gounthar Posted January 5, 2022 Posted January 5, 2022 Armbianmonitor: http://ix.io/3L8d Hello there, I have an Orange Pi Zero running Armbian 22.02.0-trunk.0003 Bullseye with Linux 5.10.89-sunxi. I have followed this thread about H3 and SPI, but it does not work for me. I have checked the right (?) options in armbian-config, added spi0-spidev in armbianEnv.txt. Here is my armbianEnv.txt: verbosity=1 bootlogo=false console=serial disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 overlays=i2c0 pwm spi-add-cs1 spi-jedec-nor spi-spidev usbhost2 usbhost3 spi0-spidev rootdev=UUID=1244dc6c-1888-4768-9cbd-922ca4cc3436 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u I don't have any spi subfolder in /dev. I'm almost sure I have forgotten something really trivial, but I can't see what for the time being. Can anyone point me the obvious mistake I made? Thanks.
Werner Posted January 5, 2022 Posted January 5, 2022 Moved to Common issues / peer to peer technical support since unsupported image/build. 1
gounthar Posted January 5, 2022 Author Posted January 5, 2022 Thank you Werner. I will try on a supported version of Armbian with another Zero and see what I get.
FurretUber Posted January 11, 2022 Posted January 11, 2022 It is possible that there are some options missing from armbianEnv.txt. On my Banana Pi M2 Zero, beyond setting the overlays, some additional settings had to be added to armbianEnv.txt. These options are: param_spidev_spi_bus=1 param_spidev_spi_cs=0 If I understood the page about the OrangePi Zero (https://linux-sunxi.org/Xunlong_Orange_Pi_Zero), using BUS 1 and CS 0 should work (however, I don't have one to test). You can find a more complete description about all possible parameters for armbianEnv.txt for the H3 on the page https://github.com/armbian/sunxi-DT-overlays/tree/master/sun8i-h3 1
Artur_M Posted March 18, 2022 Posted March 18, 2022 On 1/11/2022 at 4:36 PM, gounthar said: Thank you FurretUber, I'll try that. Did you solve this issue? I have similar issue on 22.02 - I can't enable SPI
Artur_M Posted March 18, 2022 Posted March 18, 2022 2 minutes ago, gounthar said: Nope, sorry. I reported bug, you can track it or add your input:
