Cubietruck, Black screen XFCE, AIGLX error: sun4i-drm does not export required DRI extension
Armbianmonitor:
/var/log/Xorg.0.log:
[    59.326] (EE) AIGLX error: sun4i-drm does not export required DRI extension
[    59.550] (II) IGLX: Loaded and initialized swrast
[    59.550] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    59.550] (II) Initializing extension XFree86-VidModeExtension
[    59.551] (II) Initializing extension XFree86-DGA
[    59.553] (II) Initializing extension XFree86-DRI
[    59.553] (II) Initializing extension DRI2
[    59.564] (II) modeset(0): Damage tracking initialized
[    59.565] (II) modeset(0): Setting screen physical size to 508 x 285
[    60.561] (II) config/udev: Adding input device sunxi-ir (/dev/input/event1)
[    60.561] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall"
[    60.561] (II) LoadModule: "libinput"
[    60.562] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    60.624] (II) Module libinput: vendor="X.Org Foundation"
[    60.624]    compiled for 1.20.4, module version = 0.29.0
[    60.624]    Module class: X.Org XInput Driver
[    60.624]    ABI class: X.Org XInput driver, version 24.1
[    60.624] (II) Using input driver 'libinput' for 'sunxi-ir'
[    60.624] (**) sunxi-ir: always reports core events
[    60.624] (**) Option "Device" "/dev/input/event1"
[    60.625] (**) Option "_source" "server/udev"
[    60.703] (II) event1  - sunxi-ir: is tagged by udev as: Keyboard Pointingstick
[    60.708] (II) event1  - sunxi-ir: device is a pointer
[    60.708] (II) event1  - sunxi-ir: device is a keyboard
[    60.710] (II) event1  - sunxi-ir: device removed
[    60.749] (II) libinput: sunxi-ir: needs a virtual subdevice
[    60.749] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c21800.ir/rc/rc0/input1/event1"
[    60.749] (II) XINPUT: Adding extended input device "sunxi-ir" (type: MOUSE, id 6)
Install Armbian 21.11.0-trunk
X.Org X Server version 1.20.11
Still black screen and same error
how to upgrade xorg to a new version?
Guys, help. I installed the armbian 21.08.1 Focal XFCE base image and ran it. Video over HDMI shows black screen. After the update, nothing has changed. I tried several actions that were written on the forum, but nothing helped. What steps need to be taken to fix this?
armbianmonitor -u
http://ix.io/3E9k
journalctl -p 3 -xe
-- Logs begin at Fri 2021-11-05 22:16:31 UTC, end at Fri 2021-11-05 22:25:01 UTC. --
Nov 05 22:16:31 cubietruck kernel: sun4i-drm display-engine: attempt to add DMA range to existing map
Nov 05 22:16:31 cubietruck kernel: debugfs: Directory '1c22c00.codec' with parent 'sun4i-codec' already present!
Nov 05 22:16:32 cubietruck kernel: phy id_det change to device
Nov 05 22:16:32 cubietruck kernel: Bluetooth: hci0: BCM: firmware Patch file not found, tried:
Nov 05 22:16:32 cubietruck kernel: Bluetooth: hci0: BCM: 'brcm/BCM20702A1.hcd'
Nov 05 22:16:32 cubietruck kernel: Bluetooth: hci0: BCM: 'brcm/BCM.hcd'
Nov 05 22:17:11 cubietruck kernel: ieee80211 phy0: brcmf_p2p_create_p2pdev: timeout occurred
Nov 05 22:17:11 cubietruck kernel: ieee80211 phy0: brcmf_cfg80211_add_iface: add iface p2p-dev-wlan0 type 10 failed: err=-5
Nov 05 22:17:11 cubietruck wpa_supplicant[1651]: Failed to create interface p2p-dev-wlan0: -5 (Input/output error)
Nov 05 22:17:11 cubietruck wpa_supplicant[1651]: nl80211: Failed to create a P2P Device interface p2p-dev-wlan0
Nov 05 22:17:15 cubietruck kernel: lima 1c40000.gpu: mmu page fault at 0x28fc340 from bus id 0 of type read on gpmmu
Nov 05 22:17:15 cubietruck kernel: lima 1c40000.gpu: gp task error int_state=0 status=a
Nov 05 22:17:16 cubietruck lightdm[1946]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
Nov 05 22:17:16 cubietruck lightdm[1946]: PAM adding faulty module: pam_kwallet.so
Nov 05 22:17:16 cubietruck lightdm[1946]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
Nov 05 22:17:16 cubietruck lightdm[1946]: PAM adding faulty module: pam_kwallet5.so
Nov 05 22:17:27 cubietruck lightdm[2018]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
Nov 05 22:17:27 cubietruck lightdm[2018]: PAM adding faulty module: pam_kwallet.so
Nov 05 22:17:27 cubietruck lightdm[2018]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
Nov 05 22:17:27 cubietruck lightdm[2018]: PAM adding faulty module: pam_kwallet5.so
Nov 05 22:21:38 cubietruck lightdm[2045]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
Nov 05 22:21:38 cubietruck lightdm[2045]: PAM adding faulty module: pam_kwallet.so
Nov 05 22:21:38 cubietruck lightdm[2045]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
Nov 05 22:21:38 cubietruck lightdm[2045]: PAM adding faulty module: pam_kwallet5.so
Nov 05 22:21:41 cubietruck lightdm[2047]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
Nov 05 22:21:41 cubietruck lightdm[2047]: PAM adding faulty module: pam_kwallet.so
Nov 05 22:21:41 cubietruck lightdm[2047]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
Nov 05 22:21:41 cubietruck lightdm[2047]: PAM adding faulty module: pam_kwallet5.so
Nov 05 22:21:58 cubietruck bluetoothd[1609]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
Nov 05 22:21:58 cubietruck bluetoothd[1609]: RFCOMM server failed for :1.88/Profile/HSPHSProfile/00001108-0000-1000-8000-00805f9b34fb: rfcomm_bind: Address already in use (98)
Xorg logs
cat /var/log/Xorg.0.log
  Reveal hidden contents
Armbian 21.08.3 Focal with Linux 5.10.60-sunxi (latest upgrade) nothing changes
armbianmonitor -u
http://ix.io/3E9J
journalctl -p 3 -xe
-- Logs begin at Sat 2021-11-06 00:07:50 UTC, end at Sat 2021-11-06 00:25:01 UTC. --
Nov 06 00:07:50 cubietruck kernel: sun4i-drm display-engine: attempt to add DMA range to existing map
Nov 06 00:07:50 cubietruck kernel: debugfs: Directory '1c22c00.codec' with parent 'sun4i-codec' already present!
