Armbianmonitor:
Hi forum members,
I enabled the 1w protocol via armbian.config and found, that the default GPIO pin assignment is set to 110 (what is PD14)
root@bananapim2zero:/sys/bus/w1/devices# cat  /sys/kernel/debug/gpio
gpiochip0: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl:
 gpio-110 (                    |onewire@0           ) out lo
dmesg | grep -E 'w1|wire' | grep -E 'Driver|gpio-'
[    5.659452] Driver for 1-wire Dallas network protocol.
[    6.408704] gpio-110 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
Please can someone tell me what phyical pin is this gpio-110 on my BPI m2 zero ?
I reconfigured my board via /boot/ambianEnv.txt to use the PA6 pin what is the physical pin 7.
Everything worked fine and I can read out the temperature from the onewire sensor DS18S connected on the physical pin 7.
I'm ask for help on this topic because I want to use the PD14 GPIO pin since I can configure the internal pullup resistor instead using an external pullup resistor,
Thanks in advance
wollik
  • wollik changed the title to `Physical pin of 1w-gpio, w1-therm
