I want to use debian wheezy for Olimex A20-micro. Please let me know whether it supports recording from microphone connector and audio out to headphone connector on board.Does there any audio breaking issues with this image or any other debian image.
How to install it on Nand Memory of A20-micro board.
Kernel 3.4.108 should work with audio and NAND.
I am not sure about mic if Olimex micro has it or if it is wired to connector but the feature works on some other A20 boards which I have. I haven't done any deep tests so can't say anything about quality. I also haven't noticed any complains about audio breaking.
There is a nand-sata-installer script in /root... run it and follow instructions. If you run into troubles - check faq or ask here.
thanks sir for quick reply.....can I export gpio pins for general purpose usage...Is there any problem of pin muxing because for that problem we have to edit .dts file which is very difficult for a newbie like me.
Kernel 3.4.x doesn't have DT but Allwinner FEX files which does the same and where GPIOS are defined. Hard to say if this will be hard for you.
There are plenty howto-s for this. Essentially you need to edit script.fex file (located in /boot) ... which you need to unpack from script.bin and pack back.
Utilities for this are on all images: bin2fex and fex2bin
For naming and pin location refer to board manual. Each board is/can be wired different.
Which module provide the default sound config ? I want to use the output jack on a bananapi M1+. With the kernel 3.4.108, there is no sound device, nor loaded kernel.
(I used a banapipro .fex file).
Thanks
Sound driver is built into kernel. What do you get from:
cat /proc/asound
uname -a
lsmod
/proc/asound looks Ok :
jkx@banana1 ~> cat /proc/asound/devices
  2: [ 0- 0]: digital audio playback
  3: [ 0- 0]: digital audio capture
  4: [ 0]   : control
 33:        : timer
jkx@banana1 ~> cat /proc/asound/cards
 0 [sunxicodec     ]: sunxi-CODEC - sunxi-CODEC
                      sunxi-CODEC  Audio Codec
but aplay don't find any device..
jkx@banana1 ~> aplay -l
aplay: device_list:268: no soundcards found...
My config
- uname : Linux banana1 3.4.108-bananapi #6 SMP PREEMPT Sun Jul 12 07:23:19 CEST 2015 armv7l GNU/Linux
- not asoundrc ..
jkx@banana1 ~> lsmod
Module                  Size  Used by
wifi_gpio               6375  0
ap6210                624553  0
cpufreq_userspace       3524  0
spidev                  6366  0
a20_tp                  3365  0
8021q                  18593  0
garp                    6072  1 8021q
stp                     2032  1 garp
llc                     5365  2 stp,garp
sunxi_ir                4037  0
hidp                   17640  0
rfcomm                 58686  0
hci_uart               25000  0
bluetooth             264185  5 hidp,hci_uart,rfcomm
Thanks
Oups, I managed to fix it. It's only a permission error. With the root account everything is fine.. I guess I need to apologize.
I added my user to the audio group.
Thanks for the support. Bye
