Apologies if this posted in wrong section.
I'm running Armbian buster with Linux 5.4.20-sunxi on an Orange Pi 0 (512) and recently I decided to install openmediavault. So I added a 32G USB flash memory and both lsblk and lsusb failed to display the device.
So I followed instructions at
with no avail.
Now I know that USB ports used to work a couple of months earlier and I have cleaned the dusty ports and tried many different UDB flash memories and no result.
Appreciate any help and thank you.
Try armbian-config way:
sudo  armbian-config
system -> hardware (and enable all usb ports)
I've noticed USB ports disappear after installing updates so I reinstalled OS and ignored the updates. Now the system is happy.
Thanks Igor for your input.
Can you tell us exactly on which version (including kernel version) the ports are working properly and on which not?
