quote Link to post Share on other sites More sharing options...
0 voka 2 Posted November 8, 2021 Author Share Posted November 8, 2021 I created PR: https://github.com/armbian/build/pull/3240 1 Quote Link to post Share on other sites More sharing options...
0 voka 2 Posted November 8, 2021 Author Share Posted November 8, 2021 07.11.2021 в 00:37, OLEGIM сказал: Guys, help. I installed the armbian 21.08.1 Focal XFCE base image and ran it. Video over HDMI shows black screen. After the update, nothing has changed. I tried several actions that were written on the forum, but nothing helped. What steps need to be taken to fix this? armbian 21.08.1 Focal XFCE armbianmonitor -u http://ix.io/3E9k journalctl -p 3 -xe -- Logs begin at Fri 2021-11-05 22:16:31 UTC, end at Fri 2021-11-05 22:25:01 UTC. -- Nov 05 22:16:31 cubietruck kernel: sun4i-drm display-engine: attempt to add DMA range to existing map Nov 05 22:16:31 cubietruck kernel: debugfs: Directory '1c22c00.codec' with parent 'sun4i-codec' already present! Nov 05 22:16:32 cubietruck kernel: phy id_det change to device Nov 05 22:16:32 cubietruck kernel: Bluetooth: hci0: BCM: firmware Patch file not found, tried: Nov 05 22:16:32 cubietruck kernel: Bluetooth: hci0: BCM: 'brcm/BCM20702A1.hcd' Nov 05 22:16:32 cubietruck kernel: Bluetooth: hci0: BCM: 'brcm/BCM.hcd' Nov 05 22:17:11 cubietruck kernel: ieee80211 phy0: brcmf_p2p_create_p2pdev: timeout occurred Nov 05 22:17:11 cubietruck kernel: ieee80211 phy0: brcmf_cfg80211_add_iface: add iface p2p-dev-wlan0 type 10 failed: err=-5 Nov 05 22:17:11 cubietruck wpa_supplicant[1651]: Failed to create interface p2p-dev-wlan0: -5 (Input/output error) Nov 05 22:17:11 cubietruck wpa_supplicant[1651]: nl80211: Failed to create a P2P Device interface p2p-dev-wlan0 Nov 05 22:17:15 cubietruck kernel: lima 1c40000.gpu: mmu page fault at 0x28fc340 from bus id 0 of type read on gpmmu Nov 05 22:17:15 cubietruck kernel: lima 1c40000.gpu: gp task error int_state=0 status=a Nov 05 22:17:16 cubietruck lightdm[1946]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory Nov 05 22:17:16 cubietruck lightdm[1946]: PAM adding faulty module: pam_kwallet.so Nov 05 22:17:16 cubietruck lightdm[1946]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory Nov 05 22:17:16 cubietruck lightdm[1946]: PAM adding faulty module: pam_kwallet5.so Nov 05 22:17:27 cubietruck lightdm[2018]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory Nov 05 22:17:27 cubietruck lightdm[2018]: PAM adding faulty module: pam_kwallet.so Nov 05 22:17:27 cubietruck lightdm[2018]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory Nov 05 22:17:27 cubietruck lightdm[2018]: PAM adding faulty module: pam_kwallet5.so Nov 05 22:21:38 cubietruck lightdm[2045]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory Nov 05 22:21:38 cubietruck lightdm[2045]: PAM adding faulty module: pam_kwallet.so Nov 05 22:21:38 cubietruck lightdm[2045]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory Nov 05 22:21:38 cubietruck lightdm[2045]: PAM adding faulty module: pam_kwallet5.so Nov 05 22:21:41 cubietruck lightdm[2047]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory Nov 05 22:21:41 cubietruck lightdm[2047]: PAM adding faulty module: pam_kwallet.so Nov 05 22:21:41 cubietruck lightdm[2047]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory Nov 05 22:21:41 cubietruck lightdm[2047]: PAM adding faulty module: pam_kwallet5.so Nov 05 22:21:58 cubietruck bluetoothd[1609]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98) Nov 05 22:21:58 cubietruck bluetoothd[1609]: RFCOMM server failed for :1.88/Profile/HSPHSProfile/00001108-0000-1000-8000-00805f9b34fb: rfcomm_bind: Address already in use (98) Xorg logs cat /var/log/Xorg.0.log Показать содержимое [ 60.941] X.Org X Server 1.20.11 X Protocol Version 11, Revision 0 [ 60.941] Build Operating System: linux Ubuntu [ 60.941] Current Operating System: Linux cubietruck 5.10.60-sunxi #21.08.1 SMP Wed Aug 25 18:19:32 UTC 2021 armv7l [ 60.941] Kernel command line: root=UUID=6013a5e8-5c4b-4aaa-bf84-e8ba72a01877 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=e25f374d-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 [ 60.942] Build Date: 06 July 2021 10:17:51AM [ 60.942] xorg-server 2:1.20.11-1ubuntu1~20.04.2 (For technical support please see http://www.ubuntu.com/support) [ 60.942] Current version of pixman: 0.38.4 [ 60.942] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 60.942] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 60.943] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Nov 5 22:30:16 2021 [ 61.080] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 61.081] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 61.140] (==) No Layout section. Using the first Screen section. [ 61.141] (==) No screen section available. Using defaults. [ 61.141] (**) |-->Screen "Default Screen Section" (0) [ 61.141] (**) | |-->Monitor "<default monitor>" [ 61.143] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 61.143] (**) Option "BlankTime" "0" [ 61.143] (**) Option "StandbyTime" "0" [ 61.143] (**) Option "SuspendTime" "0" [ 61.143] (**) Option "OffTime" "0" [ 61.143] (==) Automatically adding devices [ 61.144] (==) Automatically enabling devices [ 61.144] (==) Automatically adding GPU devices [ 61.144] (==) Automatically binding GPU devices [ 61.144] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 61.257] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 61.258] Entry deleted from font path. [ 61.336] (==) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, built-ins [ 61.339] (==) ModulePath set to "/usr/lib/xorg/modules" [ 61.339] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 61.339] (II) Loader magic: 0x584008 [ 61.339] (II) Module ABI versions: [ 61.339] X.Org ANSI C Emulation: 0.4 [ 61.339] X.Org Video Driver: 24.1 [ 61.339] X.Org XInput driver : 24.1 [ 61.339] X.Org Server Extension : 10.0 [ 61.345] (++) using VT number 7 [ 61.345] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 61.366] (II) xfree86: Adding drm device (/dev/dri/card0) [ 61.373] (II) xfree86: Adding drm device (/dev/dri/card1) [ 61.377] (II) no primary bus or device found [ 61.377] falling back to /sys/devices/platform/display-engine/drm/card0 [ 61.377] (II) LoadModule: "glx" [ 61.386] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 61.496] (II) Module glx: vendor="X.Org Foundation" [ 61.496] compiled for 1.20.11, module version = 1.0.0 [ 61.496] ABI class: X.Org Server Extension, version 10.0 [ 61.496] (==) Matched modesetting as autoconfigured driver 0 [ 61.497] (==) Matched fbdev as autoconfigured driver 1 [ 61.497] (==) Assigned the driver to the xf86ConfigLayout [ 61.497] (II) LoadModule: "modesetting" [ 61.497] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so [ 61.506] (II) Module modesetting: vendor="X.Org Foundation" [ 61.507] compiled for 1.20.11, module version = 1.20.11 [ 61.508] Module class: X.Org Video Driver [ 61.508] ABI class: X.Org Video Driver, version 24.1 [ 61.508] (II) LoadModule: "fbdev" [ 61.509] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 61.531] (II) Module fbdev: vendor="X.Org Foundation" [ 61.532] compiled for 1.20.1, module version = 0.5.0 [ 61.533] Module class: X.Org Video Driver [ 61.533] ABI class: X.Org Video Driver, version 24.0 [ 61.535] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 61.535] (II) FBDEV: driver for framebuffer: fbdev [ 61.601] (II) modeset(0): using drv /dev/dri/card0 [ 61.601] (WW) Falling back to old probe method for fbdev [ 61.601] (II) Loading sub module "fbdevhw" [ 61.602] (II) LoadModule: "fbdevhw" [ 61.602] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 61.610] (II) Module fbdevhw: vendor="X.Org Foundation" [ 61.611] compiled for 1.20.11, module version = 0.0.2 [ 61.611] ABI class: X.Org Video Driver, version 24.1 [ 61.657] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support [ 61.658] (II) modeset(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 61.658] (==) modeset(0): Depth 24, (==) framebuffer bpp 32 [ 61.658] (==) modeset(0): RGB weight 888 [ 61.658] (==) modeset(0): Default visual is TrueColor [ 61.659] (II) Loading sub module "glamoregl" [ 61.659] (II) LoadModule: "glamoregl" [ 61.659] (II) Loading /usr/lib/xorg/modules/libglamoregl.so [ 61.777] (II) Module glamoregl: vendor="X.Org Foundation" [ 61.777] compiled for 1.20.11, module version = 1.0.1 [ 61.777] ABI class: X.Org ANSI C Emulation, version 0.4 [ 65.210] (II) modeset(0): glamor X acceleration enabled on Mali400 [ 65.210] (II) modeset(0): glamor initialized [ 65.245] (II) modeset(0): Output HDMI-1 has no monitor section [ 65.276] (II) modeset(0): EDID for output HDMI-1 [ 65.276] (II) modeset(0): Manufacturer: AOC Model: 2716 Serial#: 16843009 [ 65.276] (II) modeset(0): Year: 2016 Week: 0 [ 65.276] (II) modeset(0): EDID Version: 1.3 [ 65.276] (II) modeset(0): Digital Display Input [ 65.277] (II) modeset(0): Max Image Size [cm]: horiz.: 60 vert.: 34 [ 65.277] (II) modeset(0): Gamma: 2.20 [ 65.277] (II) modeset(0): No DPMS capabilities specified [ 65.277] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 [ 65.277] (II) modeset(0): Default color space is primary color space [ 65.277] (II) modeset(0): First detailed timing is preferred mode [ 65.277] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600 [ 65.277] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329 [ 65.277] (II) modeset(0): Supported established timings: [ 65.277] (II) modeset(0): 640x480@60Hz [ 65.277] (II) modeset(0): 800x600@60Hz [ 65.277] (II) modeset(0): 1024x768@60Hz [ 65.277] (II) modeset(0): Manufacturer's mask: 0 [ 65.278] (II) modeset(0): Supported detailed timing: [ 65.278] (II) modeset(0): clock: 148.5 MHz Image Size: 596 x 335 mm [ 65.278] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 65.278] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0 [ 65.278] (II) modeset(0): Serial No: [ 65.278] (II) modeset(0): Ranges: V min: 24 V max: 60 Hz, H min: 30 H max: 140 kHz, PixClock max 305 MHz [ 65.278] (II) modeset(0): Monitor name: AG271UG [ 65.278] (II) modeset(0): Number of EDID sections to follow: 1 [ 65.278] (II) modeset(0): EDID (in hex): [ 65.278] (II) modeset(0): 00ffffffffffff0005e3162701010101 [ 65.279] (II) modeset(0): 001a0103803c22780eee91a3544c9926 [ 65.279] (II) modeset(0): 0f505421080001010101010101010101 [ 65.279] (II) modeset(0): 010101010101023a801871382d40582c [ 65.279] (II) modeset(0): 4500544f2100001e000000ff000a2020 [ 65.279] (II) modeset(0): 20202020202020202020000000fd0018 [ 65.279] (II) modeset(0): 3c1e8c1e010a202020202020000000fc [ 65.279] (II) modeset(0): 00414732373155470a20202020200187 [ 65.279] (II) modeset(0): 020323c149901f04130312015d5f2309 [ 65.279] (II) modeset(0): 0701830100006c030c001000003c2010 [ 65.279] (II) modeset(0): 40030100000000000000000000000000 [ 65.279] (II) modeset(0): 00000000000000000000000000000000 [ 65.279] (II) modeset(0): 00000000000000000000000000000000 [ 65.279] (II) modeset(0): 00000000000000000000000000000000 [ 65.280] (II) modeset(0): 00000000000000000000000000000000 [ 65.280] (II) modeset(0): 00000000000000000000000000000043 [ 65.280] (--) modeset(0): HDMI max TMDS frequency 300000KHz [ 65.280] (II) modeset(0): Printing probed modes for output HDMI-1 [ 65.281] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 65.281] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 65.281] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e) [ 65.281] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 65.281] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 65.281] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 65.281] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 65.281] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 65.281] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 65.281] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 65.281] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 65.281] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 65.281] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 65.281] (II) modeset(0): Output HDMI-1 connected [ 65.282] (II) modeset(0): Using exact sizes for initial modes [ 65.282] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0 [ 65.282] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0) [ 65.282] (==) modeset(0): DPI set to (96, 96) [ 65.282] (II) Loading sub module "fb" [ 65.282] (II) LoadModule: "fb" [ 65.283] (II) Loading /usr/lib/xorg/modules/libfb.so [ 65.290] (II) Module fb: vendor="X.Org Foundation" [ 65.291] compiled for 1.20.11, module version = 1.0.0 [ 65.291] ABI class: X.Org ANSI C Emulation, version 0.4 [ 65.291] (II) UnloadModule: "fbdev" [ 65.291] (II) Unloading fbdev [ 65.291] (II) UnloadSubModule: "fbdevhw" [ 65.292] (II) Unloading fbdevhw [ 65.597] (==) modeset(0): Backing store enabled [ 65.598] (==) modeset(0): Silken mouse enabled [ 65.618] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc. [ 65.619] (==) modeset(0): DPMS enabled [ 65.620] (II) modeset(0): [DRI2] Setup complete [ 65.621] (II) modeset(0): [DRI2] DRI driver: sun4i-drm [ 65.621] (II) modeset(0): [DRI2] VDPAU driver: sun4i-drm [ 65.621] (II) Initializing extension Generic Event Extension [ 65.623] (II) Initializing extension SHAPE [ 