Nov 06 00:07:50 cubietruck kernel: phy id_det change to device
Nov 06 00:07:50 cubietruck kernel: Bluetooth: hci0: BCM: firmware Patch file not found, tried:
Nov 06 00:07:50 cubietruck kernel: Bluetooth: hci0: BCM: 'brcm/BCM20702A1.hcd'
Nov 06 00:07:50 cubietruck kernel: Bluetooth: hci0: BCM: 'brcm/BCM.hcd'
Nov 06 00:08:21 cubietruck kernel: ieee80211 phy0: brcmf_p2p_create_p2pdev: timeout occurred
Nov 06 00:08:21 cubietruck kernel: ieee80211 phy0: brcmf_cfg80211_add_iface: add iface p2p-dev-wlan0 type 10 failed: err=-5
Nov 06 00:08:21 cubietruck wpa_supplicant[1720]: Failed to create interface p2p-dev-wlan0: -5 (Input/output error)
Nov 06 00:08:21 cubietruck wpa_supplicant[1720]: nl80211: Failed to create a P2P Device interface p2p-dev-wlan0
Nov 06 00:08:24 cubietruck kernel: lima 1c40000.gpu: mmu page fault at 0x28fc2c0 from bus id 0 of type read on gpmmu
Nov 06 00:08:25 cubietruck kernel: lima 1c40000.gpu: gp task error int_state=0 status=a
Nov 06 00:08:25 cubietruck lightdm[1948]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
Nov 06 00:08:25 cubietruck lightdm[1948]: PAM adding faulty module: pam_kwallet.so
Nov 06 00:08:25 cubietruck lightdm[1948]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
Nov 06 00:08:25 cubietruck lightdm[1948]: PAM adding faulty module: pam_kwallet5.so
Nov 06 00:08:36 cubietruck lightdm[2422]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
Nov 06 00:08:36 cubietruck lightdm[2422]: PAM adding faulty module: pam_kwallet.so
Nov 06 00:08:36 cubietruck lightdm[2422]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
Nov 06 00:08:36 cubietruck lightdm[2422]: PAM adding faulty module: pam_kwallet5.so
Nov 06 00:14:36 cubietruck bluetoothd[1620]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
Nov 06 00:14:36 cubietruck bluetoothd[1620]: RFCOMM server failed for :1.88/Profile/HSPHSProfile/00001108-0000-1000-8000-00805f9b34fb: rfcomm_bind: Address already in use (98)
armbianmonitor -u
http://ix.io/3E9k
journalctl -p 3 -xe
Xorg logs
armbianmonitor -u
http://ix.io/3E9J
journalctl -p 3 -xe
Expand
Check patched image: https://drive.google.com/drive/folders/1TUAyzkkQXBWXdBSABVRabxH0J3KLknT7?usp=sharing
I found I get a desktop if I install xserver-xorg-video-fbturbo. The performance is pretty poor though. Is this still the preferred option or has it been superceded?
To answer my own question for the record: fbturbo uses ARM's mali blob for acceleration, which I don't have hence the poor performance. Recent xorg works with lima and doesn't need the blob. So the correct solution to this problem is to wait for xorg-server 21.0.99.1 or newer to become available in Armbian.
Expand
I installed from https://launchpad.net/~ubuntu-raspi2/+archive/ubuntu/ppa-nightly , still a black screen and a AIGLX error: sun4i-drm does not export required DRI extension error.
Where did you get the xserver-xorg-video-fbturbo package from?
A simple sudo apt install. I had that error before I installed it, after I get AIGLX: Screen 0 is not DRI2 capable. I assume this would be fixed if I installed the mali blob.
I still have the original X.Org X Server 1.20.11, maybe you have a different one?
  On 11/8/2021 at 8:36 AM, voka said:
Expand
Thanks for the image. it worked correctly the first time. graphics load the processor a lot. When starting multimedia, the processor load is 100%.
results:
https://ibb.co/LZvZvZP
https://ibb.co/q9pk0f9
https://ibb.co/vwQMP37
https://ibb.co/1MPzJDX
https://ibb.co/vkkW5Tx
I am not sure if this is the right post but I seem to have the same problem. I am trying to reinstall my Cubietruck 3 with this file : Armbian_21.08.1_Cubietruck_focal_current_5.10.60_xfce_desktop. It boots fine does everything according to the documentation, starts "starting desktop environment" and that was the last I saw. No doubt I am doing something wrong but being a CP/M, DOS, Windows guy I am not familiar with Linux....
Regards Nico
(Netherlands)
I just did a firmware update and got xorg 1.20.13 but it still does not work. Looks like we'll have a wait a bit longer for the next version.
@Nico: if you Ctrl-Alt-F2 you will get a login prompt. Once logged in you can type sudo armbian-config and under System->Firmware do a full update. Try this once a week until things improve:rolleyes:
I installed the desktop and through ctrl-alt-F2 was able to exit back to the CLI. And all works fine again except for the desktop. I was wondering, I use an adapter to convert from HDMI to VGA. Could that be the cause?
The problem is a bug in the xserver, not your HDMI to VGA unit. The bug has been fixed but the fixed version has not yet reached the standard repos. Voka is offering a version of Armbian which includes the fix. That is a good option if you have not invested much effort in configuring your existing install.
I downloaded the files. There is an image 001 and 003 . The 003 is the patched version? For the rest it is still all clean installations so nothing is lost. I have 64Gb Class 10 SD card which is extremely fast so changing does not take too much time.
Posted (edited)
Try this but not sure if it will work:
git clone git@github.com:armbian/build.git
cd build
in file "packages/extras-buildpkgs/xf86-video-armsoc/debian/patches/0001-Add-sun4i_drmmode-driver.patch" change "sun4i-drm" to "sun4i_drm"
./compile.sh docker
- "Show a kernel configuration menu before compilation"
- button at the bottom "Show CSC/WIP/EOS/TVB"
- "I understand and agree"
- "cubietruck"
- "current"
- "jammy"
- "Image with desktop environment"
- "xfce"
- choose what you need
- ОК
Edited by voka
Thanks for your information.
Would it be possible to have the link to an already compiled version? That would be much better.
Thanks in advance!
New instruction:
cd build
./compile.sh docker BOARD=cubietruck BRANCH=current RELEASE=jammy BUILD_MINIMAL=no BUILD_DESKTOP=yes KERNEL_CONFIGURE=no DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base DESKTOP_APPGROUPS_SELECTED="3dsupport browsers chat desktop_tools editors email internet multimedia office programming remote_desktop" COMPRESS_OUTPUTIMAGE=sha,gpg,img
Сurrent link: https://drive.google.com/file/d/1_fRisa7gsMm-hjkw7TzOHJ7J6jvAaMAy/view?usp=sharing
The file will be deleted on 01/01/2023
Same error for me...
Blank screen after load desktop.
see my dmesg:
root@cubietruck:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.15.82-sunxi (root@62693d2225c5) (arm-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #trunk SMP Mon Dec 12 07:01:09 UTC 2022
[    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=50c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Cubietech Cubietruck
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x4a000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node default-pool, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000040000000-0x000000006fffffff]
[    0.000000]   HighMem  [mem 0x0000000070000000-0x00000000bdffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000bdffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bdffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] percpu: Embedded 17 pages/cpu s38540 r8192 d22900 u69632
[    0.000000] pcpu-alloc: s38540 r8192 d22900 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 514368
[    0.000000] Kernel command line: root=UUID=61d9a67f-1c4b-441c-9979-6082085dd7bf rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=f3559229-01 ubootsource=mmc usb-storage.quirks=   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=f3559229-01 ubootsource=mmc sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 1912752K/2064384K available (9216K kernel code, 1508K rwdata, 3396K rodata, 1024K init, 328K bss, 53328K reserved, 98304K cma-reserved, 1277952K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] ftrace: allocating 43962 entries in 129 pages
[    0.000000] ftrace: allocated 129 pages with 2 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000002] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000020] Switching to timer-based delay loop, resolution 41ns
[    0.000553] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000916] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370868154 ns
[    0.001448] Console: colour dummy device 80x30
[    0.001531] printk: console [tty1] enabled
[    0.001612] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001631] pid_max: default: 32768 minimum: 301
[    0.002177] LSM: Security Framework initializing
[    0.002273] Yama: becoming mindful.
