dudepron Posted December 7, 2021 Posted December 7, 2021 Trying to debug this issue. Everything was fine until a recent reboot and now the box is stuck in a boot loop with any supported image downloaded from armbian. I've been focused with debian but the ubuntu doesn't work either. I have tried 3 different microSD cards (samsung and SanDisk) with the same result. I've tried the steps in https://docs.armbian.com/User-Guide_Basic-Troubleshooting/ https://docs.armbian.com/User-Guide_Recovery/ but it appears that the there is something going on with the Linux kernel? changing the verbosity doesn't provide any new information. I have even tried 20.05.1 and still the same behavior. Any thoughts on possible next steps?
dudepron Posted December 7, 2021 Author Posted December 7, 2021 forgot to attach cubox.txt I stand corrected. I forgot to add the console=serial. Wondering if this is a HW issue. I don't see any errors during boot. It just reboots. I'll try to get some logs posted...
Igor Posted December 7, 2021 Posted December 7, 2021 Our test hardware (Cubox i4) works http://ix.io/3HgE but this doesn't mean all variants (we only have one device) and kernels are covered. I can't tell from those logs what is wrong. BTW. We are going to put a lot of devices into retirement, probably also this one since nobody beside me has it and I have no time for any research anytime soon.
dudepron Posted December 7, 2021 Author Posted December 7, 2021 I appreciate the response. It is a recent issue. I do not recall doing any big upgrades, besides having the zram /var disk fill up with journal entries. I suspect HW at the moment. It does boot the kernel but it does reboot sometimes after 11 - 14 seconds. I will work on posting that output today.
djElementDC Posted December 10, 2021 Posted December 10, 2021 Hey @dudepronI have exactly the same issue - but using two different SD cards using different distros. I also suspect HW. Coincidence? Did they put a timer on this thing to just start failing after a certain number of years After like 15 successive reboots, sometimes it will load the OS... but it's basically failing. I wonder if there's anything comparable to buy - I kind of just want to buy a new one, but a lot of the recent distros don't support the hardware anymore.
Dirk_P_Broer Posted January 19, 2022 Posted January 19, 2022 I recently installed Armbian on my HummingBoard-i4ex (same Freescale I.MX6 SOC, same board manufacturer SolidRun) -and re-installed it when it all of a sudden it didn't recognize the password anymore after a reboot. I have no problems running it with putty from a Windows box, but I have no HDMI output from the board.