65.624] (II) Initializing extension MIT-SHM [ 65.626] (II) Initializing extension XInputExtension [ 65.628] (II) Initializing extension XTEST [ 65.629] (II) Initializing extension BIG-REQUESTS [ 65.631] (II) Initializing extension SYNC [ 65.632] (II) Initializing extension XKEYBOARD [ 65.634] (II) Initializing extension XC-MISC [ 65.635] (II) Initializing extension SECURITY [ 65.637] (II) Initializing extension XFIXES [ 65.638] (II) Initializing extension RENDER [ 65.640] (II) Initializing extension RANDR [ 65.643] (II) Initializing extension COMPOSITE [ 65.644] (II) Initializing extension DAMAGE [ 65.646] (II) Initializing extension MIT-SCREEN-SAVER [ 65.647] (II) Initializing extension DOUBLE-BUFFER [ 65.649] (II) Initializing extension RECORD [ 65.650] (II) Initializing extension DPMS [ 65.652] (II) Initializing extension Present [ 65.653] (II) Initializing extension DRI3 [ 65.655] (II) Initializing extension X-Resource [ 65.656] (II) Initializing extension XVideo [ 65.658] (II) Initializing extension XVideo-MotionCompensation [ 65.658] (II) Initializing extension SELinux [ 65.658] (II) SELinux: Disabled on system [ 65.658] (II) Initializing extension GLX [ 65.660] (EE) AIGLX error: sun4i-drm does not export required DRI extension [ 65.791] (II) IGLX: Loaded and initialized swrast [ 65.792] (II) GLX: Initialized DRISWRAST GL provider for screen 0 [ 65.792] (II) Initializing extension XFree86-VidModeExtension [ 65.793] (II) Initializing extension XFree86-DGA [ 65.795] (II) Initializing extension XFree86-DRI [ 65.795] (II) Initializing extension DRI2 [ 65.806] (II) modeset(0): Damage tracking initialized [ 65.806] (II) modeset(0): Setting screen physical size to 508 x 285 [ 66.431] (II) config/udev: Adding input device HID 05ac:0256 (/dev/input/event2) [ 66.432] (**) HID 05ac:0256: Applying InputClass "libinput keyboard catchall" [ 66.432] (II) LoadModule: "libinput" [ 66.433] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so [ 66.473] (II) Module libinput: vendor="X.Org Foundation" [ 66.474] compiled for 1.20.4, module version = 0.29.0 [ 66.474] Module class: X.Org XInput Driver [ 66.474] ABI class: X.Org XInput driver, version 24.1 [ 66.474] (II) Using input driver 'libinput' for 'HID 05ac:0256' [ 66.474] (**) HID 05ac:0256: always reports core events [ 66.474] (**) Option "Device" "/dev/input/event2" [ 66.474] (**) Option "_source" "server/udev" [ 66.557] (II) event2 - HID 05ac:0256: is tagged by udev as: Keyboard [ 66.558] (II) event2 - HID 05ac:0256: device is a keyboard [ 66.559] (II) event2 - HID 05ac:0256: device removed [ 66.584] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.0/0003:05AC:0256.0001/input/input2/event2" [ 66.585] (II) XINPUT: Adding extended input device "HID 05ac:0256" (type: KEYBOARD, id 6) [ 66.585] (**) Option "xkb_model" "pc105" [ 66.585] (**) Option "xkb_layout" "us" [ 66.606] (II) event2 - HID 05ac:0256: is tagged by udev as: Keyboard [ 66.607] (II) event2 - HID 05ac:0256: device is a keyboard [ 66.618] (II) config/udev: Adding input device HID 05ac:0256 Mouse (/dev/input/event3) [ 66.619] (**) HID 05ac:0256 Mouse: Applying InputClass "libinput pointer catchall" [ 66.619] (II) Using input driver 'libinput' for 'HID 05ac:0256 Mouse' [ 66.619] (**) HID 05ac:0256 Mouse: always reports core events [ 66.619] (**) Option "Device" "/dev/input/event3" [ 66.619] (**) Option "_source" "server/udev" [ 66.639] (II) event3 - HID 05ac:0256 Mouse: is tagged by udev as: Mouse [ 66.641] (II) event3 - HID 05ac:0256 Mouse: device is a pointer [ 66.643] (II) event3 - HID 05ac:0256 Mouse: device removed [ 66.673] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input3/event3" [ 66.673] (II) XINPUT: Adding extended input device "HID 05ac:0256 Mouse" (type: MOUSE, id 7) [ 66.674] (**) Option "AccelerationScheme" "none" [ 66.674] (**) HID 05ac:0256 Mouse: (accel) selected scheme none/0 [ 66.675] (**) HID 05ac:0256 Mouse: (accel) acceleration factor: 2.000 [ 66.675] (**) HID 05ac:0256 Mouse: (accel) acceleration threshold: 4 [ 66.694] (II) event3 - HID 05ac:0256 Mouse: is tagged by udev as: Mouse [ 66.695] (II) event3 - HID 05ac:0256 Mouse: device is a pointer [ 66.707] (II) config/udev: Adding input device HID 05ac:0256 Consumer Control (/dev/input/event4) [ 66.707] (**) HID 05ac:0256 Consumer Control: Applying InputClass "libinput keyboard catchall" [ 66.708] (II) Using input driver 'libinput' for 'HID 05ac:0256 Consumer Control' [ 66.708] (**) HID 05ac:0256 Consumer Control: always reports core events [ 66.708] (**) Option "Device" "/dev/input/event4" [ 66.708] (**) Option "_source" "server/udev" [ 66.728] (II) event4 - HID 05ac:0256 Consumer Control: is tagged by udev as: Keyboard [ 66.729] (II) event4 - HID 05ac:0256 Consumer Control: device is a keyboard [ 66.731] (II) event4 - HID 05ac:0256 Consumer Control: device removed [ 66.744] (II) libinput: HID 05ac:0256 Consumer Control: needs a virtual subdevice [ 66.744] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input4/event4" [ 66.745] (II) XINPUT: Adding extended input device "HID 05ac:0256 Consumer Control" (type: MOUSE, id 8) [ 66.745] (**) Option "AccelerationScheme" "none" [ 66.745] (**) HID 05ac:0256 Consumer Control: (accel) selected scheme none/0 [ 66.745] (**) HID 05ac:0256 Consumer Control: (accel) acceleration factor: 2.000 [ 66.746] (**) HID 05ac:0256 Consumer Control: (accel) acceleration threshold: 4 [ 66.765] (II) event4 - HID 05ac:0256 Consumer Control: is tagged by udev as: Keyboard [ 66.766] (II) event4 - HID 05ac:0256 Consumer Control: device is a keyboard [ 66.777] (II) config/udev: Adding input device HID 05ac:0256 System Control (/dev/input/event5) [ 66.777] (**) HID 05ac:0256 System Control: Applying InputClass "libinput keyboard catchall" [ 66.777] (II) Using input driver 'libinput' for 'HID 05ac:0256 System Control' [ 66.778] (**) HID 05ac:0256 System Control: always reports core events [ 66.778] (**) Option "Device" "/dev/input/event5" [ 66.778] (**) Option "_source" "server/udev" [ 66.799] (II) event5 - HID 05ac:0256 System Control: is tagged by udev as: Keyboard [ 66.801] (II) event5 - HID 05ac:0256 System Control: device is a keyboard [ 66.802] (II) event5 - HID 05ac:0256 System Control: device removed [ 66.816] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input5/event5" [ 66.816] (II) XINPUT: Adding extended input device "HID 05ac:0256 System Control" (type: KEYBOARD, id 9) [ 66.816] (**) Option "xkb_model" "pc105" [ 66.817] (**) Option "xkb_layout" "us" [ 66.837] (II) event5 - HID 05ac:0256 System Control: is tagged by udev as: Keyboard [ 66.838] (II) event5 - HID 05ac:0256 System Control: device is a keyboard [ 66.846] (II) config/udev: Adding input device sunxi-ir (/dev/input/event1) [ 66.847] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 66.847] (II) Using input driver 'libinput' for 'sunxi-ir' [ 66.847] (**) sunxi-ir: always reports core events [ 66.847] (**) Option "Device" "/dev/input/event1" [ 66.847] (**) Option "_source" "server/udev" [ 66.860] (II) event1 - sunxi-ir: is tagged by udev as: Keyboard Pointingstick [ 66.862] (II) event1 - sunxi-ir: device is a pointer [ 66.863] (II) event1 - sunxi-ir: device is a keyboard [ 66.866] (II) event1 - sunxi-ir: device removed [ 66.896] (II) libinput: sunxi-ir: needs a virtual subdevice [ 66.896] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c21800.ir/rc/rc0/input1/event1" [ 66.896] (II) XINPUT: Adding extended input device "sunxi-ir" (type: MOUSE, id 10) [ 66.897] (**) Option "AccelerationScheme" "none" [ 66.897] (**) sunxi-ir: (accel) selected scheme none/0 [ 66.898] (**) sunxi-ir: (accel) acceleration factor: 2.000 [ 66.898] (**) sunxi-ir: (accel) acceleration threshold: 4 [ 66.910] (II) event1 - sunxi-ir: is tagged by udev as: Keyboard Pointingstick [ 66.913] (II) event1 - sunxi-ir: device is a pointer [ 66.913] (II) event1 - sunxi-ir: device is a keyboard [ 66.925] (II) config/udev: Adding input device axp20x-pek (/dev/input/event0) [ 66.926] (**) axp20x-pek: Applying InputClass "libinput keyboard catchall" [ 66.926] (II) Using input driver 'libinput' for 'axp20x-pek' [ 66.926] (**) axp20x-pek: always reports core events [ 66.926] (**) Option "Device" "/dev/input/event0" [ 66.926] (**) Option "_source" "server/udev" [ 66.946] (II) event0 - axp20x-pek: is tagged by udev as: Keyboard [ 66.947] (II) event0 - axp20x-pek: device is a keyboard [ 66.950] (II) event0 - axp20x-pek: device removed [ 66.968] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c2ac00.i2c/i2c-1/1-0034/axp20x-pek/input/input0/event0" [ 66.968] (II) XINPUT: Adding extended input device "axp20x-pek" (type: KEYBOARD, id 11) [ 66.968] (**) Option "xkb_model" "pc105" [ 66.968] (**) Option "xkb_layout" "us" [ 66.987] (II) event0 - axp20x-pek: is tagged by udev as: Keyboard [ 66.988] (II) event0 - axp20x-pek: device is a keyboard [ 67.054] (**) HID 05ac:0256 Consumer Control: Applying InputClass "libinput keyboard catchall" [ 67.055] (II) Using input driver 'libinput' for 'HID 05ac:0256 Consumer Control' [ 67.055] (**) HID 05ac:0256 Consumer Control: always reports core events [ 67.055] (**) Option "Device" "/dev/input/event4" [ 67.055] (**) Option "_source" "_driver/libinput" [ 67.055] (II) libinput: HID 05ac:0256 Consumer Control: is a virtual subdevice [ 67.055] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input4/event4" [ 67.055] (II) XINPUT: Adding extended input device "HID 05ac:0256 Consumer Control" (type: KEYBOARD, id 12) [ 67.056] (**) Option "xkb_model" "pc105" [ 67.056] (**) Option "xkb_layout" "us" [ 67.057] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 67.058] (II) Using input driver 'libinput' for 'sunxi-ir' [ 67.058] (**) sunxi-ir: always reports core events [ 67.058] (**) Option "Device" "/dev/input/event1" [ 67.058] (**) Option "_source" "_driver/libinput" [ 67.058] (II) libinput: sunxi-ir: is a virtual subdevice [ 67.058] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c21800.ir/rc/rc0/input1/event1" [ 67.058] (II) XINPUT: Adding extended input device "sunxi-ir" (type: KEYBOARD, id 13) [ 67.058] (**) Option "xkb_model" "pc105" [ 67.059] (**) Option "xkb_layout" "us" [ 78.675] (II) modeset(0): Disabling kernel dirty updates, not required. Armbian 21.08.3 Focal with Linux 5.10.60-sunxi (latest upgrade) nothing changes armbianmonitor -u http://ix.io/3E9J journalctl -p 3 -xe -- Logs begin at Sat 2021-11-06 00:07:50 UTC, end at Sat 2021-11-06 00:25:01 UTC. -- Nov 06 00:07:50 cubietruck kernel: sun4i-drm display-engine: attempt to add DMA range to existing map Nov 06 00:07:50 cubietruck kernel: debugfs: Directory '1c22c00.codec' with parent 'sun4i-codec' already present! Nov 06 00:07:50 cubietruck kernel: phy id_det change to device Nov 06 00:07:50 cubietruck kernel: Bluetooth: hci0: BCM: firmware Patch file not found, tried: Nov 06 00:07:50 cubietruck kernel: Bluetooth: hci0: BCM: 'brcm/BCM20702A1.hcd' Nov 06 00:07:50 cubietruck kernel: Bluetooth: hci0: BCM: 'brcm/BCM.hcd' Nov 06 00:08:21 cubietruck kernel: ieee80211 phy0: brcmf_p2p_create_p2pdev: timeout occurred Nov 06 00:08:21 cubietruck kernel: ieee80211 phy0: brcmf_cfg80211_add_iface: add iface p2p-dev-wlan0 type 10 failed: err=-5 Nov 06 00:08:21 cubietruck wpa_supplicant[1720]: Failed to create interface p2p-dev-wlan0: -5 (Input/output error) Nov 06 00:08:21 cubietruck wpa_supplicant[1720]: nl80211: Failed to create a P2P Device interface p2p-dev-wlan0 Nov 06 00:08:24 cubietruck kernel: lima 1c40000.gpu: mmu page fault at 0x28fc2c0 from bus id 0 of type read on gpmmu Nov 06 00:08:25 cubietruck kernel: lima 1c40000.gpu: gp task error int_state=0 status=a Nov 06 00:08:25 cubietruck lightdm[1948]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory Nov 06 00:08:25 cubietruck lightdm[1948]: PAM adding faulty module: pam_kwallet.so Nov 06 00:08:25 cubietruck lightdm[1948]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory Nov 06 00:08:25 cubietruck lightdm[1948]: PAM adding faulty module: pam_kwallet5.so Nov 06 00:08:36 cubietruck lightdm[2422]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory Nov 06 00:08:36 cubietruck lightdm[2422]: PAM adding faulty module: pam_kwallet.so Nov 06 00:08:36 cubietruck lightdm[2422]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory Nov 06 00:08:36 cubietruck lightdm[2422]: PAM adding faulty module: pam_kwallet5.so Nov 06 00:14:36 cubietruck bluetoothd[1620]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98) Nov 06 00:14:36 cubietruck bluetoothd[1620]: RFCOMM server failed for :1.88/Profile/HSPHSProfile/00001108-0000-1000-8000-00805f9b34fb: rfcomm_bind: Address already in use (98) cat /var/log/Xorg.0.log Показать содержимое [ 53.125] X.Org X Server 1.20.11 X Protocol Version 11, Revision 0 [ 53.126] Build Operating System: linux Ubuntu [ 53.126] Current Operating System: Linux cubietruck 5.10.60-sunxi #21.08.2 SMP Tue Sep 14 16:28:44 UTC 2021 armv7l [ 53.126] Kernel command line: root=UUID=68b481b7-93d9-4f63-9190-cae97742a56f rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=e25f374d-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 [ 53.126] Build Date: 06 July 2021 10:17:51AM [ 53.126] xorg-server 2:1.20.11-1ubuntu1~20.04.2 (For technical support please see http://www.ubuntu.com/support) [ 53.126] Current version of pixman: 0.38.4 [ 53.127] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 53.127] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 53.127] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Nov 6 00:08:19 2021 [ 53.183] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 53.183] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 53.192] (==) No Layout section. Using the first Screen section. [ 53.193] (==) No screen section available. Using defaults. [ 53.193] (**) |-->Screen "Default Screen Section" (0) [ 53.193] (**) | |-->Monitor "<default monitor>" [ 53.196] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 53.196] (**) Option "BlankTime" "0" [ 53.196] (**) Option "StandbyTime" "0" [ 53.196] (**) Option "SuspendTime" "0" [ 53.196] (**) Option "OffTime" "0" [ 53.197] (==) Automatically adding devices [ 53.197] (==) Automatically enabling devices [ 53.197] (==) Automatically adding GPU devices [ 53.197] (==) Automatically binding GPU devices [ 53.197] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 53.227] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 53.228] Entry deleted from font path. [ 53.252] (==) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, built-ins [ 53.252] (==) ModulePath set to "/usr/lib/xorg/modules" [ 53.252] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 53.253] (II) Loader magic: 0x5b4008 [ 53.253] (II) Module ABI versions: [ 53.253] X.Org ANSI C Emulation: 0.4 [ 53.253] X.Org Video Driver: 24.1 [ 53.253] X.Org XInput driver : 24.1 [ 53.253] X.Org Server Extension : 10.0 [ 53.272] (++) using VT number 7 [ 53.272] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 53.291] (II) xfree86: Adding drm device (/dev/dri/card0) [ 53.319] (II) xfree86: Adding drm device (/dev/dri/card1) [ 53.324] (II) no primary bus or device found [ 53.325] falling back to /sys/devices/platform/display-engine/drm/card0 [ 53.325] (II) LoadModule: "glx" [ 53.332] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 53.385] (II) Module glx: vendor="X.Org Foundation" [ 53.385] compiled for 1.20.11, module version = 1.0.0 [ 53.385] ABI class: X.Org Server Extension, version 10.0 [ 53.386] (==) Matched modesetting as autoconfigured driver 0 [ 53.386] (==) Matched fbdev as autoconfigured driver 1 [ 53.386] (==) Assigned the driver to the xf86ConfigLayout [ 53.386] (II) LoadModule: "modesetting" [ 53.404] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so [ 53.407] (II) Module modesetting: vendor="X.Org Foundation" [ 53.407] compiled for 1.20.11, module version = 1.20.11 [ 53.408] Module class: X.Org Video Driver [ 53.408] ABI class: X.Org Video Driver, version 24.1 [ 53.408] (II) LoadModule: "fbdev" [ 53.409] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 53.418] (II) Module fbdev: vendor="X.Org Foundation" [ 53.418] compiled for 1.20.1, module version = 0.5.0 [ 53.418] Module class: X.Org Video Driver [ 53.418] ABI class: X.Org Video Driver, version 24.0 [ 53.418] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 53.418] (II) FBDEV: driver for framebuffer: fbdev [ 53.505] (II) modeset(0): using drv /dev/dri/card0 [ 53.505] (WW) Falling back to old probe method for fbdev [ 53.506] (II) Loading sub module "fbdevhw" [ 53.506] (II) LoadModule: "fbdevhw" [ 53.506] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 53.508] (II) Module fbdevhw: vendor="X.Org Foundation" [ 53.508] compiled for 1.20.11, module version = 0.0.2 [ 53.508] ABI class: X.Org Video Driver, version 24.1 [ 53.575] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support [ 53.577] (II) modeset(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 53.577] (==) modeset(0): Depth 24, (==) framebuffer bpp 32 [ 53.577] (==) modeset(0): RGB weight 888 [ 53.578] (==) modeset(0): Default visual is TrueColor [ 53.578] (II) Loading sub module "glamoregl" [ 53.578] (II) LoadModule: "glamoregl" [ 53.579] (II) Loading /usr/lib/xorg/modules/libglamoregl.so [ 53.754] (II) Module glamoregl: vendor="X.Org Foundation" [ 53.754] compiled for 1.20.11, module version = 1.0.1 [ 53.755] ABI class: X.Org ANSI C Emulation, version 0.4 [ 56.018] (II) modeset(0): glamor X acceleration enabled on Mali400 [ 56.018] (II) modeset(0): glamor initialized [ 56.086] (II) modeset(0): Output HDMI-1 has no monitor section [ 56.129] (II) modeset(0): EDID for output HDMI-1 [ 56.129] (II) modeset(0): Manufacturer: AOC Model: 2716 Serial#: 16843009 [ 56.130] (II) modeset(0): Year: 2016 Week: 0 [ 56.130] (II) modeset(0): EDID Version: 1.3 [ 56.130] (II) modeset(0): Digital Display Input [ 56.130] (II) modeset(0): Max Image Size [cm]: horiz.: 60 vert.: 34 [ 56.130] (II) modeset(0): Gamma: 2.20 [ 56.130] (II) modeset(0): No DPMS capabilities specified [ 56.130] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 [ 56.130] (II) modeset(0): Default color space is primary color space [ 56.130] (II) modeset(0): First detailed timing is preferred mode [ 56.130] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600 [ 56.130] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329 [ 56.130] (II) modeset(0): Supported established timings: [ 56.130] (II) modeset(0): 640x480@60Hz [ 56.130] (II) modeset(0): 800x600@60Hz [ 56.130] (II) modeset(0): 1024x768@60Hz [ 56.130] (II) modeset(0): Manufacturer's mask: 0 [ 56.131] (II) modeset(0): Supported detailed timing: [ 56.131] (II) modeset(0): clock: 148.5 MHz Image Size: 596 x 335 mm [ 56.131] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 56.131] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0 [ 56.131] (II) modeset(0): Serial No: [ 56.131] (II) modeset(0): Ranges: V min: 24 V max: 60 Hz, H min: 30 H max: 140 kHz, PixClock max 305 MHz [ 56.131] (II) modeset(0): Monitor name: AG271UG [ 56.131] (II) modeset(0): Number of EDID sections to follow: 1 [ 56.131] (II) modeset(0): EDID (in hex): [ 56.132] (II) modeset(0): 00ffffffffffff0005e3162701010101 [ 56.132] (II) modeset(0): 001a0103803c22780eee91a3544c9926 [ 56.133] (II) modeset(0): 0f505421080001010101010101010101 [ 56.133] (II) modeset(0): 010101010101023a801871382d40582c [ 56.133] (II) modeset(0): 4500544f2100001e000000ff000a2020 [ 56.133] (II) modeset(0): 20202020202020202020000000fd0018 [ 56.133] (II) modeset(0): 3c1e8c1e010a202020202020000000fc [ 56.133] (II) modeset(0): 00414732373155470a20202020200187 [ 56.133] (II) modeset(0): 020323c149901f04130312015d5f2309 [ 56.133] (II) modeset(0): 0701830100006c030c001000003c2010 [ 56.133] (II) modeset(0): 40030100000000000000000000000000 [ 56.133] (II) modeset(0): 00000000000000000000000000000000 [ 56.133] (II) modeset(0): 00000000000000000000000000000000 [ 56.133] (II) modeset(0): 00000000000000000000000000000000 [ 56.133] (II) modeset(0): 00000000000000000000000000000000 [ 56.133] (II) modeset(0): 00000000000000000000000000000043 [ 56.134] (--) modeset(0): HDMI max TMDS frequency 300000KHz [ 56.134] (II) modeset(0): Printing probed modes for output HDMI-1 [ 56.134] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 56.134] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 56.134] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e) [ 56.134] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 56.134] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 56.134] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 56.135] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 56.135] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 56.135] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 56.135] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 56.135] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 56.135] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 56.135] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 56.135] (II) modeset(0): Output HDMI-1 connected [ 56.135] (II) modeset(0): Using exact sizes for initial modes [ 56.135] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0 [ 56.135] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0) [ 56.135] (==) modeset(0): DPI set to (96, 96) [ 56.135] (II) Loading sub module "fb" [ 56.136] (II) LoadModule: "fb" [ 56.136] (II) Loading /usr/lib/xorg/modules/libfb.so [ 56.146] (II) Module fb: vendor="X.Org Foundation" [ 56.146] compiled for 1.20.11, module version = 1.0.0 [ 56.146] ABI class: X.Org ANSI C Emulation, version 0.4 [ 56.146] (II) UnloadModule: "fbdev" [ 56.146] (II) Unloading fbdev [ 56.147] (II) UnloadSubModule: "fbdevhw" [ 56.147] (II) Unloading fbdevhw [ 56.334] (==) modeset(0): Backing store enabled [ 56.335] (==) modeset(0): Silken mouse enabled [ 56.339] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc. [ 56.340] (==) modeset(0): DPMS enabled [ 56.341] (II) modeset(0): [DRI2] Setup complete [ 56.341] (II) modeset(0): [DRI2] DRI driver: sun4i-drm [ 56.341] (II) modeset(0): [DRI2] VDPAU driver: sun4i-drm [ 56.341] (II) Initializing extension Generic Event Extension [ 56.343] (II) Initializing extension SHAPE [ 56.344] (II) Initializing extension MIT-SHM [ 56.346] (II) Initializing extension XInputExtension [ 56.347] (II) Initializing extension XTEST [ 56.349] (II) Initializing extension BIG-REQUESTS [ 56.351] (II) Initializing extension SYNC [ 56.352] (II) Initializing extension XKEYBOARD [ 56.354] (II) Initializing extension XC-MISC [ 56.355] (II) Initializing extension SECURITY [ 56.357] (II) Initializing extension XFIXES [ 56.358] (II) Initializing extension RENDER [ 56.359] (II) Initializing extension RANDR [ 56.362] (II) Initializing extension COMPOSITE [ 56.363] (II) Initializing extension DAMAGE [ 56.365] (II) Initializing extension MIT-SCREEN-SAVER [ 56.366] (II) Initializing extension DOUBLE-BUFFER [ 56.368] (II) Initializing extension RECORD [ 56.369] (II) Initializing extension DPMS [ 56.370] (II) Initializing extension Present [ 56.372] (II) Initializing extension DRI3 [ 56.373] (II) Initializing extension X-Resource [ 56.374] (II) Initializing extension XVideo [ 56.376] (II) Initializing extension XVideo-MotionCompensation [ 56.376] (II) Initializing extension SELinux [ 56.376] (II) SELinux: Disabled on system [ 56.376] (II) Initializing extension GLX [ 56.378] (EE) AIGLX error: sun4i-drm does not export required DRI extension [ 56.499] (II) IGLX: Loaded and initialized swrast [ 56.500] (II) GLX: Initialized DRISWRAST GL provider for screen 0 [ 56.500] (II) Initializing extension XFree86-VidModeExtension [ 56.501] (II) Initializing extension XFree86-DGA [ 56.503] (II) Initializing extension XFree86-DRI [ 56.503] (II) Initializing extension DRI2 [ 56.513] (II) modeset(0): Damage tracking initialized [ 56.513] (II) modeset(0): Setting screen physical size to 508 x 285 [ 57.046] (II) config/udev: Adding input device HID 05ac:0256 (/dev/input/event2) [ 57.046] (**) HID 05ac:0256: Applying InputClass "libinput keyboard catchall" [ 57.046] (II) LoadModule: "libinput" [ 57.047] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so [ 57.072] (II) Module libinput: vendor="X.Org Foundation" [ 57.072] compiled for 1.20.4, module version = 0.29.0 [ 57.072] Module class: X.Org XInput Driver [ 57.072] ABI class: X.Org XInput driver, version 24.1 [ 57.072] (II) Using input driver 'libinput' for 'HID 05ac:0256' [ 57.072] (**) HID 05ac:0256: always reports core events [ 57.073] (**) Option "Device" "/dev/input/event2" [ 57.073] (**) Option "_source" "server/udev" [ 57.123] (II) event2 - HID 05ac:0256: is tagged by udev as: Keyboard [ 57.124] (II) event2 - HID 05ac:0256: device is a keyboard [ 57.127] (II) event2 - HID 05ac:0256: device removed [ 57.144] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.0/0003:05AC:0256.0001/input/input2/event2" [ 57.145] (II) XINPUT: Adding extended input device "HID 05ac:0256" (type: KEYBOARD, id 6) [ 57.145] (**) Option "xkb_model" "pc105" [ 57.145] (**) Option "xkb_layout" "us" [ 57.166] (II) event2 - HID 05ac:0256: is tagged by udev as: Keyboard [ 57.167] (II) event2 - HID 05ac:0256: device is a keyboard [ 57.179] (II) config/udev: Adding input device HID 05ac:0256 Mouse (/dev/input/event3) [ 57.179] (**) HID 05ac:0256 Mouse: Applying InputClass "libinput pointer catchall" [ 57.179] (II) Using input driver 'libinput' for 'HID 05ac:0256 Mouse' [ 57.179] (**) HID 05ac:0256 Mouse: always reports core events [ 57.180] (**) Option "Device" "/dev/input/event3" [ 57.180] (**) Option "_source" "server/udev" [ 57.200] (II) event3 - HID 05ac:0256 Mouse: is tagged by udev as: Mouse [ 57.202] (II) event3 - HID 05ac:0256 Mouse: device is a pointer [ 57.204] (II) event3 - HID 05ac:0256 Mouse: device removed [ 57.240] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input3/event3" [ 57.241] (II) XINPUT: Adding extended input device "HID 05ac:0256 Mouse" (type: MOUSE, id 7) [ 57.242] (**) Option "AccelerationScheme" "none" [ 57.242] (**) HID 05ac:0256 Mouse: (accel) selected scheme none/0 [ 57.242] (**) HID 05ac:0256 Mouse: (accel) acceleration factor: 2.000 [ 57.242] (**) HID 05ac:0256 Mouse: (accel) acceleration threshold: 4 [ 57.262] (II) event3 - HID 05ac:0256 Mouse: is tagged by udev as: Mouse [ 57.263] (II) event3 - HID 05ac:0256 Mouse: device is a pointer [ 57.291] (II) config/udev: Adding input device HID 05ac:0256 Consumer Control (/dev/input/event4) [ 57.291] (**) HID 05ac:0256 Consumer Control: Applying InputClass "libinput keyboard catchall" [ 57.292] (II) Using input driver 'libinput' for 'HID 05ac:0256 Consumer Control' [ 57.292] (**) HID 05ac:0256 Consumer Control: always reports core events [ 57.292] (**) Option "Device" "/dev/input/event4" [ 57.292] (**) Option "_source" "server/udev" [ 57.311] (II) event4 - HID 05ac:0256 Consumer Control: is tagged by udev as: Keyboard [ 57.313] (II) event4 - HID 05ac:0256 Consumer Control: device is a keyboard [ 57.314] (II) event4 - HID 05ac:0256 Consumer Control: device removed [ 57.328] (II) libinput: HID 05ac:0256 Consumer Control: needs a virtual subdevice [ 57.328] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input4/event4" [ 57.329] (II) XINPUT: Adding extended input device "HID 05ac:0256 Consumer Control" (type: MOUSE, id 8) [ 57.329] (**) Option "AccelerationScheme" "none" [ 57.329] (**) HID 05ac:0256 Consumer Control: (accel) selected scheme none/0 [ 57.329] (**) HID 05ac:0256 Consumer Control: (accel) acceleration factor: 2.000 [ 57.329] (**) HID 05ac:0256 Consumer Control: (accel) acceleration threshold: 4 [ 57.348] (II) event4 - HID 05ac:0256 Consumer Control: is tagged by udev as: Keyboard [ 57.349] (II) event4 - HID 05ac:0256 Consumer Control: device is a keyboard [ 57.360] (II) config/udev: Adding input device HID 05ac:0256 System Control (/dev/input/event5) [ 57.360] (**) HID 05ac:0256 System Control: Applying InputClass "libinput keyboard catchall" [ 57.360] (II) Using input driver 'libinput' for 'HID 05ac:0256 System Control' [ 57.360] (**) HID 05ac:0256 System Control: always reports core events [ 57.361] (**) Option "Device" "/dev/input/event5" [ 57.361] (**) Option "_source" "server/udev" [ 57.381] (II) event5 - HID 05ac:0256 System Control: is tagged by udev as: Keyboard [ 57.382] (II) event5 - HID 05ac:0256 System Control: device is a keyboard [ 57.383] (II) event5 - HID 05ac:0256 System Control: device removed [ 57.396] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input5/event5" [ 57.396] (II) XINPUT: Adding extended input device "HID 05ac:0256 System Control" (type: KEYBOARD, id 9) [ 57.396] (**) Option "xkb_model" "pc105" [ 57.396] (**) Option "xkb_layout" "us" [ 57.422] (II) event5 - HID 05ac:0256 System Control: is tagged by udev as: Keyboard [ 57.423] (II) event5 - HID 05ac:0256 System Control: device is a keyboard [ 57.431] (II) config/udev: Adding input device sunxi-ir (/dev/input/event1) [ 57.432] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 57.432] (II) Using input driver 'libinput' for 'sunxi-ir' [ 57.432] (**) sunxi-ir: always reports core events [ 57.432] (**) Option "Device" "/dev/input/event1" [ 57.432] (**) Option "_source" "server/udev" [ 57.445] (II) event1 - sunxi-ir: is tagged by udev as: Keyboard Pointingstick [ 57.448] (II) event1 - sunxi-ir: device is a pointer [ 57.448] (II) event1 - sunxi-ir: device is a keyboard [ 57.451] (II) event1 - sunxi-ir: device removed [ 57.488] (II) libinput: sunxi-ir: needs a virtual subdevice [ 57.488] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c21800.ir/rc/rc0/input1/event1" [ 57.488] (II) XINPUT: Adding extended input device "sunxi-ir" (type: MOUSE, id 10) [ 57.489] (**) Option "AccelerationScheme" "none" [ 57.490] (**) sunxi-ir: (accel) selected scheme none/0 [ 57.490] (**) sunxi-ir: (accel) acceleration factor: 2.000 [ 57.490] (**) sunxi-ir: (accel) acceleration threshold: 4 [ 57.502] (II) event1 - sunxi-ir: is tagged by udev as: Keyboard Pointingstick [ 57.505] (II) event1 - sunxi-ir: device is a pointer [ 57.505] (II) event1 - sunxi-ir: device is a keyboard [ 57.517] (II) config/udev: Adding input device axp20x-pek (/dev/input/event0) [ 57.518] (**) axp20x-pek: Applying InputClass "libinput keyboard catchall" [ 57.518] (II) Using input driver 'libinput' for 'axp20x-pek' [ 57.518] (**) axp20x-pek: always reports core events [ 57.518] (**) Option "Device" "/dev/input/event0" [ 57.518] (**) Option "_source" "server/udev" [ 57.536] (II) event0 - axp20x-pek: is tagged by udev as: Keyboard [ 57.537] (II) event0 - axp20x-pek: device is a keyboard [ 57.540] (II) event0 - axp20x-pek: device removed [ 57.560] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c2ac00.i2c/i2c-1/1-0034/axp20x-pek/input/input0/event0" [ 57.560] (II) XINPUT: Adding extended input device "axp20x-pek" (type: KEYBOARD, id 11) [ 57.560] (**) Option "xkb_model" "pc105" [ 57.560] (**) Option "xkb_layout" "us" [ 57.579] (II) event0 - axp20x-pek: is tagged by udev as: Keyboard [ 57.580] (II) event0 - axp20x-pek: device is a keyboard [ 57.659] (**) HID 05ac:0256 Consumer Control: Applying InputClass "libinput keyboard catchall" [ 57.659] (II) Using input driver 'libinput' for 'HID 05ac:0256 Consumer Control' [ 57.659] (**) HID 05ac:0256 Consumer Control: always reports core events [ 57.659] (**) Option "Device" "/dev/input/event4" [ 57.659] (**) Option "_source" "_driver/libinput" [ 57.659] (II) libinput: HID 05ac:0256 Consumer Control: is a virtual subdevice [ 57.692] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:05AC:0256.0002/input/input4/event4" [ 57.692] (II) XINPUT: Adding extended input device "HID 05ac:0256 Consumer Control" (type: KEYBOARD, id 12) [ 57.692] (**) Option "xkb_model" "pc105" [ 57.692] (**) Option "xkb_layout" "us" [ 57.693] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 57.694] (II) Using input driver 'libinput' for 'sunxi-ir' [ 57.694] (**) sunxi-ir: always reports core events [ 57.694] (**) Option "Device" "/dev/input/event1" [ 57.694] (**) Option "_source" "_driver/libinput" [ 57.694] (II) libinput: sunxi-ir: is a virtual subdevice [ 57.694] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c21800.ir/rc/rc0/input1/event1" [ 57.694] (II) XINPUT: Adding extended input device "sunxi-ir" (type: KEYBOARD, id 13) [ 57.694] (**) Option "xkb_model" "pc105" [ 57.694] (**) Option "xkb_layout" "us" [ 69.038] (II) modeset(0): Disabling kernel dirty updates, not required. Check patched image: https://drive.google.com/drive/folders/1TUAyzkkQXBWXdBSABVRabxH0J3KLknT7?usp=sharing 1 Quote Link to post Share on other sites More sharing options...
0 CryBaby 2 Posted November 11, 2021 Share Posted November 11, 2021 I found I get a desktop if I install xserver-xorg-video-fbturbo. The performance is pretty poor though. Is this still the preferred option or has it been superceded? To answer my own question for the record: fbturbo uses ARM's mali blob for acceleration, which I don't have hence the poor performance. Recent xorg works with lima and doesn't need the blob. So the correct solution to this problem is to wait for xorg-server 21.0.99.1 or newer to become available in Armbian. 0 Quote Link to post Share on other sites More sharing options...