[    0.002594] AppArmor: AppArmor initialized
[    0.002887] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002912] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.004787] CPU: Testing write buffer coherency: ok
[    0.005445] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.006774] Setting up static identity map for 0x40100000 - 0x40100054
[    0.007026] rcu: Hierarchical SRCU implementation.
[    0.008899] smp: Bringing up secondary CPUs ...
[    0.020077] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.020286] smp: Brought up 1 node, 2 CPUs
[    0.020307] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.020318] CPU: All CPU(s) started in HYP mode.
[    0.020324] CPU: Virtualization extensions available.
[    0.022600] allocated 2097152 bytes of page_ext
[    0.023479] devtmpfs: initialized
[    0.035719] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[    0.036226] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.036293] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.042041] pinctrl core: initialized pinctrl subsystem
[    0.044040] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.049128] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.050008] audit: initializing netlink subsys (disabled)
[    0.050431] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[    0.051117] thermal_sys: Registered thermal governor 'fair_share'
[    0.051133] thermal_sys: Registered thermal governor 'bang_bang'
[    0.051142] thermal_sys: Registered thermal governor 'step_wise'
[    0.051546] cpuidle: using governor ladder
[    0.051586] cpuidle: using governor menu
[    0.052206] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.052274] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.063750] platform 1c16000.hdmi: Fixing up cyclic dependency with 1c0d000.lcd-controller
[    0.063844] platform 1c16000.hdmi: Fixing up cyclic dependency with 1c0c000.lcd-controller
[    0.072868] platform 1e40000.display-backend: Fixing up cyclic dependency with 1c0d000.lcd-controller
[    0.072966] platform 1e40000.display-backend: Fixing up cyclic dependency with 1c0c000.lcd-controller
[    0.073044] platform 1e40000.display-backend: Fixing up cyclic dependency with 1e20000.display-frontend
[    0.073152] platform 1e40000.display-backend: Fixing up cyclic dependency with 1e00000.display-frontend
[    0.073783] platform 1e60000.display-backend: Fixing up cyclic dependency with 1c0d000.lcd-controller
[    0.073891] platform 1e60000.display-backend: Fixing up cyclic dependency with 1c0c000.lcd-controller
[    0.073971] platform 1e60000.display-backend: Fixing up cyclic dependency with 1e20000.display-frontend
[    0.074047] platform 1e60000.display-backend: Fixing up cyclic dependency with 1e00000.display-frontend
[    0.076790] platform hdmi-connector: Fixing up cyclic dependency with 1c16000.hdmi
[    0.092135] cryptd: max_cpu_qlen set to 1000
[    0.164936] raid6: neonx8   gen()   706 MB/s
[    0.233038] raid6: neonx8   xor()   521 MB/s
[    0.301160] raid6: neonx4   gen()   754 MB/s
[    0.369246] raid6: neonx4   xor()   569 MB/s
[    0.437363] raid6: neonx2   gen()   828 MB/s
[    0.505477] raid6: neonx2   xor()   590 MB/s
[    0.573602] raid6: neonx1   gen()   737 MB/s
[    0.641705] raid6: neonx1   xor()   511 MB/s
[    0.709842] raid6: int32x8  gen()   274 MB/s
[    0.777936] raid6: int32x8  xor()   162 MB/s
[    0.846088] raid6: int32x4  gen()   320 MB/s
[    0.914162] raid6: int32x4  xor()   186 MB/s
[    0.982277] raid6: int32x2  gen()   361 MB/s
[    1.050407] raid6: int32x2  xor()   193 MB/s
[    1.118487] raid6: int32x1  gen()   364 MB/s
[    1.186650] raid6: int32x1  xor()   173 MB/s
[    1.186659] raid6: using algorithm neonx2 gen() 828 MB/s
[    1.186667] raid6: .... xor() 590 MB/s, rmw enabled
[    1.186674] raid6: using neon recovery algorithm
[    1.188689] iommu: Default domain type: Translated
[    1.188709] iommu: DMA domain TLB invalidation policy: strict mode
[    1.189216] SCSI subsystem initialized
[    1.189645] libata version 3.00 loaded.
[    1.190025] usbcore: registered new interface driver usbfs
[    1.190091] usbcore: registered new interface driver hub
[    1.190144] usbcore: registered new device driver usb
[    1.190301] mc: Linux media interface: v0.10
[    1.190362] videodev: Linux video capture interface: v2.00
[    1.190543] pps_core: LinuxPPS API ver. 1 registered
[    1.190554] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.190577] PTP clock support registered
[    1.191518] Advanced Linux Sound Architecture Driver Initialized.
[    1.192627] NetLabel: Initializing
[    1.192643] NetLabel:  domain hash size = 128
[    1.192652] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.192753] NetLabel:  unlabeled traffic allowed by default
[    1.193794] clocksource: Switched to clocksource arch_sys_counter
[    1.242841] VFS: Disk quotas dquot_6.6.0
[    1.243011] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.243857] AppArmor: AppArmor Filesystem Enabled
[    1.362433] NET: Registered PF_INET protocol family
[    1.362741] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.364229] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.364463] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.364511] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.364641] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.364772] TCP: Hash tables configured (established 8192 bind 8192)
[    1.364985] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.365077] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.365517] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.366158] Trying to unpack rootfs image as initramfs...
[    1.366513] armv7-pmu pmu: hw perfevents: no interrupt-affinity property, guessing.
[    1.367467] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.369545] Initialise system trusted keyrings
[    1.369681] Key type blacklist registered
[    1.370256] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    1.378090] zbud: loaded
[    1.380622] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.383528] fuse: init (API version 7.34)
[    1.395902] integrity: Platform Keyring initialized
[    1.518161] xor: measuring software checksum speed
[    1.526690]    arm4regs        :  1170 MB/sec
[    1.538952]    8regs           :   808 MB/sec
[    1.551891]    32regs          :   764 MB/sec
[    1.560256]    neon            :  1188 MB/sec
[    1.560277] xor: using function: neon (1188 MB/sec)
[    1.560300] Key type asymmetric registered
[    1.560310] Asymmetric key parser 'x509' registered
[    1.560753] bounce: pool size: 64 pages
[    1.560929] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.561548] io scheduler mq-deadline registered
[    1.561572] io scheduler kyber registered
[    1.561948] io scheduler bfq registered
[    1.567706] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pi not found, using dummy regulator
[    1.570878] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    1.586427] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    1.590685] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
[    1.591656] printk: console [ttyS0] disabled
[    1.591788] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 58, base_baud = 1500000) is a 16550A
[    1.592129] printk: console [ttyS0] enabled
[    1.594238] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 59, base_baud = 1500000) is a 16550A
[    1.594530] serial serial0: tty port ttyS2 registered
[    1.604367] sun4i-drm display-engine: bound 1e00000.display-frontend (ops 0xc0aa0b78)
[    1.604541] sun4i-drm display-engine: bound 1e20000.display-frontend (ops 0xc0aa0b78)
[    1.605170] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0aa0310)
[    1.605589] sun4i-drm display-engine: bound 1e40000.display-backend (ops 0xc0aa0310)
[    1.606411] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[    1.606457] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a9eb54)
[    1.607140] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[    1.607183] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xc0a9eb54)
[    1.611979] sun4i-drm display-engine: bound 1c16000.hdmi (ops 0xc0aa1534)
[    1.613257] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    1.678678] Console: switching to colour frame buffer device 240x67
[    1.734918] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device
[    1.744407] brd: module loaded
[    1.754579] loop: module loaded
[    1.758692] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator
[    1.759097] sun7i-dwmac 1c50000.ethernet: IRQ eth_wake_irq not found
[    1.759121] sun7i-dwmac 1c50000.ethernet: IRQ eth_lpi not found
[    1.759328] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
[    1.759390] sun7i-dwmac 1c50000.ethernet: no regulator found
[    1.759862] sun7i-dwmac 1c50000.ethernet: Version ID not available
[    1.759957] sun7i-dwmac 1c50000.ethernet:    DWMAC1000
[    1.759972] sun7i-dwmac 1c50000.ethernet: No HW DMA feature register supported
[    1.759984] sun7i-dwmac 1c50000.ethernet: TX Checksum insertion supported
[    1.759993] sun7i-dwmac 1c50000.ethernet: Normal descriptors
[    1.760002] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
[    2.776000] Freeing initrd memory: 17704K
[    2.789579] realtek: module verification failed: signature and/or required key missing - tainting kernel
[    2.801122] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.801178] ehci-platform: EHCI generic platform driver
[    2.801408] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.801503] ohci-platform: OHCI generic platform driver
[    2.802340] usbcore: registered new interface driver usb-storage
[    2.803702] sunxi-rtc 1c20d00.rtc: registered as rtc0
[    2.803765] sunxi-rtc 1c20d00.rtc: setting system clock to 1970-01-01T00:00:12 UTC (12)
[    2.803995] i2c_dev: i2c /dev entries driver
[    2.805606] axp20x-i2c 1-0034: AXP20x variant AXP209 found
[    2.813603] input: axp20x-pek as /devices/platform/soc/1c2ac00.i2c/i2c-1/1-0034/axp20x-pek/input/input0
[    2.822643] vdd-rtc: supplied by regulator-dummy
[    2.823559] avcc: supplied by regulator-dummy
[    2.824934] ldo3: supplied by regulator-dummy
[    2.825301] ldo4: supplied by regulator-dummy
[    2.826501] ldo5: supplied by regulator-dummy
[    2.827140] vdd-cpu: supplied by regulator-dummy
[    2.827945] vdd-int-dll: supplied by regulator-dummy
[    2.833212] axp20x-i2c 1-0034: Backup (RTC) battery charging is enabled
[    2.833355] axp20x-i2c 1-0034: AXP20X driver loaded
[    2.837329] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    2.838936] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
[    2.839254] sun4i-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
[    2.841195] ledtrig-cpu: registered to indicate activity on CPUs
[    2.841609] sun4i-ss 1c15000.crypto-engine: no reset control found
[    2.841739] sun4i-ss 1c15000.crypto-engine: Die ID 0
[    2.843218] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    2.846319] hid: raw HID events driver (C) Jiri Kosina
[    2.846506] usbcore: registered new interface driver usbhid
[    2.846516] usbhid: USB HID core driver
[    2.850217] debugfs: Directory '1c22c00.codec' with parent 'sun4i-codec' already present!
[    2.857039] Initializing XFRM netlink socket
[    2.858208] NET: Registered PF_INET6 protocol family
[    2.868530] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    2.906134] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.909176] mmc0: new high speed SDHC card at address aaaa
[    2.911620] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[    2.917164] Segment Routing with IPv6
[    2.917328] In-situ OAM (IOAM) with IPv6
[    2.917465] NET: Registered PF_PACKET protocol family
[    2.917514] NET: Registered PF_KEY protocol family
[    2.917622] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.918046] 8021q: 802.1Q VLAN Support v1.8
[    2.918165] Key type dns_resolver registered
[    2.918710] Registering SWP/SWPB emulation handler
[    2.919380]  mmcblk0: p1
[    2.919821] registered taskstats version 1
[    2.919846] Loading compiled-in X.509 certificates
[    2.928120] Loaded X.509 cert 'Build time autogenerated kernel key: 62fb46dab2422dc326e7fcb3f4661abeb2c583d1'
[    2.932971] zswap: loaded using pool zstd/z3fold
[    2.934346] Key type .fscrypt registered
[    2.934370] Key type fscrypt-provisioning registered
[    2.942741] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=yes
[    2.955855] Key type encrypted registered
[    2.955898] AppArmor: AppArmor sha1 policy hashing enabled
[    2.977410] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator
[    2.977629] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator
[    3.033833] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP
[    3.033857] ahci-sunxi 1c18000.sata: forcing PORTS_IMPL to 0x1
[    3.033933] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    3.033956] ahci-sunxi 1c18000.sata: flags: ncq sntf pm led clo only pio slum part ccc
[    3.036148] scsi host0: ahci-sunxi
[    3.036648] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 45
[    3.042965] of_cfs_init
[    3.043133] of_cfs_init: OK
[    3.043813] ALSA device list:
[    3.043834]   #0: sun4i-hdmi
[    3.043847]   #1: sun4i-codec
[    3.649797] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    3.651225] ata1.00: ATA-8: TOSHIBA MQ01ABD100, AX1R4F, max UDMA/100
[    3.651248] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32)
[    3.652678] ata1.00: configured for UDMA/100
[    3.653509] scsi 0:0:0:0: Direct-Access     ATA      TOSHIBA MQ01ABD1 4F   PQ: 0 ANSI: 5
[    3.654854] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    3.655121] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    3.655142] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    3.655230] sd 0:0:0:0: [sda] Write Protect is off
[    3.655246] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    3.655466] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.665175]  sda: sda1
[    3.666585] sd 0:0:0:0: [sda] Attached SCSI disk
[    3.673702] Freeing unused kernel image (initmem) memory: 1024K
[    3.678130] Run /init as init process
[    3.678156]   with arguments:
[    3.678166]     /init
[    3.678173]   with environment:
[    3.678180]     HOME=/
[    3.678187]     TERM=linux
[    3.678193]     splash=verbose
[    3.678200]     ubootpart=f3559229-01
[    3.678207]     ubootsource=mmc
[    3.678213]     sunxi_ve_mem_reserve=0
[    3.678220]     sunxi_g2d_mem_reserve=0
[    3.678226]     sunxi_fb_mem_reserve=16
[    3.678234]     cgroup_enable=memory
[    4.528758] sunxi-mmc 1c12000.mmc: allocated mmc-pwrseq
[    4.552999] sunxi-mmc 1c12000.mmc: initialized, max. request size: 16384 KB
[    4.600956] mmc1: new high speed SDIO card at address 0001
[    4.843758] sun5i-a13-gpadc-iio: Failed to locate of_node [id: 0]
[    4.979919] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
[    4.980019] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
[    4.980097] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
[    4.980182] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
[    5.030949] lima 1c40000.gpu: bus rate = 300000000
[    5.030990] lima 1c40000.gpu: mod rate = 384000000
[    5.064040] axp20x-gpio axp20x-gpio: DMA mask not set
[    5.067893] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
[    5.073002] [drm] Initialized lima 1.2.0 20200215 for 1c40000.gpu on minor 1
[    5.081474] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set
[    6.599189] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none.
[    7.478357] systemd[1]: System time before build time, advancing clock.
[    7.521132] systemd[1]: Inserted module 'autofs4'
[    7.629036] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    7.630163] systemd[1]: Detected architecture arm.
[    7.631280] systemd[1]: Detected first boot.
[    7.634254] systemd[1]: Hostname set to <cubietruck>.
[    7.639404] random: systemd: uninitialized urandom read (16 bytes read)
[    7.639546] systemd[1]: Initializing machine ID from random generator.
[   10.772421] systemd[1]: Failed to populate /etc with preset unit settings, ignoring: Read-only file system
[   11.611049] systemd[1]: Queued start job for default target Graphical Interface.
