I migrated my dashboard project from a BananaPro under "Buster" to a BananaPI under "Bullseye", image took from the website, verified and up to date as per Armbian-config.
The source code of my project is exactly the same as well a the compilation procedure, and the used Makefile is :
cc=cc
opts=-Wall -fPIC   $(shell pkg-config --cflags lua5.1 ) $(shell pkg-config --libs lua5.1 ) 	-DDRMC_WITH_FB -DUSE_DRMCAIRO $(shell pkg-config --cflags libdrm cairo freetype2 ) -DKMS_MISSING $(shell pkg-config --libs libdrm cairo freetype2 ) 	  	  	  	 	-DPLUGIN_DIR='"/home/laurent/Projets/Selene"' -L/home/laurent/Projets/Selene 	-L/home/laurent/Projets/Selene -lSelene -lpaho-mqtt3c $(shell pkg-config --cflags lua5.1 ) -lm -ldl -Wl,--export-dynamic -lpthread
selene.o : selene.c SeleneLibrary/libSelene.h version.h Makefile
	$(cc) -c -o selene.o selene.c $(opts)
../Selene : selene.o Makefile
	 $(cc) -o ../Selene selene.o $(opts)
all: ../Selene
Note : DRM, Cairo and Freetype libraries are not used in  selene.c itself but in .so which are dynamically loaded (full source code can be found on https://github.com/destroyedlolo/Selene
The problem : my projet is perfectly working on my Gentoo development box, as well on BananaPro/Buster but on the BananaPI/Bullseye, it's falling complaining about missing libraries :
laurent@TdB:~/Projets/Selene$ ./Selene SelenitesDRMCairo/Gfx.sel
./Selene: symbol lookup error: /home/laurent/Projets/Selene/SelDRMCairo.so: undefined symbol: FT_Init_FreeType
The root cause can be found with ldd
On working boxes (here gentoo one) :
laurent@torchwood ~ $ ldd /usr/local/bin/Selene
	liblua.so.5 => /usr/lib/liblua.so.5 (0xb6f23000)
	libm.so.6 => /lib/libm.so.6 (0xb6eb6000)
	libdrm.so.2 => /usr/lib/libdrm.so.2 (0xb6e96000)
	libcairo.so.2 => /usr/lib/libcairo.so.2 (0xb6dbe000)
	libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0xb6d1a000)
	libkms.so.1 => /usr/lib/libkms.so.1 (0xb6d07000)
	libpthread.so.0 => /lib/libpthread.so.0 (0xb6b7d000)
	libSelene.so => /usr/local/lib/libSelene.so (0xb6abc000)
	libpaho-mqtt3c.so.1 => /usr/local/lib/libpaho-mqtt3c.so.1 (0xb6a1a000)
	libdl.so.2 => /lib/libdl.so.2 (0xb6a07000)
	libc.so.6 => /lib/libc.so.6 (0xb68bf000)
	/lib/ld-linux-armhf.so.3 (0xb6f7c000)
whereas drm cairo freetype2 and dependancies are missing on the Bullseye box
laurent@TdB:~/Projets/Selene$ ldd Selene
	linux-vdso.so.1 (0xbef14000)
	liblua5.1.so.0 => /lib/arm-linux-gnueabihf/liblua5.1.so.0 (0xb6f38000)
	libSelene.so => /home/laurent/Projets/Selene/libSelene.so (0xb6f16000)
	libpaho-mqtt3c.so.1 => /lib/arm-linux-gnueabihf/libpaho-mqtt3c.so.1 (0xb6e70000)
	libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb6e5d000)
	libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6d5e000)
	libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xb6cf6000)
	/lib/ld-linux-armhf.so.3 (0xb6f74000)
	libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb6cd0000)
Does someone having any tips why libraries are not referenced under Bullseye ?
Thanks
Laurent
I'm suspecting a change/optimisation within GCC 10.
I tried to use -rdynamic which is supposed to add all symbols, including not used ones ... but it doesn't change anything.
I don't find a solution and it's blocking : I'm return back to Buster for my dashboard but I'm still investigating on other board.
There is not really a need to upgrade to Bullseye since Buster will be supported upstream for a few more years unless you need specific packages in newer versions that are not available via backports.
Hi, thanks for your reply.
The only package missing in Buster is libpaho-mqtt-dev so I installed it from source.
Anyway, I'll investigate about this issue as one day or another, my Gentoo boxes will move to GCC 10 (and in case someone will use my tool on recent distribs).
odd that works, I would link:
cc -o .. ... -L<path-to-so> -lSelDRMCairo -l<other-sel-so>-lcairo .....
as a shared object is not linked to any library but simply a position independent object file.
I did a try on my Gentoo PC using GCC 10.3.0 (same code, same Makefile, ...).
Libraries are correctly included :
ldd Selene
	linux-vdso.so.1 (0x00007ffdcb866000)
	liblua5.3.so.0 => /usr/lib64/liblua5.3.so.0 (0x00007fa2a4efc000)
	libm.so.6 => /lib64/libm.so.6 (0x00007fa2a4dc8000)
	libdrm.so.2 => /usr/lib64/libdrm.so.2 (0x00007fa2a4db3000)
	libcairo.so.2 => /usr/lib64/libcairo.so.2 (0x00007fa2a4c7a000)
	libfreetype.so.6 => /usr/lib64/libfreetype.so.6 (0x00007fa2a4bb1000)
	libSelene.so => /usr/local/lib/libSelene.so (0x00007fa2a4b94000)
	libpaho-mqtt3c.so.1 => /usr/local/lib64/libpaho-mqtt3c.so.1 (0x00007fa2a4ada000)
	libdl.so.2 => /lib64/libdl.so.2 (0x00007fa2a4ad4000)
	libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fa2a4ab4000)
	libc.so.6 => /lib64/libc.so.6 (0x00007fa2a48fb000)
	/lib64/ld-linux-x86-64.so.2 (0x00007fa2a4f5b000)
	libpixman-1.so.0 => /usr/lib64/libpixman-1.so.0 (0x00007fa2a4857000)
	libfontconfig.so.1 => /usr/lib64/libfontconfig.so.1 (0x00007fa2a4810000)
So the problem is with the way  Bullseye is configured (Gcc or the linker or whatever).
Note : GCC is compiled with the default options, no trick, no cheat, only optimized for my processor.
Bye
Laurent
a test as been done on Raspbian Bullseye and it's not working as well with the same error.
Options suggested by xwiggen are already included :unsure:
It seems the problem is related to something upstream.
Any idea ?