0 voka 2 Posted November 12, 2021 Author Share Posted November 12, 2021 11.11.2021 в 06:29, CryBaby сказал: I found I get a desktop if I install xserver-xorg-video-fbturbo. The performance is pretty poor though. Is this still the preferred option or has it been superceded? To answer my own question for the record: fbturbo uses ARM's mali blob for acceleration, which I don't have hence the poor performance. Recent xorg works with lima and doesn't need the blob. So the correct solution to this problem is to wait for xorg-server 21.0.99.1 or newer to become available in Armbian. I installed from https://launchpad.net/~ubuntu-raspi2/+archive/ubuntu/ppa-nightly , still a black screen and a AIGLX error: sun4i-drm does not export required DRI extension error. Where did you get the xserver-xorg-video-fbturbo package from? 0 Quote Link to post Share on other sites More sharing options...
0 CryBaby 2 Posted November 12, 2021 Share Posted November 12, 2021 A simple sudo apt install. I had that error before I installed it, after I get AIGLX: Screen 0 is not DRI2 capable. I assume this would be fixed if I installed the mali blob. I still have the original X.Org X Server 1.20.11, maybe you have a different one? 0 Quote Link to post Share on other sites More sharing options...
0 OLEGIM 0 Posted November 17, 2021 Share Posted November 17, 2021 08.11.2021 в 11:36, voka сказал: Check patched image: https://drive.google.com/drive/folders/1TUAyzkkQXBWXdBSABVRabxH0J3KLknT7?usp=sharing Thanks for the image. it worked correctly the first time. graphics load the processor a lot. When starting multimedia, the processor load is 100%. results: https://ibb.co/LZvZvZP https://ibb.co/q9pk0f9 https://ibb.co/vwQMP37 https://ibb.co/1MPzJDX https://ibb.co/vkkW5Tx 0 Quote Link to post Share on other sites More sharing options...
0 Nico Verduin 0 Posted December 22, 2021 Share Posted December 22, 2021 I am not sure if this is the right post but I seem to have the same problem. I am trying to reinstall my Cubietruck 3 with this file : Armbian_21.08.1_Cubietruck_focal_current_5.10.60_xfce_desktop. It boots fine does everything according to the documentation, starts "starting desktop environment" and that was the last I saw. No doubt I am doing something wrong but being a CP/M, DOS, Windows guy I am not familiar with Linux.... Regards Nico (Netherlands) 0 Quote Link to post Share on other sites More sharing options...
0 CryBaby 2 Posted December 23, 2021 Share Posted December 23, 2021 I just did a firmware update and got xorg 1.20.13 but it still does not work. Looks like we'll have a wait a bit longer for the next version. @Nico: if you Ctrl-Alt-F2 you will get a login prompt. Once logged in you can type sudo armbian-config and under System->Firmware do a full update. Try this once a week until things improve 0 Quote Link to post Share on other sites More sharing options...
0 Nico Verduin 0 Posted December 23, 2021 Share Posted December 23, 2021 I installed the desktop and through ctrl-alt-F2 was able to exit back to the CLI. And all works fine again except for the desktop. I was wondering, I use an adapter to convert from HDMI to VGA. Could that be the cause? 0 Quote Link to post Share on other sites More sharing options...
0 Nico Verduin 0 Posted December 23, 2021 Share Posted December 23, 2021 On 11/17/2021 at 8:12 PM, OLEGIM said: Thanks for the image. it worked correctly the first time. graphics load the processor a lot. When starting multimedia, the processor load is 100%. results: https://ibb.co/LZvZvZP https://ibb.co/q9pk0f9 https://ibb.co/vwQMP37 https://ibb.co/1MPzJDX https://ibb.co/vkkW5Tx How does one apply a patch? 0 Quote Link to post Share on other sites More sharing options...
0 voka 2 Posted December 23, 2021 Author Share Posted December 23, 2021 3 часа назад, Nico Verduin сказал: How does one apply a patch? In this image the patch has already been applied: https://drive.google.com/drive/folders/1TUAyzkkQXBWXdBSABVRabxH0J3KLknT7?usp=sharing 0 Quote Link to post Share on other sites More sharing options...
0 CryBaby 2 Posted December 23, 2021 Share Posted December 23, 2021 The problem is a bug in the xserver, not your HDMI to VGA unit. The bug has been fixed but the fixed version has not yet reached the standard repos. Voka is offering a version of Armbian which includes the fix. That is a good option if you have not invested much effort in configuring your existing install. 0 Quote Link to post Share on other sites More sharing options...
0 Nico Verduin 0 Posted December 23, 2021 Share Posted December 23, 2021 I downloaded the files. There is an image 001 and 003 . The 003 is the patched version? For the rest it is still all clean installations so nothing is lost. I have 64Gb Class 10 SD card which is extremely fast so changing does not take too much time. 0 Quote Link to post Share on other sites More sharing options...
0 Nico Verduin 0 Posted December 24, 2021 Share Posted December 24, 2021 It was image 001. WOrks like a charm. Will reinstall on a 64Gb class 10 sd and a 500Gb Hard disk. Next I will try to see if it works on a phoenix A20 (have 2 of those) Thanks again!!! 0 Quote Link to post Share on other sites More sharing options...
Question
voka 2
/var/log/Xorg.0.log: [ 59.326] (EE) AIGLX error: sun4i-drm does not export required DRI extension [ 59.550] (II) IGLX: Loaded and initialized swrast [ 59.550] (II) GLX: Initialized DRISWRAST GL provider for screen 0 [ 59.550] (II) Initializing extension XFree86-VidModeExtension [ 59.551] (II) Initializing extension XFree86-DGA [ 59.553] (II) Initializing extension XFree86-DRI [ 59.553] (II) Initializing extension DRI2 [ 59.564] (II) modeset(0): Damage tracking initialized [ 59.565] (II) modeset(0): Setting screen physical size to 508 x 285 [ 60.561] (II) config/udev: Adding input device sunxi-ir (/dev/input/event1) [ 60.561] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 60.561] (II) LoadModule: "libinput" [ 60.562] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so [ 60.624] (II) Module libinput: vendor="X.Org Foundation" [ 60.624] compiled for 1.20.4, module version = 0.29.0 [ 60.624] Module class: X.Org XInput Driver [ 60.624] ABI class: X.Org XInput driver, version 24.1 [ 60.624] (II) Using input driver 'libinput' for 'sunxi-ir' [ 60.624] (**) sunxi-ir: always reports core events [ 60.624] (**) Option "Device" "/dev/input/event1" [ 60.625] (**) Option "_source" "server/udev" [ 60.703] (II) event1 - sunxi-ir: is tagged by udev as: Keyboard Pointingstick [ 60.708] (II) event1 - sunxi-ir: device is a pointer [ 60.708] (II) event1 - sunxi-ir: device is a keyboard [ 60.710] (II) event1 - sunxi-ir: device removed [ 60.749] (II) libinput: sunxi-ir: needs a virtual subdevice [ 60.749] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c21800.ir/rc/rc0/input1/event1" [ 60.749] (II) XINPUT: Adding extended input device "sunxi-ir" (type: MOUSE, id 6)
Link to post
18 answers to this question