[   11.614663] random: systemd: uninitialized urandom read (16 bytes read)
[   11.623071] systemd[1]: Created slice Slice /system/modprobe.
[   11.624064] random: systemd: uninitialized urandom read (16 bytes read)
[   11.628158] systemd[1]: Created slice Slice /system/serial-getty.
[   11.628689] random: systemd: uninitialized urandom read (16 bytes read)
[   11.631526] systemd[1]: Created slice User and Session Slice.
[   11.633069] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   11.635853] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   11.637633] systemd[1]: Reached target Remote File Systems.
[   11.638387] systemd[1]: Reached target Slice Units.
[   11.639055] systemd[1]: Reached target Swaps.
[   11.639617] systemd[1]: Reached target System Time Set.
[   11.640946] systemd[1]: Reached target Local Verity Protected Volumes.
[   11.642968] systemd[1]: Listening on Syslog Socket.
[   11.644708] systemd[1]: Listening on fsck to fsckd communication Socket.
[   11.646022] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   11.648567] systemd[1]: Listening on Journal Audit Socket.
[   11.650337] systemd[1]: Listening on Journal Socket (/dev/log).
[   11.652226] systemd[1]: Listening on Journal Socket.
[   11.662086] systemd[1]: Listening on udev Control Socket.
[   11.663809] systemd[1]: Listening on udev Kernel Socket.
[   11.665708] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   11.673335] systemd[1]: Mounting POSIX Message Queue File System...
[   11.683792] systemd[1]: Mounting Kernel Debug File System...
[   11.695711] systemd[1]: Mounting Kernel Trace File System...
[   11.715525] systemd[1]: Starting Restore / save the current clock...
[   11.735580] systemd[1]: Starting Set the console keyboard layout...
[   11.749167] systemd[1]: Starting Create List of Static Device Nodes...
[   11.763679] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   11.798678] systemd[1]: Starting Load Kernel Module configfs...
[   11.819951] systemd[1]: Starting Load Kernel Module drm...
[   11.855317] systemd[1]: Starting Load Kernel Module efi_pstore...
[   11.873660] systemd[1]: Starting Load Kernel Module fuse...
[   11.894913] systemd[1]: Starting Load Kernel Module pstore_blk...
[   11.925283] systemd[1]: Starting Load Kernel Module pstore_zone...
[   11.945442] systemd[1]: Starting Load Kernel Module ramoops...
[   11.961012] systemd[1]: Started Nameserver information manager.
[   11.964172] systemd[1]: Reached target Preparation for Network.
[   11.972437] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   12.013011] systemd[1]: Starting Load Kernel Modules...
[   12.075148] systemd[1]: Starting Remount Root and Kernel File Systems...
[   12.132154] systemd[1]: Starting Coldplug All udev Devices...
[   12.207677] systemd[1]: Mounted POSIX Message Queue File System.
[   12.212650] systemd[1]: Mounted Kernel Debug File System.
[   12.222702] systemd[1]: Mounted Kernel Trace File System.
[   12.233567] systemd[1]: Finished Restore / save the current clock.
[   12.233972] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
[   12.254532] systemd[1]: Finished Create List of Static Device Nodes.
[   12.268866] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
[   12.275369] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[   12.283786] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   12.290295] systemd[1]: Finished Load Kernel Module configfs.
[   12.298902] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   12.306241] systemd[1]: Finished Load Kernel Module drm.
[   12.317206] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   12.319877] systemd[1]: Finished Load Kernel Module efi_pstore.
[   12.323900] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   12.335135] systemd[1]: Finished Load Kernel Module fuse.
[   12.338944] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[   12.350292] systemd[1]: Finished Load Kernel Module pstore_blk.
[   12.353998] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[   12.358965] systemd[1]: Finished Load Kernel Module pstore_zone.
[   12.365243] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[   12.376219] systemd[1]: Finished Load Kernel Module ramoops.
[   12.393335] systemd[1]: Finished Load Kernel Modules.
[   12.402984] systemd[1]: Finished Remount Root and Kernel File Systems.
[   12.430615] systemd[1]: Mounting FUSE Control File System...
[   12.460645] systemd[1]: Mounting Kernel Configuration File System...
[   12.487322] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   12.507100] systemd[1]: Starting Load/Save Random Seed...
[   12.543382] systemd[1]: Starting Apply Kernel Variables...
[   12.575263] systemd[1]: Starting Create System Users...
[   12.599263] systemd[1]: Mounted FUSE Control File System.
[   12.658767] random: systemd: uninitialized urandom read (16 bytes read)
[   12.661197] systemd[1]: Mounted Kernel Configuration File System.
[   12.714710] systemd[1]: Finished Create System Users.
[   12.726051] random: systemd: uninitialized urandom read (16 bytes read)
[   12.747442] systemd[1]: Starting Create Static Device Nodes in /dev...
[   12.846530] systemd[1]: Finished Apply Kernel Variables.
[   12.898162] systemd[1]: Finished Set the console keyboard layout.
[   12.968595] systemd[1]: Finished Create Static Device Nodes in /dev.
[   12.970698] random: systemd: uninitialized urandom read (16 bytes read)
[   12.971029] systemd[1]: Reached target Preparation for Local File Systems.
[   13.001016] systemd[1]: Mounting /tmp...
[   13.047859] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   13.070681] systemd[1]: Mounted /tmp.
[   13.079853] systemd[1]: Reached target Local File Systems.
[   13.111740] systemd[1]: Starting Load AppArmor profiles...
[   13.151507] systemd[1]: Starting Armbian leds state...
[   13.203448] systemd[1]: Starting Armbian ZRAM config...
[   13.259623] systemd[1]: Starting Set console font and keymap...
[   13.335278] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   13.359836] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   13.372125] systemd[1]: Finished Armbian leds state.
[   13.429686] systemd[1]: Finished Set console font and keymap.
[   13.467394] systemd[1]: Received SIGRTMIN+20 from PID 229 (plymouthd).
[   13.517540] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   14.021901] random: crng init done
[   14.021929] random: 48 urandom warning(s) missed due to ratelimiting
[   14.065237] systemd[1]: Finished Load/Save Random Seed.
[   14.072032] systemd[1]: Reached target First Boot Complete.
[   14.079979] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   14.133616] systemd[1]: Starting Commit a transient machine-id on disk...
[   14.207304] systemd[1]: Started Rule-based Manager for Device Events and Files.
[   14.572632] systemd[1]: Finished Coldplug All udev Devices.
[   14.608456] systemd[1]: etc-machine\x2did.mount: Deactivated successfully.
[   14.677506] systemd[1]: Finished Commit a transient machine-id on disk.
[   14.764582] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[   14.875256] systemd[1]: Starting Show Plymouth Boot Screen...
[   14.935289] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[   15.130054] systemd[1]: Started Show Plymouth Boot Screen.
[   15.132295] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   15.146608] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[   15.204418] zram: Added device: zram0
[   15.204609] systemd[1]: Reached target Local Encrypted Volumes.
[   15.234872] zram: Added device: zram1
[   15.236001] zram: Added device: zram2
[   15.673246] zram0: detected capacity change from 0 to 2029784
[   15.892587] Adding 1014888k swap on /dev/zram0.  Priority:5 extents:1 across:1014888k SSFS
[   17.550615] Registered IR keymap rc-empty
[   17.550853] rc rc0: sunxi-ir as /devices/platform/soc/1c21800.ir/rc/rc0
[   17.566079] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
[   17.566385] input: sunxi-ir as /devices/platform/soc/1c21800.ir/rc/rc0/input1
[   17.590162] sunxi-ir 1c21800.ir: initialized sunXi IR driver
[   17.610710] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
[   17.624935] systemd[1]: Found device /dev/ttyS0.
[   17.654006] cedrus 1c0e000.video-codec: Device registered as /dev/video0
[   18.026682] zram1: detected capacity change from 0 to 102400
[   18.063537] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[   18.082006] axp20x-adc axp20x-adc: DMA mask not set
[   18.372843] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   18.374574] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   18.393031] usb_phy_generic usb_phy_generic.0.auto: supply vcc not found, using dummy regulator
[   18.393278] usb_phy_generic usb_phy_generic.0.auto: dummy supplies not allowed for exclusive requests
[   18.394641] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[   18.394713] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[   18.430219] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[   18.430260] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   18.430274] usb usb1: Product: MUSB HDRC host driver
[   18.430283] usb usb1: Manufacturer: Linux 5.15.82-sunxi musb-hcd
[   18.430293] usb usb1: SerialNumber: musb-hdrc.1.auto
[   18.442327] hub 1-0:1.0: USB hub found
[   18.447999] hub 1-0:1.0: 1 port detected
[   18.455993] ehci-platform 1c14000.usb: EHCI Host Controller
[   18.456062] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 2
[   18.486246] ehci-platform 1c14000.usb: irq 41, io mem 0x01c14000
[   18.499024] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   18.502843] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[   18.503306] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[   18.503328] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   18.503341] usb usb2: Product: EHCI Host Controller
[   18.503350] usb usb2: Manufacturer: Linux 5.15.82-sunxi ehci_hcd
[   18.503359] usb usb2: SerialNumber: 1c14000.usb
[   18.504245] hub 2-0:1.0: USB hub found
[   18.504323] hub 2-0:1.0: 1 port detected
[   18.505896] ehci-platform 1c1c000.usb: EHCI Host Controller
[   18.505952] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
[   18.542444] ehci-platform 1c1c000.usb: irq 46, io mem 0x01c1c000
[   18.557911] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[   18.558428] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[   18.558452] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   18.558464] usb usb3: Product: EHCI Host Controller
[   18.558473] usb usb3: Manufacturer: Linux 5.15.82-sunxi ehci_hcd
[   18.558482] usb usb3: SerialNumber: 1c1c000.usb
[   18.559496] hub 3-0:1.0: USB hub found
[   18.559590] hub 3-0:1.0: 1 port detected
[   18.561029] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[   18.561076] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 4
[   18.582047] ohci-platform 1c14400.usb: irq 42, io mem 0x01c14400
[   18.646323] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[   18.646375] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   18.646395] usb usb4: Product: Generic Platform OHCI controller
[   18.646418] usb usb4: Manufacturer: Linux 5.15.82-sunxi ohci_hcd
[   18.646433] usb usb4: SerialNumber: 1c14400.usb
[   18.647685] hub 4-0:1.0: USB hub found
[   18.647793] hub 4-0:1.0: 1 port detected
[   18.649635] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[   18.649692] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 5
[   18.653412] systemd[1]: Starting Load Kernel Module efi_pstore...
[   18.661064] ohci-platform 1c1c400.usb: irq 47, io mem 0x01c1c400
[   18.758355] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[   18.758397] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   18.758409] usb usb5: Product: Generic Platform OHCI controller
[   18.758419] usb usb5: Manufacturer: Linux 5.15.82-sunxi ohci_hcd
[   18.758428] usb usb5: SerialNumber: 1c1c400.usb
[   18.763455] hub 5-0:1.0: USB hub found
[   18.763578] hub 5-0:1.0: 1 port detected
[   18.770855] systemd[1]: Starting Load Kernel Module pstore_blk...
[   18.948357] systemd[1]: Starting Load Kernel Module pstore_zone...
[   18.978601] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   18.999821] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   19.113000] systemd[1]: Starting Load Kernel Module ramoops...
[   19.171266] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   19.171877] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   19.283373] audit: type=1400 audit(1670829051.436:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=348 comm="apparmor_parser"
[   19.303004] systemd[1]: Finished Armbian ZRAM config.
[   19.354099] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
[   19.362415] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[   19.393589] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   19.410571] systemd[1]: Finished Load Kernel Module efi_pstore.
[   19.451134] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[   19.474978] systemd[1]: Finished Load Kernel Module pstore_blk.
[   19.511235] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[   19.530961] systemd[1]: Finished Load Kernel Module pstore_zone.
[   19.558014] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1
[   19.571913] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43362-sdio.cubietech,cubietruck.bin failed with error -2
[   19.571948] brcmfmac mmc1:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43362-sdio.cubietech,cubietruck.bin
[   19.592804] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[   19.595506] systemd[1]: Finished Load Kernel Module ramoops.
[   19.690794] Bluetooth: Core ver 2.22
[   19.691027] NET: Registered PF_BLUETOOTH protocol family
[   19.691037] Bluetooth: HCI device and connection manager initialized
[   19.691063] Bluetooth: HCI socket layer initialized
[   19.691076] Bluetooth: L2CAP socket layer initialized
[   19.691119] Bluetooth: SCO socket layer initialized
[   20.116946] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   20.118584] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   20.128311] systemd[1]: Starting Armbian memory supported logging...
[   20.147870] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   20.199141] systemd[1]: Starting Load Kernel Module efi_pstore...
[   20.256668] systemd[1]: Starting Load Kernel Module pstore_blk...
[   20.257892] Bluetooth: HCI UART driver ver 2.3
[   20.257924] Bluetooth: HCI UART protocol H4 registered
[   20.257931] Bluetooth: HCI UART protocol BCSP registered
[   20.258115] Bluetooth: HCI UART protocol LL registered
[   20.258126] Bluetooth: HCI UART protocol ATH3K registered
[   20.258209] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   20.258608] Bluetooth: HCI UART protocol Broadcom registered
[   20.259149] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[   20.259450] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[   20.326954] systemd[1]: Starting Load Kernel Module pstore_zone...
[   20.395459] systemd[1]: Starting Load Kernel Module ramoops...
[   20.419230] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   20.419774] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   20.667144] Bluetooth: hci0: BCM: chip id 63
[   20.669961] Bluetooth: hci0: BCM: features 0x07
[   20.686633] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
[   20.693641] Bluetooth: hci0: BCM20702A
[   20.693690] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[   20.711213] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[   20.781716] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   20.847207] systemd[1]: Finished Load Kernel Module efi_pstore.
[   20.902817] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[   20.921141] systemd[1]: Finished Load Kernel Module pstore_blk.
[   20.989520] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[   21.016227] systemd[1]: Finished Load Kernel Module pstore_zone.
[   21.021026] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[   21.038501] systemd[1]: Finished Load Kernel Module ramoops.
[   21.124730] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none.
[   21.552851] systemd[1]: Reached target Hardware activated USB gadget.
[   21.596360] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   21.597251] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   21.689568] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   21.692456] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43362-sdio.cubietech,cubietruck.txt failed with error -2
[   21.692497] brcmfmac mmc1:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43362-sdio.cubietech,cubietruck.txt
[   21.879646] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[   21.879678] Bluetooth: hci0: BCM: 'brcm/BCM20702A1.hcd'
[   21.879686] Bluetooth: hci0: BCM: 'brcm/BCM.hcd'
[   22.011918] systemd[1]: Started Load/Save RF Kill Switch Status.
[   22.013709] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   22.023536] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   22.044168] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   22.052587] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1
[   22.058186] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[   22.059014] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43362/1 wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d
[   22.109514] systemd[1]: Starting Load Kernel Module efi_pstore...
[   22.195195] systemd[1]: Starting Load Kernel Module pstore_blk...
[   22.252378] systemd[1]: Starting Load Kernel Module pstore_zone...
[   22.326202] systemd[1]: Starting Load Kernel Module ramoops...
[   22.339537] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   22.340234] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   22.384636] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
[   22.406535] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[   22.431506] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   22.442593] systemd[1]: Finished Load Kernel Module efi_pstore.
[   22.453380] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[   22.464120] systemd[1]: Finished Load Kernel Module pstore_blk.
[   22.485185] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[   22.496411] systemd[1]: Finished Load Kernel Module pstore_zone.
[   22.522547] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[   22.527316] systemd[1]: Finished Load Kernel Module ramoops.
[   22.540038] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   22.959001] audit: type=1400 audit(1670829055.112:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=481 comm="apparmor_parser"
[   22.968179] audit: type=1400 audit(1670829055.120:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=481 comm="apparmor_parser"
[   23.979837] audit: type=1400 audit(1670829056.132:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=347 comm="apparmor_parser"
[   24.004600] audit: type=1400 audit(1670829056.156:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=347 comm="apparmor_parser"
[   26.426544] audit: type=1400 audit(1670829058.580:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=590 comm="apparmor_parser"
[   26.451537] audit: type=1400 audit(1670829058.604:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=590 comm="apparmor_parser"
[   26.466920] audit: type=1400 audit(1670829058.620:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=590 comm="apparmor_parser"
[   26.492854] audit: type=1400 audit(1670829058.644:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/{,usr/}sbin/dhclient" pid=590 comm="apparmor_parser"
[   27.187985] systemd[1]: systemd-rfkill.service: Deactivated successfully.
[   28.158815] audit: type=1400 audit(1670829060.312:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=593 comm="apparmor_parser"
[   28.171468] audit: type=1400 audit(1670829060.324:12): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=593 comm="apparmor_parser"
[   28.280198] audit: type=1400 audit(1670829060.432:13): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=593 comm="apparmor_parser"
[   29.792307] systemd[1]: Finished Armbian memory supported logging.
[   29.826957] systemd[1]: Starting Journal Service...
[   30.451946] audit: type=1400 audit(1670829062.604:14): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/redshift" pid=602 comm="apparmor_parser"
[   30.606964] systemd[1]: Started Journal Service.
[   30.753316] systemd-journald[618]: Received client request to flush runtime journal.
[   31.492337] audit: type=1400 audit(1670829063.644:15): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oosplash" pid=619 comm="apparmor_parser"
[   32.169473] audit: type=1400 audit(1670829064.320:16): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=624 comm="apparmor_parser"
[   33.769901] vcc3v0: disabling
[   33.769940] vcc5v0: disabling
[   42.516063] sysfs: cannot create duplicate filename '/devices/platform/soc/1c16000.hdmi/dma:audio-tx'
[   42.516122] CPU: 1 PID: 120 Comm: kworker/1:17 Tainted: G         C  E     5.15.82-sunxi #trunk
[   42.516142] Hardware name: Allwinner sun7i (A20) Family
[   42.516152] Workqueue: events output_poll_execute
[   42.516194] [<c010cd21>] (unwind_backtrace) from [<c01095fd>] (show_stack+0x11/0x14)
[   42.516225] [<c01095fd>] (show_stack) from [<c09e153d>] (dump_stack_lvl+0x2b/0x34)
[   42.516252] [<c09e153d>] (dump_stack_lvl) from [<c031aee1>] (sysfs_warn_dup+0x49/0x54)
[   42.516280] [<c031aee1>] (sysfs_warn_dup) from [<c031b113>] (sysfs_do_create_link_sd+0x87/0xa8)
[   42.516303] [<c031b113>] (sysfs_do_create_link_sd) from [<c060130f>] (dma_request_chan+0xb3/0x1ec)
[   42.516328] [<c060130f>] (dma_request_chan) from [<c08579fd>] (snd_dmaengine_pcm_register+0x85/0x148)
[   42.516355] [<c08579fd>] (snd_dmaengine_pcm_register) from [<c067c121>] (sun4i_hdmi_audio_create+0x1d/0x134)
[   42.516382] [<c067c121>] (sun4i_hdmi_audio_create) from [<c067c947>] (sun4i_hdmi_enable+0xff/0x124)
[   42.516403] [<c067c947>] (sun4i_hdmi_enable) from [<c064a5ff>] (drm_atomic_helper_commit_modeset_enables+0x13f/0x16c)
[   42.516428] [<c064a5ff>] (drm_atomic_helper_commit_modeset_enables) from [<c064ada9>] (drm_atomic_helper_commit_tail_rpm+0x1d/0x4c)
[   42.516449] [<c064ada9>] (drm_atomic_helper_commit_tail_rpm) from [<c064b073>] (commit_tail+0x73/0x148)
[   42.516469] [<c064b073>] (commit_tail) from [<c064baa9>] (drm_atomic_helper_commit+0xd1/0xf0)
[   42.516489] [<c064baa9>] (drm_atomic_helper_commit) from [<c066fdcb>] (drm_client_modeset_commit_atomic+0x15b/0x184)
[   42.516514] [<c066fdcb>] (drm_client_modeset_commit_atomic) from [<c066fe73>] (drm_client_modeset_commit_locked+0x3b/0x104)
[   42.516534] [<c066fe73>] (drm_client_modeset_commit_locked) from [<c066ff57>] (drm_client_modeset_commit+0x1b/0x2c)
[   42.516553] [<c066ff57>] (drm_client_modeset_commit) from [<c064fa17>] (__drm_fb_helper_restore_fbdev_mode_unlocked+0x6f/0x88)
[   42.516577] [<c064fa17>] (__drm_fb_helper_restore_fbdev_mode_unlocked) from [<c064fa91>] (drm_fb_helper_set_par+0x2d/0x4c)
[   42.516596] [<c064fa91>] (drm_fb_helper_set_par) from [<c064fb1f>] (drm_fb_helper_hotplug_event.part.5+0x6f/0x80)
[   42.516614] [<c064fb1f>] (drm_fb_helper_hotplug_event.part.5) from [<c066f6e1>] (drm_client_dev_hotplug+0x4d/0x78)
[   42.516633] [<c066f6e1>] (drm_client_dev_hotplug) from [<c0641d83>] (output_poll_execute+0x17b/0x190)
[   42.516658] [<c0641d83>] (output_poll_execute) from [<c0130dff>] (process_one_work+0x18f/0x3e8)
[   42.516683] [<c0130dff>] (process_one_work) from [<c013115b>] (worker_thread+0x103/0x410)
[   42.516700] [<c013115b>] (worker_thread) from [<c0136b13>] (kthread+0x117/0x12c)
[   42.516726] [<c0136b13>] (kthread) from [<c0100139>] (ret_from_fork+0x11/0x38)
[   42.516747] Exception stack(0xc1dbffb0 to 0xc1dbfff8)
[   42.516759] ffa0:                                     00000000 00000000 00000000 00000000
[   42.516772] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   42.516783] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
[   42.516805] sun4i-hdmi 1c16000.hdmi: Cannot create DMA dma:audio-tx symlink
[   69.982145] audit: type=1400 audit(1670829102.032:17): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince" pid=591 comm="apparmor_parser"
[   69.997331] audit: type=1400 audit(1670829102.148:18): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince//sanitized_helper" pid=591 comm="apparmor_parser"
[   70.116034] audit: type=1400 audit(1670829102.268:19): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince-previewer" pid=591 comm="apparmor_parser"
[   70.128814] audit: type=1400 audit(1670829102.280:20): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince-previewer//sanitized_helper" pid=591 comm="apparmor_parser"
[   70.192766] audit: type=1400 audit(1670829102.344:21): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince-thumbnailer" pid=591 comm="apparmor_parser"
[   70.623792] audit: type=1400 audit(1670829102.776:22): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=638 comm="apparmor_parser"
[   74.120602] audit: type=1400 audit(1670829106.272:23): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=639 comm="apparmor_parser"
[   74.129597] audit: type=1400 audit(1670829106.280:24): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=639 comm="apparmor_parser"
[   75.476688] audit: type=1400 audit(1670829107.628:25): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/chronyd" pid=640 comm="apparmor_parser"
[   79.521677] audit: type=1400 audit(1670829111.672:26): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=641 comm="apparmor_parser"
[   79.545330] audit: type=1400 audit(1670829111.696:27): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd" pid=641 comm="apparmor_parser"
[   79.548410] audit: type=1400 audit(1670829111.700:28): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd//third_party" pid=641 comm="apparmor_parser"
[   79.996143] audit: type=1400 audit(1670829112.148:29): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/haveged" pid=642 comm="apparmor_parser"
[  156.615663] audit: type=1400 audit(1670829188.768:30): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-soffice" pid=625 comm="apparmor_parser"
[  156.634402] audit: type=1400 audit(1670829188.788:31): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-soffice//gpg" pid=625 comm="apparmor_parser"
[  161.257464] EXT4-fs (mmcblk0p1): resizing filesystem from 1540096 to 3849216 blocks
[  172.742157] EXT4-fs (mmcblk0p1): resized to 3670016 blocks
[  173.722731] EXT4-fs (mmcblk0p1): resized filesystem to 3849216
[  189.520645] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[  189.520687] Bluetooth: BNEP filters: protocol multicast
[  189.520731] Bluetooth: BNEP socket layer initialized
[  189.829909] NET: Registered PF_ALG protocol family
[  190.629212] audit: type=1400 audit(1670829222.780:32): apparmor="DENIED" operation="capable" profile="/usr/sbin/cupsd" pid=1886 comm="cupsd" capability=12  capname="net_admin"
[  191.841392] loop0: detected capacity change from 0 to 8
[  196.485679] phy_rtl8211e_led_fixup in
[  196.506050] sun7i-dwmac 1c50000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
[  196.507841] sun7i-dwmac 1c50000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[  196.511084] sun7i-dwmac 1c50000.ethernet eth0: No Safety Features support found
[  196.511116] sun7i-dwmac 1c50000.ethernet eth0: RX IPC Checksum Offload disabled
[  196.511133] sun7i-dwmac 1c50000.ethernet eth0: No MAC Management Counters available
[  196.511146] sun7i-dwmac 1c50000.ethernet eth0: PTP not supported by HW
[  196.562090] sun7i-dwmac 1c50000.ethernet eth0: configuring for phy/rgmii-id link mode
[  199.305948] ieee80211 phy0: brcmf_p2p_create_p2pdev: timeout occurred
[  199.305996] ieee80211 phy0: brcmf_cfg80211_add_iface: add iface p2p-dev-wlan0 type 10 failed: err=-5
[  199.626882] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  199.626967] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  207.402942] audit: type=1400 audit(1670829239.553:33): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=1998 comm="apparmor_parser"
[  207.527126] audit: type=1400 audit(1670829239.677:34): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=1998 comm="apparmor_parser"
[  258.294620] usb 5-1: new full-speed USB device number 2 using ohci-platform
[  258.527798] usb 5-1: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[  258.527848] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  258.527861] usb 5-1: Product: USB Receiver
[  258.527870] usb 5-1: Manufacturer: Logitech
[  258.547553] input: Logitech USB Receiver as /devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.0/0003:046D:C534.0001/input/input2
[  258.608877] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-1c1c400.usb-1/input0
[  258.622687] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/input/input3
[  258.631136] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/input/input4
[  258.691383] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/input/input5
[  258.696257] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-1c1c400.usb-1/input1
[  259.023359] logitech-djreceiver 0003:046D:C534.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-1c1c400.usb-1/input0
[  259.177575] logitech-djreceiver 0003:046D:C534.0002: hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-1c1c400.usb-1/input1
[  259.244665] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 1
[  259.246656] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 2
[  259.283361] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input8
[  259.290735] hid-generic 0003:046D:4023.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-1c1c400.usb-1/input1:1
[  259.293994] input: Logitech Wireless Mouse PID:4054 Mouse as /devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/0003:046D:4054.0004/input/input13
[  259.322827] hid-generic 0003:046D:4054.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4054] on usb-1c1c400.usb-1/input1:2
[  260.189919] input: Logitech Wireless Keyboard PID:4023 as /devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input17
[  260.202826] logitech-hidpp-device 0003:046D:4023.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-1c1c400.usb-1/input1:1
[  260.233188] input: Logitech Wireless Mouse as /devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/0003:046D:4054.0004/input/input18
[  260.233924] logitech-hidpp-device 0003:046D:4054.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-1c1c400.usb-1/input1:2
[  261.208859] logitech-hidpp-device 0003:046D:4023.0003: HID++ 2.0 device connected.
[  325.980018] usb 5-1: USB disconnect, device number 2
>>>>>>>>>>>>>>>>>>>>>>>>>>[  370.220499] lima 1c40000.gpu: gp error irq state=6000 status=1
>>>>>>>>>>>>>>>>>>>>>>>>>>[  370.221423] lima 1c40000.gpu: fail to save task state from Xorg pid 3473: error task list is full
>>>>>>>>>>>>>>>>>>>>>>>>>>[  370.221456] lima 1c40000.gpu: gp task error int_state=0 status=0
[  379.591268] Bluetooth: RFCOMM TTY layer initialized
[  379.591345] Bluetooth: RFCOMM socket layer initialized
[  379.591404] Bluetooth: RFCOMM ver 1.11
I got the same issue on my Cubietruck. With the official images, my TV even said there is no signal when the Cubietruck loads the Desktop. With the latest image provided by Voka, the signal seems to be there, but I still got a black screen, just like Josue Turco. After searching the net for the lima 1c40000.gpu: mmu page fault prints, I found a very similar issue in the mesa tracker: https://gitlab.freedesktop.org/mesa/mesa/-/issues/5707 . There was even a patch provided (by https://gitlab.freedesktop.org/dorna8550) that seems to fix the problem (https://gitlab.freedesktop.org/mesa/mesa/uploads/64e8736c6a935e91a6547fd22f2051e6/0001-Modify-MBUS-Driver-to-get-Mali-working-on-Sunxi-A20.patch). Unfortunately I have not set up the build environment for creating an Image for the Cubietruck with that patch to test it.
I set up the build environment, cloned the repository and placed the mentioned patch file in the user patches location: <git repo>/userpatches/kernel/archive/sunxi-5.15/0001-Modify-MBUS-Driver-to-get-Mali-working-on-Sunxi-A20.patch . After invoking the compile command (similar to Voka's suggestion, but without docker and less entries in DESKTOP_APPGROUPS_SELECTED) and some patience, I got an image for the Cubietruck that finally boots up with the xfce desktop on the TV that was attached via HDMI.
