FredrikA Posted January 19, 2022 Posted January 19, 2022 Board orangepi4b uname -a Linux orangepi4 5.10.63-rockchip64 #21.08.2 SMP PREEMPT Wed Sep 8 10:57:23 UTC 2021 aarch64 GNU/Linux Got syntax error on armbianmonitor -u: armbianmonitor -u "System diagnosis information will now be uploaded to syntax error at or near "" Please post the URL in the forum where you've been asked for" set -x armbianmonitor -u Network/firewall problem detected. Not able to upload debug info. Please fix this or use "-U" instead and upload whole output manually attached file err is output from armbianmonitor -U Anyway I had to reflash after a microSD broke. Previously I used 4.4.213-rk3399 (don't recall the armbian version) and then built in wifi worked. Now I used the latest image 5.10.63-rockchip64, and I can't get the built in wifi to work. As I think I recall right, i added the module rtl8189fs with "insmod 8189fs" and the kernel log said [ 4584.914559] RTL871X: module init start [ 4584.914579] RTL871X: rtl8189fs v4.3.24.8_22657.20170607 [ 4584.914783] RTL871X: module init ret=0 but I can't find the device with nmtui or lshw. What Am I doing wrong? err
Igor Posted January 19, 2022 Posted January 19, 2022 1 hour ago, FredrikA said: What Am I doing wrong? We are moving soon to next LTS kernel, where my OrangePi 4 has not problems connecting to wifi: http://ix.io/3MKQ WiFi chip - at least on mine - is Broadcom: [ 7.839285] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [ 7.840127] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available [ 7.841615] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Feb 11 2020 11:54:51 version XXX.XXX.96.61 (be7af2d@shgit) (r745790) FWID 01-a41d86bd es7.c5.n4.a3
