Flolm Posted November 29, 2021 Posted November 29, 2021 Hello, I have a Helio64 not yet configured and I would like to be able to install the latest image available on https://armbian.hosthatch.com/dl/helios64/archive/ and especially to install the latest OpenMediaVault 6 version. Do you think this is possible ? Or will OpenMediaVault 6 not be available from armbian-config? As I write this post, the latest image available for Helios64 is Armbian_21.05.9_Helios64_bullseye_current_5.10.63.img.xz I thank you for your help Flolm 0 Quote
bunducafe Posted November 29, 2021 Posted November 29, 2021 Go ahead, OMV6 works fairly well with the Helios64... there are some bits and pieces that are not completely ported (plugins for example) and some need a bit of adjustment whatsoever. But all in all it is okay. I am running OMV6 together with SnapRaid. MergerFS and Luks I am running outside of OMV as I do find it easier to customize for my needs. 1 Quote
Vin Posted December 7, 2021 Posted December 7, 2021 Is there any performance difference among OMV5 and OMV6 SMB/Ethernet wise? 0 Quote
bunducafe Posted December 10, 2021 Posted December 10, 2021 On 12/7/2021 at 3:53 PM, Vin said: Is there any performance difference among OMV5 and OMV6 SMB/Ethernet wise? Expand Hm, that always depends on the setup. I am in the Apple universe and I find that SMB works a bit faster on OMV6 but as you can edit the preferences yourself there should not be too much of an issue to modify this to your needs. 0 Quote
