r2s bridge mode eth0 lan0
Go to solution Solved by arox,
hello guys,
how to activate bridge mode between the 2 ethernet ports of R2S (WAN and LAN) which are referred to as eth0 and lan0 respectively, so as both of them have the same ip address.
i tried this https://wiki.debian.org/BridgeNetworkConnections#Manual_bridge_setup but when i reach the command which adds interfaces to the bridge (# brctl addif br0 eth0 lan0)then the ssh connection is lost.
i noticed something as well, in interfaces file i added eth0 and lan0 and gave each one a different ip. but then it seems as is now i have two IPs but for the same port (WAN), and no ip for lan port!!!
  • Solution
As stated in the tutorial, you should assign an address to the bridge only.
The bridge forward everything on data link layer and the interface of the bridge then form/extract IP packet. Otherwise you will have a hard time to manage kernel routing tables...
