RaphaelTrombini Posted March 8, 2022 Posted March 8, 2022 Hello Everyone! I'm currently working on a nano pi m4b with a rockchip 3399 processor on it. I need to use an USB camera for my application but I am experiencing some issues that have been really hard to track down lately. First of all I'm using a 5 mega pixels camera with a OV5640 CMOS sensor and I experience some glitches with the image while live streaming. Besides that, I can only get an image while connected to USB 2.0, the 3.0 gives me a black screen with sporadic glitched frames. I'm running Linux 4.4.213-rk3399 on it and here are the dmesg dump logs I'm geting. Has anyone else had this kind of issue? [Feb24 19:13] Booting Linux on physical CPU 0x0 [ +0.000000] Initializing cgroup subsys cpuset [ +0.000000] Initializing cgroup subsys cpu [ +0.000000] Initializing cgroup subsys cpuacct [ +0.000000] Linux version 4.4.213-rk3399 (root@beast) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) ) #1 SMP Fri Nov 20 20:43:09 CET 2020 [ +0.000000] Boot CPU: AArch64 Processor [410fd034] [ +0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ +0.000000] On node 0 totalpages: 523776 [ +0.000000] DMA zone: 8184 pages used for memmap [ +0.000000] DMA zone: 0 pages reserved [ +0.000000] DMA zone: 523776 pages, LIFO batch:31 [ +0.000000] psci: probing for conduit method from DT. [ +0.000000] psci: PSCIv1.0 detected in firmware. [ +0.000000] psci: Using standard PSCI v0.2 function IDs [ +0.000000] psci: MIGRATE_INFO_TYPE not supported. [ +0.000000] psci: SMC Calling Convention v1.0 [ +0.000000] PERCPU: Embedded 20 pages/cpu @ffffffc07fee5000 s42216 r8192 d31512 u81920 [ +0.000000] pcpu-alloc: s42216 r8192 d31512 u81920 alloc=20*4096 [ +0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [ +0.000000] Detected VIPT I-cache on CPU0 [ +0.000000] CPU features: enabling workaround for ARM erratum 845719 [ +0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 515592 [ +0.000000] Kernel command line: root=LABEL=SYSTEM rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=15158a89-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u usbcore.autosuspend=-1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ +0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ +0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ +0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ +0.000000] software IO TLB: mapped [mem 0x757a7000-0x797a7000] (64MB) [ +0.000000] Memory: 1962680K/2095104K available (11518K kernel code, 1402K rwdata, 6140K rodata, 1088K init, 1954K bss, 132424K reserved, 0K cma-reserved) [ +0.000000] Virtual kernel memory layout: modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB) vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB) .init : 0xffffff80091d0000 - 0xffffff80092e0000 ( 1088 KB) .text : 0xffffff8008080000 - 0xffffff8008bc0000 ( 11520 KB) .rodata : 0xffffff8008bc0000 - 0xffffff80091d0000 ( 6208 KB) .data : 0xffffff80092e0000 - 0xffffff800943e808 ( 1403 KB) vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum) 0xffffffbdc0008000 - 0xffffffbdc2000000 ( 31 MB actual) fixed : 0xffffffbffe7fb000 - 0xffffffbffec00000 ( 4116 KB) PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB) memory : 0xffffffc000200000 - 0xffffffc080000000 ( 2046 MB) [ +0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ +0.000000] Hierarchical RCU implementation. [ +0.000000] Build-time adjustment of leaf fanout to 64. [ +0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [ +0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6 [ +0.000000] NR_IRQS:64 nr_irqs:64 0 [ +0.000000] GIC: Using split EOI/Deactivate mode [ +0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000 [ +0.000000] ITS: allocated 65536 Devices @7d500000 (psz 64K, shr 0) [ +0.000000] ITS: using cache flushing for cmd queue [ +0.000000] GIC: using LPI property table @0x000000007d490000 [ +0.000000] ITS: Allocated 1792 chunks for LPIs [ +0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000 [ +0.000000] CPU0: using LPI pending table @0x000000007d4a0000 [ +0.000000] GIC: using cache flushing for LPI property table [ +0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ +0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ +0.000000] rockchip_mmc_get_phase: invalid clk rate [ +0.000000] rockchip_mmc_get_phase: invalid clk rate [ +0.000000] rockchip_mmc_get_phase: invalid clk rate [ +0.000000] rockchip_mmc_get_phase: invalid clk rate [ +0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work [ +0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work [ +0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ +0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ +0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ +0.001462] Console: colour dummy device 80x25 [ +0.000205] console [tty1] enabled [ +0.000023] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ +0.000012] pid_max: default: 32768 minimum: 301 [ +0.000115] Security Framework initialized [ +0.000011] Yama: becoming mindful. [ +0.000022] AppArmor: AppArmor disabled by boot time parameter [ +0.000052] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes) [ +0.000012] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes) [ +0.000704] Initializing cgroup subsys io [ +0.000019] Initializing cgroup subsys memory [ +0.000032] Initializing cgroup subsys devices [ +0.000014] Initializing cgroup subsys freezer [ +0.000013] Initializing cgroup subsys net_cls [ +0.000012] Initializing cgroup subsys perf_event [ +0.000013] Initializing cgroup subsys net_prio [ +0.000018] Initializing cgroup subsys hugetlb [ +0.000011] Initializing cgroup subsys pids [ +0.000040] ftrace: allocating 41759 entries in 164 pages [ +0.111603] sched-energy: Sched-energy-costs installed from DT [ +0.000019] CPU0: update cpu_capacity 401 [ +0.000054] ASID allocator initialised with 32768 entries [ +0.002899] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ +0.000554] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ +0.001348] Detected VIPT I-cache on CPU1 [ +0.000032] CPU1: found redistributor 1 region 0:0x00000000fef20000 [ +0.000030] CPU1: using LPI pending table @0x000000007d720000 [ +0.000044] CPU1: update cpu_capacity 401 [ +0.000004] CPU1: Booted secondary processor [410fd034] [ +0.000547] Detected VIPT I-cache on CPU2 [ +0.000021] CPU2: found redistributor 2 region 0:0x00000000fef40000 [ +0.000028] CPU2: using LPI pending table @0x000000007d750000 [ +0.000027] CPU2: update cpu_capacity 401 [ +0.000004] CPU2: Booted secondary processor [410fd034] [ +0.000516] Detected VIPT I-cache on CPU3 [ +0.000020] CPU3: found redistributor 3 region 0:0x00000000fef60000 [ +0.000027] CPU3: using LPI pending table @0x000000007d7a0000 [ +0.000026] CPU3: update cpu_capacity 401 [ +0.000004] CPU3: Booted secondary processor [410fd034] [ +0.000531] Detected PIPT I-cache on CPU4 [ +0.000026] CPU4: found redistributor 100 region 0:0x00000000fef80000 [ +0.000038] CPU4: using LPI pending table @0x000000007d7e0000 [ +0.000038] CPU4: update cpu_capacity 1024 [ +0.000003] CPU4: Booted secondary processor [410fd082] [ +0.000560] Detected PIPT I-cache on CPU5 [ +0.000018] CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ +0.000036] CPU5: using LPI pending table @0x000000007cc10000 [ +0.000026] CPU5: update cpu_capacity 1024 [ +0.000003] CPU5: Booted secondary processor [410fd082] [ +0.000088] Brought up 6 CPUs [ +0.000086] SMP: Total of 6 processors activated. [ +0.000009] CPU features: detected feature: GIC system register CPU interface [ +0.000010] CPU features: detected feature: 32-bit EL0 Support [ +0.000011] CPU: All CPU(s) started at EL2 [ +0.000046] alternatives: patching kernel code [ +0.001384] devtmpfs: initialized [ +0.018199] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ +0.000024] futex hash table entries: 2048 (order: 5, 131072 bytes) [ +0.000471] xor: measuring software checksum speed [ +0.039147] 8regs : 2855.000 MB/sec [ +0.040061] 8regs_prefetch: 2552.000 MB/sec [ +0.040061] 32regs : 3211.000 MB/sec [ +0.040061] 32regs_prefetch: 2843.000 MB/sec [ +0.000006] xor: using function: 32regs (3211.000 MB/sec) [ +0.000021] pinctrl core: initialized pinctrl subsystem [ +0.000226] regulator-dummy: no parameters [ +0.000539] NET: Registered protocol family 16 [ +0.007129] cpuidle: using governor ladder [ +0.008006] cpuidle: using governor menu [ +0.000023] Registered FIQ tty driver [ +0.000290] vdso: 2 pages (1 code @ ffffff8008bc6000, 1 data @ ffffff80092e5000) [ +0.000027] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ +0.000163] DMA: preallocated 256 KiB pool for atomic allocations [ +0.016791] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0 [ +0.000076] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1 [ +0.000070] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2 [ +0.000071] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3 [ +0.000069] gpiochip_add_data: registered GPIOs 128 to 159 on device: gpio4 [ +0.007650] console [pstore-1] enabled [ +0.000008] pstore: Registered ramoops as persistent store backend [ +0.000009] ramoops: attached 0xf0000@0x110000, ecc: 0/0 [ +0.003155] console [ttyFIQ0] enabled [ +0.000220] Registered fiq debugger ttyFIQ0 [ +0.075693] raid6: int64x1 gen() 450 MB/s [ +0.068094] raid6: int64x1 xor() 410 MB/s [ +0.068119] raid6: int64x2 gen() 765 MB/s [ +0.068083] raid6: int64x2 xor() 596 MB/s [ +0.068117] raid6: int64x4 gen() 1072 MB/s [ +0.068078] raid6: int64x4 xor() 666 MB/s [ +0.068106] raid6: int64x8 gen() 824 MB/s [ +0.068101] raid6: int64x8 xor() 603 MB/s [ +0.068099] raid6: neonx1 gen() 908 MB/s [ +0.068095] raid6: neonx1 xor() 663 MB/s [ +0.068152] raid6: neonx2 gen() 1548 MB/s [ +0.068069] raid6: neonx2 xor() 989 MB/s [ +0.068112] raid6: neonx4 gen() 1836 MB/s [ +0.068105] raid6: neonx4 xor() 1149 MB/s [ +0.068122] raid6: neonx8 gen() 1697 MB/s [ +0.068081] raid6: neonx8 xor() 1235 MB/s [ +0.000008] raid6: using algorithm neonx4 gen() 1836 MB/s [ +0.000008] raid6: .... xor() 1149 MB/s, rmw enabled [ +0.000007] raid6: using intx1 recovery algorithm [ +0.001076] of_get_named_gpiod_flags: parsed 'rockchip,power-ctrl' property of node '/rockchip-suspend[0]' - status (0) [ +0.000048] of_get_named_gpiod_flags: parsed 'rockchip,power-ctrl' property of node '/rockchip-suspend[1]' - status (0) [ +0.000307] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc3v3-sys[0]' [ +0.000025] vcc3v3_sys: 3300 mV [ +0.000175] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV [ +0.000055] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc5v0-host-regulator[0]' [ +0.000018] vcc5v0_host: 5000 mV [ +0.000156] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 5000000uV [ +0.000055] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc5v0-sys[0]' [ +0.000017] vcc5v0_sys: 5000 mV [ +0.000143] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV [ +0.000052] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vccadc-ref[0]' [ +0.000017] vcc1v8_sys: 1800 mV [ +0.000156] reg-fixed-voltage vccadc-ref: vcc1v8_sys supplying 1800000uV [ +0.000162] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-sd[0]' - status (0) [ +0.000052] vcc_sd: 3000 mV [ +0.000158] reg-fixed-voltage vcc-sd: vcc_sd supplying 3000000uV [ +0.000051] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]' [ +0.000017] vcc_phy: no parameters [ +0.000151] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV [ +0.000082] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-lcd[0]' - status (0) [ +0.000042] reg-fixed-voltage vcc-lcd: Looking up vin-supply from device tree [ +0.000049] vcc_lcd: supplied by vcc5v0_sys [ +0.024407] vcc_lcd: 3300 mV [ +0.000175] reg-fixed-voltage vcc-lcd: vcc_lcd supplying 3300000uV [ +0.000686] iommu: Adding device ff650000.vpu_service to group 0 [ +0.000091] iommu: Adding device ff660000.rkvdec to group 1 [ +0.000119] iommu: Adding device ff8f0000.vop to group 2 [ +0.000096] iommu: Adding device ff900000.vop to group 3 [ +0.000099] iommu: Adding device ff910000.rkisp1 to group 4 [ +0.000099] iommu: Adding device ff920000.rkisp1 to group 5 [ +0.000516] rk_iommu ff650800.iommu: can't get sclk [ +0.000287] rk_iommu ff660480.iommu: can't get sclk [ +0.000220] rk_iommu ff8f3f00.iommu: can't get sclk [ +0.000182] rk_iommu ff903f00.iommu: can't get sclk [ +0.000177] rk_iommu ff914000.iommu: can't get sclk [ +0.000174] rk_iommu ff924000.iommu: can't get sclk [ +0.000387] SCSI subsystem initialized [ +0.000204] libata version 3.00 loaded. [ +0.000202] usbcore: registered new interface driver usbfs [ +0.000047] usbcore: registered new interface driver hub [ +0.000109] usbcore: registered new device driver usb [ +0.000102] media: Linux media interface: v0.10 [ +0.000039] Linux video capture interface: v2.00 [ +0.000074] pps_core: LinuxPPS API ver. 1 registered [ +0.000008] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ +0.000026] PTP clock support registered [ +0.001251] Advanced Linux Sound Architecture Driver Initialized. [ +0.000941] NetLabel: Initializing [ +0.000009] NetLabel: domain hash size = 128 [ +0.000006] NetLabel: protocols = UNLABELED CIPSOv4 [ +0.000041] NetLabel: unlabeled traffic allowed by default [ +0.000272] rockchip-cpuinfo cpuinfo: Serial : bb1bd30f66833859 [ +0.000633] clocksource: Switched to clocksource arch_sys_counter [ +0.046126] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ +0.000132] NET: Registered protocol family 2 [ +0.000455] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ +0.000138] TCP bind hash table entries: 16384 (order: 7, 524288 bytes) [ +0.000412] TCP: Hash tables configured (established 16384 bind 16384) [ +0.000083] UDP hash table entries: 1024 (order: 4, 98304 bytes) [ +0.000080] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes) [ +0.000258] NET: Registered protocol family 1 [ +0.000043] PCI: CLS 0 bytes, default 64 [ +0.000746] Trying to unpack rootfs image as initramfs... [ +0.360122] Freeing initrd memory: 7156K [ +0.000565] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ +0.000091] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ +0.001572] kvm [1]: 8-bit VMID [ +0.000010] kvm [1]: Hyp mode initialized successfully [ +0.000128] kvm [1]: interrupt-controller@fff20000 IRQ10 [ +0.000202] kvm [1]: timer IRQ12 [ +0.003613] audit: initializing netlink subsys (disabled) [ +0.000058] audit: type=2000 audit(1.816:1): initialized [ +0.000402] Initialise system trusted keyring [ +0.000395] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ +0.007390] VFS: Disk quotas dquot_6.6.0 [ +0.000159] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ +0.001459] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ +0.000675] fuse init (API version 7.23) [ +0.000576] JFS: nTxBlock = 8192, nTxLock = 65536 [ +0.005348] SGI XFS with ACLs, security attributes, realtime, no debug enabled [ +0.001763] Key type big_key registered [ +0.000022] TEE Core Framework initialization (ver 1:0.1) [ +0.000030] TEE armv7 Driver initialization [ +0.000469] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0" [ +0.000011] TEE core: Alloc the misc device "opteearmtz00" (id=0) [ +0.000192] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62) [ +0.005742] Key type asymmetric registered [ +0.000023] Asymmetric key parser 'x509' registered [ +0.000202] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ +0.000134] io scheduler noop registered [ +0.000012] io scheduler deadline registered (default) [ +0.000040] io scheduler cfq registered [ +0.001082] phy phy-ff770000.syscon:usb2-phy@e460.0: Looking up phy-supply from device tree [ +0.000416] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up phy-supply from device tree [ +0.000015] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed [ +0.000087] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up vbus-supply from device tree [ +0.000012] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed [ +0.000014] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator [ +0.001148] phy phy-ff770000.syscon:phy@f780.2: Looking up phy-supply from device tree [ +0.000013] phy phy-ff770000.syscon:phy@f780.2: Looking up phy-supply property in node /syscon@ff770000/phy@f780 failed [ +0.000885] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply from device tree [ +0.000015] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply property in node /power-management@ff310000/power-controller failed [ +0.000331] phy phy-ff800000.phy.3: Looking up phy-supply from device tree [ +0.000013] phy phy-ff800000.phy.3: Looking up phy-supply property in node /phy@ff800000/dp-port failed [ +0.000134] phy phy-ff800000.phy.4: Looking up phy-supply from device tree [ +0.000012] phy phy-ff800000.phy.4: Looking up phy-supply property in node /phy@ff800000/usb3-port failed [ +0.000105] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply from device tree [ +0.000013] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply property in node /power-management@ff310000/power-controller failed [ +0.000370] phy phy-pcie-phy.5: Looking up phy-supply from device tree [ +0.000013] phy phy-pcie-phy.5: Looking up phy-supply property in node /pcie-phy failed [ +0.002271] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep [ +0.000013] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup [ +0.000013] of_get_named_gpiod_flags: can't parse 'ep-gpios' property of node '/pcie@f8000000[0]' [ +0.000011] of_get_named_gpiod_flags: can't parse 'ep-gpio' property of node '/pcie@f8000000[0]' [ +0.000009] rockchip-pcie f8000000.pcie: using lookup tables for GPIO lookup [ +0.000011] rockchip-pcie f8000000.pcie: lookup for GPIO ep failed [ +0.000228] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree [ +0.000013] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply property in node /pcie@f8000000 failed [ +0.000016] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found [ +0.000010] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree [ +0.000011] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed [ +0.000013] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found [ +0.000009] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree [ +0.000011] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed [ +0.000014] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found [ +0.000010] rockchip-pcie f8000000.pcie: no bus-scan-delay-ms in device tree, default 0 ms [ +0.000010] rockchip-pcie f8000000.pcie: missing "memory-region" property [ +0.000016] PCI host bridge /pcie@f8000000 ranges: [ +0.000022] MEM 0xfa000000..0xfbdfffff -> 0xfa000000 [ +0.000012] IO 0xfbe00000..0xfbefffff -> 0xfbe00000 [ +0.600778] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ +0.000024] rockchip-pcie f8000000.pcie: deferred probe failed [ +0.000207] rockchip-pcie: probe of f8000000.pcie failed with error -110 [ +0.000869] pwm-backlight backlight: GPIO lookup for consumer enable [ +0.000015] pwm-backlight backlight: using device tree for GPIO lookup [ +0.000122] of_get_named_gpiod_flags: parsed 'enable-gpios' property of node '/backlight[0]' - status (0) [ +0.000030] no flags found for enable [ +0.000044] pwm-backlight backlight: Looking up power-supply from device tree [ +0.000015] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [ +0.000022] backlight supply power not found, using dummy regulator [ +0.000723] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply from device tree [ +0.000018] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply property in node /vpu_service@ff650000 failed [ +0.000018] rk-vcodec ff650000.vpu_service: no regulator for vcodec [ +0.000265] rk-vcodec ff650000.vpu_service: probe device [ +0.000245] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled [ +0.000558] rk-vcodec ff650000.vpu_service: could not find power_model node [ +0.000012] rk-vcodec ff650000.vpu_service: init success [ +0.000205] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply from device tree [ +0.000013] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff660000 failed [ +0.000018] rk-vcodec ff660000.rkvdec: no regulator for vcodec [ +0.000459] rk-vcodec ff660000.rkvdec: probe device [ +0.000240] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled [ +0.000388] rk-vcodec ff660000.rkvdec: could not find power_model node [ +0.000010] rk-vcodec ff660000.rkvdec: init success [ +0.001504] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ +0.000013] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [ +0.001385] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ +0.000012] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ +0.001101] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ +0.000610] pwm-regulator vdd-log: GPIO lookup for consumer enable [ +0.000011] pwm-regulator vdd-log: using device tree for GPIO lookup [ +0.000012] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log[0]' [ +0.000010] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log[0]' [ +0.000010] pwm-regulator vdd-log: using lookup tables for GPIO lookup [ +0.000010] pwm-regulator vdd-log: lookup for GPIO enable failed [ +0.000025] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000011] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000045] vdd_log: 800 <--> 1400 mV at 800 mV [ +0.000151] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000012] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000053] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000011] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000431] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled [ +0.000691] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A [ +0.000511] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A [ +0.001115] [drm] Initialized drm 1.1.0 20060810 [ +0.003923] [drm] Rockchip DRM driver version: v1.0.1 [ +0.000357] rockchip-drm display-subsystem: defer getting devfreq [ +0.000296] rockchip-vop ff900000.vop: missing rockchip,grf property [ +0.000274] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008c68818) [ +0.000049] rockchip-vop ff8f0000.vop: missing rockchip,grf property [ +0.000190] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008c68818) [ +0.000174] rockchip-drm display-subsystem: failed to bind ff940000.hdmi (ops 0xffffff8008c5d890): -517 [ +0.000246] rockchip-drm display-subsystem: master bind failed: -517 [ +0.000527] panel-friendlyelec edp-panel: Looking up power-supply from device tree [ +0.000129] panel-friendlyelec edp-panel: GPIO lookup for consumer enable [ +0.000010] panel-friendlyelec edp-panel: using device tree for GPIO lookup [ +0.000013] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/edp-panel[0]' [ +0.000010] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/edp-panel[0]' [ +0.000010] panel-friendlyelec edp-panel: using lookup tables for GPIO lookup [ +0.000010] panel-friendlyelec edp-panel: lookup for GPIO enable failed [ +0.001709] Unable to detect cache hierarchy for CPU 0 [ +0.000848] brd: module loaded [ +0.005508] loop: module loaded [ +0.000325] lkdtm: No crash points registered, enable through debugfs [ +0.002298] rk_gmac-dwmac fe300000.ethernet: Looking up phy-supply from device tree [ +0.000089] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ +0.000012] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ +0.000011] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11). [ +0.000025] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no). [ +0.000194] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed [ +0.000009] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ +0.005017] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ +0.000154] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ +0.000008] Ring mode enabled [ +0.000007] DMA HW capability register supported [ +0.000006] Normal descriptors [ +0.000009] RX Checksum Offload Engine supported (type 2) [ +0.000007] TX Checksum insertion supported [ +0.000006] Wake-Up On Lan supported [ +0.000040] Enable RX Mitigation via HW Watchdog Timer [ +0.000111] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@fe300000[0]' - status (0) [ +0.085469] libphy: stmmac: probed [ +0.000016] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active [ +0.000010] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01) [ +0.001389] usbcore: registered new interface driver rndis_wlan [ +0.000237] Rockchip WiFi SYS interface (V1.00) ... [ +0.000071] usbcore: registered new interface driver cdc_ether [ +0.000040] usbcore: registered new interface driver rndis_host [ +0.001424] rockchip-dwc3 usb0: failed to get drvdata dwc3 [ +0.000091] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply from device tree [ +0.000014] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply property in node /power-management@ff310000/power-controller failed [ +0.004797] rockchip-dwc3 usb1: fail to get drvdata hcd [ +0.001820] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ +0.000027] ehci-pci: EHCI PCI platform driver [ +0.000063] ehci-platform: EHCI generic platform driver [ +0.003948] ehci-platform fe3c0000.usb: EHCI Host Controller [ +0.000168] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1 [ +0.000108] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000 [ +0.009421] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00 [ +0.000159] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ +0.000012] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ +0.000011] usb usb1: Product: EHCI Host Controller [ +0.000009] usb usb1: Manufacturer: Linux 4.4.213-rk3399 ehci_hcd [ +0.000009] usb usb1: SerialNumber: fe3c0000.usb [ +0.000456] hub 1-0:1.0: USB hub found [ +0.000030] hub 1-0:1.0: 1 port detected [ +0.000600] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ +0.000022] ohci-platform: OHCI generic platform driver [ +0.000519] ohci-platform fe3e0000.usb: Generic Platform OHCI controller [ +0.000154] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2 [ +0.000093] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000 [ +0.058061] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ +0.000012] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ +0.000010] usb usb2: Product: Generic Platform OHCI controller [ +0.000009] usb usb2: Manufacturer: Linux 4.4.213-rk3399 ohci_hcd [ +0.000009] usb usb2: SerialNumber: fe3e0000.usb [ +0.000415] hub 2-0:1.0: USB hub found [ +0.000031] hub 2-0:1.0: 1 port detected [ +0.000952] usbcore: registered new interface driver cdc_acm [ +0.000009] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ +0.000043] usbcore: registered new interface driver cdc_wdm [ +0.000083] usbcore: registered new interface driver usbserial [ +0.000032] usbcore: registered new interface driver usbserial_generic [ +0.000024] usbserial: USB Serial support registered for generic [ +0.000872] usbcore: registered new interface driver iforce [ +0.000062] usbcore: registered new interface driver xpad [ +0.000200] usbcore: registered new interface driver usbtouchscreen [ +0.000013] <<-GTP-INFO->> GTP driver installing [ +0.000569] sensor_register_slave:mma8452,id=17 [ +0.000023] sensor_register_slave:lis3dh,id=7 [ +0.000017] sensor_register_slave:mma7660,id=18 [ +0.000016] sensor_register_slave:lsm303d,id=22 [ +0.000017] sensor_register_slave:mpu6880_acc,id=24 [ +0.000017] sensor_register_slave:mpu6500_acc,id=25 [ +0.000016] sensor_register_slave:lsm330_acc,id=26 [ +0.000017] sensor_register_slave:akm8975,id=30 [ +0.000017] sensor_register_slave:akm8963,id=31 [ +0.000017] sensor_register_slave:l3g4200d,id=45 [ +0.000016] sensor_register_slave:l3g20d,id=46 [ +0.000016] sensor_register_slave:ewtsa,id=47 [ +0.000017] sensor_register_slave:lsm330_gyro,id=51 [ +0.000016] sensor_register_slave:cm3217,id=53 [ +0.000016] sensor_register_slave:cm3218,id=54 [ +0.000637] i2c /dev entries driver [ +0.001336] fan53555-regulator 0-0040: GPIO lookup for consumer vsel [ +0.000016] fan53555-regulator 0-0040: using device tree for GPIO lookup [ +0.000048] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3c0000/syr827@40[0]' - status (0) [ +0.000418] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ +0.000025] fan53555-regulator 0-0040: Looking up vin-supply from device tree [ +0.000091] fan53555-reg: supplied by vcc3v3_sys [ +0.001441] vdd_cpu_b: 712 <--> 1500 mV at 1000 mV [ +0.000486] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000018] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000339] fan53555-regulator 0-0041: GPIO lookup for consumer vsel [ +0.000013] fan53555-regulator 0-0041: using device tree for GPIO lookup [ +0.000044] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3c0000/syr828@41[0]' - status (0) [ +0.000374] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ +0.000021] fan53555-regulator 0-0041: Looking up vin-supply from device tree [ +0.000069] fan53555-reg: supplied by vcc3v3_sys [ +0.001422] vdd_gpu: 712 <--> 1500 mV at 1000 mV [ +0.000444] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000017] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000704] rk808 0-001b: Pmic Chip id: 0x0 [ +0.003645] rk808 0-001b: GPIO lookup for consumer dvs [ +0.000014] rk808 0-001b: using device tree for GPIO lookup [ +0.000016] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[0]' [ +0.000014] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]' [ +0.000011] rk808 0-001b: using lookup tables for GPIO lookup [ +0.000013] rk808 0-001b: lookup for GPIO dvs failed [ +0.000013] rk808-regulator rk808-regulator: there is no dvs0 gpio [ +0.000012] rk808 0-001b: GPIO lookup for consumer dvs [ +0.000011] rk808 0-001b: using device tree for GPIO lookup [ +0.000013] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[1]' [ +0.000013] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[1]' [ +0.000012] rk808 0-001b: using lookup tables for GPIO lookup [ +0.000011] rk808 0-001b: lookup for GPIO dvs failed [ +0.000012] rk808-regulator rk808-regulator: there is no dvs1 gpio [ +0.000053] rk808 0-001b: Looking up vcc1-supply from device tree [ +0.000094] DCDC_REG1: supplied by vcc3v3_sys [ +0.000530] vdd_center: 750 <--> 1350 mV at 900 mV [ +0.000290] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000018] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000058] rk808 0-001b: Looking up vcc2-supply from device tree [ +0.000075] DCDC_REG2: supplied by vcc3v3_sys [ +0.000353] vdd_cpu_l: 750 <--> 1350 mV at 900 mV [ +0.000271] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000017] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000056] rk808 0-001b: Looking up vcc3-supply from device tree [ +0.000063] DCDC_REG3: supplied by vcc3v3_sys [ +0.000048] vcc_ddr: at 3300 mV [ +0.000261] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000016] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000064] rk808 0-001b: Looking up vcc4-supply from device tree [ +0.000057] DCDC_REG4: supplied by vcc3v3_sys [ +0.000199] vcc_1v8: 1800 mV [ +0.000290] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000016] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000066] rk808 0-001b: Looking up vcc6-supply from device tree [ +0.000057] LDO_REG1: supplied by vcc3v3_sys [ +0.000869] vcc1v8_dvp: 1800 mV [ +0.000292] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000016] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000071] rk808 0-001b: Looking up vcc6-supply from device tree [ +0.000057] LDO_REG2: supplied by vcc3v3_sys [ +0.000714] vcc3v0_tp: 3000 mV [ +0.000292] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000016] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000072] rk808 0-001b: Looking up vcc7-supply from device tree [ +0.000058] LDO_REG3: supplied by vcc3v3_sys [ +0.000715] vcc1v8_pmu: 1800 mV [ +0.000292] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000016] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000074] rk808 0-001b: Looking up vcc9-supply from device tree [ +0.000058] LDO_REG4: supplied by vcc3v3_sys [ +0.000195] vccio_sd: Bringing 3300000uV into 3000000-3000000uV [ +0.000134] vccio_sd: ramp_delay not set [ +0.000541] vccio_sd: 1800 <--> 3000 mV at 3000 mV [ +0.000267] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000016] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000081] rk808 0-001b: Looking up vcc9-supply from device tree [ +0.000059] LDO_REG5: supplied by vcc3v3_sys [ +0.000749] vcca3v0_codec: 3000 mV [ +0.000270] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000016] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000080] rk808 0-001b: Looking up vcc10-supply from device tree [ +0.000058] LDO_REG6: supplied by vcc3v3_sys [ +0.000712] vcc_1v5: 1500 mV [ +0.000299] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000016] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000086] rk808 0-001b: Looking up vcc7-supply from device tree [ +0.000058] LDO_REG7: supplied by vcc3v3_sys [ +0.000714] vcca1v8_codec: 1800 mV [ +0.000297] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000016] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000084] rk808 0-001b: Looking up vcc11-supply from device tree [ +0.000057] LDO_REG8: supplied by vcc3v3_sys [ +0.000714] vcc_3v0: 3000 mV [ +0.000298] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000016] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000116] rk808 0-001b: Looking up vcc8-supply from device tree [ +0.000059] SWITCH_REG1: supplied by vcc3v3_sys [ +0.000049] vcc3v3_s3: at 3300 mV [ +0.000268] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000015] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.000083] rk808 0-001b: Looking up vcc12-supply from device tree [ +0.000058] SWITCH_REG2: supplied by vcc3v3_sys [ +0.000046] vcc3v3_s0: at 3300 mV [ +0.000265] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ +0.000016] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ +0.003567] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0 [ +0.000486] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80096fc000 [ +0.001203] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80096fe000 [ +0.000892] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80097c2000 [ +0.000617] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff80097c4000 [ +0.001156] fusb302 4-0022: GPIO lookup for consumer int-n [ +0.000013] fusb302 4-0022: using device tree for GPIO lookup [ +0.000048] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0) [ +0.000036] fusb302 4-0022: GPIO lookup for consumer vbus-5v [ +0.000013] fusb302 4-0022: using device tree for GPIO lookup [ +0.000041] of_get_named_gpiod_flags: parsed 'vbus-5v-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0) [ +0.000040] fusb302 4-0022: GPIO lookup for consumer vbus-other [ +0.000012] fusb302 4-0022: using device tree for GPIO lookup [ +0.000014] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' [ +0.000013] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]' [ +0.000012] fusb302 4-0022: using lookup tables for GPIO lookup [ +0.000013] fusb302 4-0022: lookup for GPIO vbus-other failed [ +0.000012] fusb302 4-0022: GPIO lookup for consumer discharge [ +0.000011] fusb302 4-0022: using device tree for GPIO lookup [ +0.000013] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' [ +0.000013] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]' [ +0.000011] fusb302 4-0022: using lookup tables for GPIO lookup [ +0.000012] fusb302 4-0022: lookup for GPIO discharge failed [ +0.000216] fusb302 4-0022: Can't get property of role, set role to default DRP [ +0.001899] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE [ +0.000214] input: Typec_Headphone as /devices/platform/ff3d0000.i2c/i2c-4/4-0022/input/input0 [ +0.000847] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80097c6000 [ +0.002615] usbcore: registered new interface driver uvcvideo [ +0.000010] USB Video Class driver (1.1.1) [ +0.000800] rockchip-iodomain ff320000.syscon:io-domains: Looking up pmu1830-supply from device tree [ +0.000400] rockchip-iodomain ff770000.syscon:io-domains: Looking up bt656-supply from device tree [ +0.000089] rockchip-iodomain ff770000.syscon:io-domains: Looking up audio-supply from device tree [ +0.000078] rockchip-iodomain ff770000.syscon:io-domains: Looking up sdmmc-supply from device tree [ +0.000074] rockchip-iodomain ff770000.syscon:io-domains: Looking up gpio1830-supply from device tree [ +0.001212] Boot mode: normal [ +0.001602] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647 [ +0.000225] rockchip-thermal ff260000.tsadc: tsadc is probed successfully! [ +0.000990] dw_wdt ff848000.watchdog: Should better to setup a 'resets' property in dt, that must been named with reset [ +0.000576] device-mapper: uevent: version 1.0.3 [ +0.000426] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com [ +0.000780] cpu cpu0: bin=1 [ +0.000083] cpu cpu0: leakage=21 [ +0.000042] cpu cpu0: Looking up cpu-supply from device tree [ +0.012691] cpu cpu0: temp=60625, pvtm=148152 (146898 + 1254) [ +0.000413] cpu cpu0: pvtm-volt-sel=1 [ +0.000090] cpu cpu0: bin-scale=34 [ +0.000469] cpu cpu4: bin=1 [ +0.000153] cpu cpu4: leakage=40 [ +0.000040] cpu cpu4: Looking up cpu-supply from device tree [ +0.012034] cpu cpu4: temp=61250, pvtm=150557 (149857 + 700) [ +0.000144] cpu cpu4: pvtm-volt-sel=1 [ +0.000074] cpu cpu4: bin-scale=17 [ +0.000397] cpu cpu0: Looking up cpu-supply from device tree [ +0.000420] cpu cpu0: Looking up cpu-supply from device tree [ +0.000925] cpu cpu0: avs=0 [ +0.000050] cpu cpu0: scale_rate=1416000000 [ +0.000269] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 [ +0.002450] cpu cpu0: failed to find power_model node [ +0.000360] cpu cpu4: Looking up cpu-supply from device tree [ +0.000704] cpu cpu4: avs=0 [ +0.000024] cpu cpu4: scale_rate=1800000000 [ +0.000180] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 [ +0.001840] cpu cpu4: failed to find power_model node [ +0.000813] sdhci: Secure Digital Host Controller Interface driver [ +0.000006] sdhci: Copyright(c) Pierre Ossman [ +0.000009] Synopsys Designware Multimedia Card Interface Driver [ +0.001046] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ +0.000037] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ +0.000013] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ +0.000051] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ +0.000019] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated. [ +0.000013] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree [ +0.000009] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed [ +0.000033] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree [ +0.000009] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed [ +0.000014] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ +0.000007] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ +0.000016] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp [ +0.000007] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup [ +0.000010] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe310000[0]' [ +0.000008] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe310000[0]' [ +0.000007] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup [ +0.000009] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed [ +0.000236] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply from device tree [ +0.000011] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply property in node /power-management@ff310000/power-controller failed [ +0.000592] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [ +0.000024] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [ +0.000011] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [ +0.000035] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo [ +0.000017] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated. [ +0.000008] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply from device tree [ +0.000105] dwmmc_rockchip fe320000.dwmmc: Looking up vqmmc-supply from device tree [ +0.000069] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer cd [ +0.000008] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup [ +0.000009] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@fe320000[0]' [ +0.000008] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@fe320000[0]' [ +0.000007] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup [ +0.000008] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed [ +0.000009] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer wp [ +0.000007] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup [ +0.000008] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe320000[0]' [ +0.000008] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe320000[0]' [ +0.000007] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup [ +0.000007] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed [ +0.000161] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done [ +0.000011] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done [ +0.012559] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ +0.016451] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done [ +0.000025] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done [ +0.000134] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized [ +0.000679] sdhci-pltfm: SDHCI platform and OF driver helper [ +0.000981] sdhci-arasan fe330000.sdhci: GPIO lookup for consumer wp [ +0.000019] sdhci-arasan fe330000.sdhci: using device tree for GPIO lookup [ +0.000020] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/sdhci@fe330000[0]' [ +0.000019] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/sdhci@fe330000[0]' [ +0.000016] sdhci-arasan fe330000.sdhci: using lookup tables for GPIO lookup [ +0.000018] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed [ +0.001164] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply from device tree [ +0.000022] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply property in node /sdhci@fe330000 failed [ +0.000051] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply from device tree [ +0.000019] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe330000 failed [ +0.000033] sdhci-arasan fe330000.sdhci: No vmmc regulator found [ +0.000014] sdhci-arasan fe330000.sdhci: No vqmmc regulator found [ +0.032486] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA [ +0.003796] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/led@1[0]' - status (0) [ +0.000572] ledtrig-cpu: registered to indicate activity on CPUs [ +0.000125] hidraw: raw HID events driver (C) Jiri Kosina [ +0.000727] usbcore: registered new interface driver usbhid [ +0.000017] usbhid: USB HID core driver [ +0.000505] ashmem: initialized [ +0.001608] rockchip-dmc dmc: unable to get devfreq-event device : dfi [ +0.002094] rockchip-saradc ff100000.saradc: Looking up vref-supply from device tree [ +0.022817] Initializing XFRM netlink socket [ +0.001000] NET: Registered protocol family 10 [ +0.001906] lib80211: common routines for IEEE802.11 drivers [ +0.000029] lib80211_crypt: registered algorithm 'NULL' [ +0.000031] lib80211_crypt: registered algorithm 'WEP' [ +0.000024] lib80211_crypt: registered algorithm 'CCMP' [ +0.000023] lib80211_crypt: registered algorithm 'TKIP' [ +0.000020] [WLAN_RFKILL]: Enter rfkill_wlan_init [ +0.000724] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ +0.000108] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354 [ +0.000013] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ +0.000013] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ +0.000020] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]' [ +0.000017] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]' [ +0.000016] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]' [ +0.000088] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0) [ +0.000014] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0. [ +0.000021] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found ! [ +0.000013] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ +0.000016] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ +0.000098] [BT_RFKILL]: Enter rfkill_rk_init [ +0.000786] of_get_named_gpiod_flags: parsed 'uart_rts_gpios' property of node '/wireless-bluetooth[0]' - status (0) [ +0.000016] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83. [ +0.000021] of_get_named_gpiod_flags: can't parse 'BT,power_gpio' property of node '/wireless-bluetooth[0]' [ +0.000052] of_get_named_gpiod_flags: parsed 'BT,reset_gpio' property of node '/wireless-bluetooth[0]' - status (0) [ +0.000014] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9. [ +0.000049] of_get_named_gpiod_flags: parsed 'BT,wake_gpio' property of node '/wireless-bluetooth[0]' - status (0) [ +0.000014] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90. [ +0.000049] of_get_named_gpiod_flags: parsed 'BT,wake_host_irq' property of node '/wireless-bluetooth[0]' - status (0) [ +0.000013] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4. [ +0.001347] [BT_RFKILL]: Request irq for bt wakeup host [ +0.000105] [BT_RFKILL]: ** disable irq [ +0.000237] [BT_RFKILL]: bt shut off power [ +0.021104] [BT_RFKILL]: bt_default device registered. [ +0.000131] Key type dns_resolver registered [ +0.000413] sensor_register_slave:mpu6880_gyro,id=50 [ +0.000639] ov4689 1-0036: driver version: 00.01.01 [ +0.000021] ov4689 1-0036: could not get module information! [ +0.000058] ov4689 1-0036: GPIO lookup for consumer reset [ +0.000012] ov4689 1-0036: using device tree for GPIO lookup [ +0.000044] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff110000/ov4689@36[0]' - status (0) [ +0.000040] ov4689 1-0036: GPIO lookup for consumer pwdn [ +0.000011] ov4689 1-0036: using device tree for GPIO lookup [ +0.000039] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff110000/ov4689@36[0]' - status (0) [ +0.000296] ov4689 1-0036: Looking up avdd-supply from device tree [ +0.000016] ov4689 1-0036: Looking up avdd-supply property in node /i2c@ff110000/ov4689@36 failed [ +0.000041] 1-0036 supply avdd not found, using dummy regulator [ +0.000083] ov4689 1-0036: Looking up dovdd-supply from device tree [ +0.000015] ov4689 1-0036: Looking up dovdd-supply property in node /i2c@ff110000/ov4689@36 failed [ +0.000021] 1-0036 supply dovdd not found, using dummy regulator [ +0.000049] ov4689 1-0036: Looking up dvdd-supply from device tree [ +0.000015] ov4689 1-0036: Looking up dvdd-supply property in node /i2c@ff110000/ov4689@36 failed [ +0.000021] 1-0036 supply dvdd not found, using dummy regulator [ +0.002749] ov4689 1-0036: Unexpected sensor id(000000), ret(-5) [ +0.000810] ov4689 2-0036: driver version: 00.01.01 [ +0.000020] ov4689 2-0036: could not get module information! [ +0.000045] ov4689 2-0036: GPIO lookup for consumer reset [ +0.000012] ov4689 2-0036: using device tree for GPIO lookup [ +0.000043] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff120000/ov4689@36[0]' - status (0) [ +0.000044] ov4689 2-0036: GPIO lookup for consumer pwdn [ +0.000012] ov4689 2-0036: using device tree for GPIO lookup [ +0.000038] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff120000/ov4689@36[0]' - status (0) [ +0.000251] ov4689 2-0036: Looking up avdd-supply from device tree [ +0.000015] ov4689 2-0036: Looking up avdd-supply property in node /i2c@ff120000/ov4689@36 failed [ +0.000041] 2-0036 supply avdd not found, using dummy regulator [ +0.000111] ov4689 2-0036: Looking up dovdd-supply from device tree [ +0.000015] ov4689 2-0036: Looking up dovdd-supply property in node /i2c@ff120000/ov4689@36 failed [ +0.000022] 2-0036 supply dovdd not found, using dummy regulator [ +0.000054] ov4689 2-0036: Looking up dvdd-supply from device tree [ +0.000014] ov4689 2-0036: Looking up dvdd-supply property in node /i2c@ff120000/ov4689@36 failed [ +0.000021] 2-0036 supply dvdd not found, using dummy regulator [ +0.002645] ov4689 2-0036: Unexpected sensor id(000000), ret(-5) [ +0.000411] Error: Driver 'ov7750' is already registered, aborting... [ +0.000022] Error: Driver 'ov8858' is already registered, aborting... [ +0.000564] ov13850 1-0010: driver version: 00.01.01 [ +0.000020] ov13850 1-0010: could not get module information! [ +0.000045] ov13850 1-0010: GPIO lookup for consumer reset [ +0.000012] ov13850 1-0010: using device tree for GPIO lookup [ +0.000044] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff110000/ov13850@10[0]' - status (0) [ +0.000043] ov13850 1-0010: GPIO lookup for consumer pwdn [ +0.000012] ov13850 1-0010: using device tree for GPIO lookup [ +0.000038] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff110000/ov13850@10[0]' - status (0) [ +0.000035] ov13850 1-0010: Looking up avdd-supply from device tree [ +0.000014] ov13850 1-0010: Looking up avdd-supply property in node /i2c@ff110000/ov13850@10 failed [ +0.000041] 1-0010 supply avdd not found, using dummy regulator [ +0.000074] ov13850 1-0010: Looking up dovdd-supply from device tree [ +0.000014] ov13850 1-0010: Looking up dovdd-supply property in node /i2c@ff110000/ov13850@10 failed [ +0.000022] 1-0010 supply dovdd not found, using dummy regulator [ +0.000061] ov13850 1-0010: Looking up dvdd-supply from device tree [ +0.000015] ov13850 1-0010: Looking up dvdd-supply property in node /i2c@ff110000/ov13850@10 failed [ +0.000022] 1-0010 supply dvdd not found, using dummy regulator [ +0.002023] ov13850 1-0010: Unexpected sensor id(000000), ret(-5) [ +0.000468] ov13850 2-0010: driver version: 00.01.01 [ +0.000019] ov13850 2-0010: could not get module information! [ +0.000039] ov13850 2-0010: GPIO lookup for consumer reset [ +0.000012] ov13850 2-0010: using device tree for GPIO lookup [ +0.000040] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff120000/ov13850@10[0]' - status (0) [ +0.000038] ov13850 2-0010: GPIO lookup for consumer pwdn [ +0.000012] ov13850 2-0010: using device tree for GPIO lookup [ +0.000038] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff120000/ov13850@10[0]' - status (0) [ +0.000033] ov13850 2-0010: Looking up avdd-supply from device tree [ +0.000015] ov13850 2-0010: Looking up avdd-supply property in node /i2c@ff120000/ov13850@10 failed [ +0.000027] 2-0010 supply avdd not found, using dummy regulator [ +0.000058] ov13850 2-0010: Looking up dovdd-supply from device tree [ +0.000014] ov13850 2-0010: Looking up dovdd-supply property in node /i2c@ff120000/ov13850@10 failed [ +0.000022] 2-0010 supply dovdd not found, using dummy regulator [ +0.000049] ov13850 2-0010: Looking up dvdd-supply from device tree [ +0.000015] ov13850 2-0010: Looking up dvdd-supply property in node /i2c@ff120000/ov13850@10 failed [ +0.000021] 2-0010 supply dvdd not found, using dummy regulator [ +0.003150] ov13850 2-0010: Unexpected sensor id(000000), ret(-5) [ +0.000492] Error: Driver 'sc031gs' is already registered, aborting... [ +0.001323] Registered cp15_barrier emulation handler [ +0.000140] Registered setend emulation handler [ +0.002711] registered taskstats version 1 [ +0.000038] Loading compiled-in X.509 certificates [ +0.003555] Btrfs loaded, integrity-checker=on [ +0.000107] BTRFS: selftest: Running btrfs free space cache tests [ +0.000028] BTRFS: selftest: Running extent only tests [ +0.000024] BTRFS: selftest: Running bitmap only tests [ +0.000026] BTRFS: selftest: Running bitmap and extent tests [ +0.000030] BTRFS: selftest: Running space stealing from bitmap to extent [ +0.001011] BTRFS: selftest: Free space cache tests finished [ +0.000008] BTRFS: selftest: Running extent buffer operation tests [ +0.000007] BTRFS: selftest: Running btrfs_split_item tests [ +0.000053] BTRFS: selftest: Running find delalloc tests [ +0.001457] mmc1: new HS200 MMC card at address 0001 [ +0.001533] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB [ +0.001983] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB [ +0.001046] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB [ +0.001123] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB [ +0.002187] mmcblk1: p1 p2 p3 p4 [ +0.340596] BTRFS: selftest: Running btrfs_get_extent tests [ +0.000204] BTRFS: selftest: Running hole first btrfs_get_extent test [ +0.000033] BTRFS: selftest: Running outstanding_extents tests [ +0.000050] BTRFS: selftest: Running qgroup tests [ +0.000007] BTRFS: selftest: Qgroup basic add [ +0.000053] BTRFS: selftest: Qgroup multiple refs test [ +0.048580] Key type encrypted registered [ +0.001210] rga2: Driver loaded successfully ver:3.02 [ +0.000510] rga2: Module initialized. [ +0.000451] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply from device tree [ +0.000037] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply property in node /power-management@ff310000/power-controller failed [ +0.000511] phy phy-ff770000.syscon:usb2-phy@e450.6: Looking up phy-supply from device tree [ +0.001091] phy phy-ff770000.syscon:usb2-phy@e450.7: Looking up phy-supply from device tree [ +0.000018] phy phy-ff770000.syscon:usb2-phy@e450.7: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed [ +0.000124] phy phy-ff770000.syscon:usb2-phy@e450.7: Looking up vbus-supply from device tree [ +0.000010] phy phy-ff770000.syscon:usb2-phy@e450.7: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed [ +0.000020] phy phy-ff770000.syscon:usb2-phy@e450.7: Failed to get VBUS supply regulator [ +0.001831] phy phy-ff7c0000.phy.8: Looking up phy-supply from device tree [ +0.000012] phy phy-ff7c0000.phy.8: Looking up phy-supply property in node /phy@ff7c0000/dp-port failed [ +0.000092] phy phy-ff7c0000.phy.9: Looking up phy-supply from device tree [ +0.000010] phy phy-ff7c0000.phy.9: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed [ +0.000203] [drm] Rockchip DRM driver version: v1.0.1 [ +0.000321] rockchip-drm display-subsystem: defer getting devfreq [ +0.000314] rockchip-vop ff900000.vop: missing rockchip,grf property [ +0.000216] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008c68818) [ +0.000043] rockchip-vop ff8f0000.vop: missing rockchip,grf property [ +0.000145] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008c68818) [ +0.000229] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ +0.003137] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008c5d890) [ +0.000091] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ +0.000018] [drm] No driver support for vblank timestamp query. [ +0.000620] rockchip-drm display-subsystem: failed to parse loader memory [ +0.000073] rockchip-drm display-subsystem: No connectors reported connected with modes [ +0.000095] [drm] Cannot find any crtc or sizes - going 1024x768 [ +0.013862] Console: switching to colour frame buffer device 128x48 [ +0.005016] rockchip-drm display-subsystem: fb0: frame buffer device [ +0.006449] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ +0.000625] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 3 [ +0.000274] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010 [ +0.000109] xhci-hcd xhci-hcd.7.auto: irq 231, io mem 0xfe800000 [ +0.000573] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ +0.000030] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ +0.000023] usb usb3: Product: xHCI Host Controller [ +0.000023] usb usb3: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd [ +0.000023] usb usb3: SerialNumber: xhci-hcd.7.auto [ +0.001550] hub 3-0:1.0: USB hub found [ +0.000046] hub 3-0:1.0: 1 port detected [ +0.000387] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ +0.000363] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 4 [ +0.000093] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ +0.000140] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ +0.000014] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ +0.000013] usb usb4: Product: xHCI Host Controller [ +0.000011] usb usb4: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd [ +0.000012] usb usb4: SerialNumber: xhci-hcd.7.auto [ +0.000671] hub 4-0:1.0: USB hub found [ +0.000039] hub 4-0:1.0: 1 port detected [ +0.002435] xhci-hcd xhci-hcd.7.auto: remove, state 1 [ +0.000034] usb usb4: USB disconnect, device number 1 [ +0.004728] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller [ +0.011767] xhci-hcd xhci-hcd.7.auto: Host not halted after 16000 microseconds. [ +0.000011] xhci-hcd xhci-hcd.7.auto: Host controller not halted, aborting reset. [ +0.000059] xhci-hcd xhci-hcd.7.auto: USB bus 4 deregistered [ +0.000067] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 5 [ +0.000158] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010 [ +0.000041] xhci-hcd xhci-hcd.8.auto: irq 232, io mem 0xfe900000 [ +0.000193] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ +0.000010] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ +0.000008] usb usb5: Product: xHCI Host Controller [ +0.000008] usb usb5: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd [ +0.000007] usb usb5: SerialNumber: xhci-hcd.8.auto [ +0.000375] hub 5-0:1.0: USB hub found [ +0.000026] hub 5-0:1.0: 1 port detected [ +0.000221] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller [ +0.000550] xhci-hcd xhci-hcd.7.auto: remove, state 1 [ +0.000040] usb usb3: USB disconnect, device number 1 [ +0.000075] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 6 [ +0.001045] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ +0.000061] xhci-hcd xhci-hcd.7.auto: USB bus 3 deregistered [ +0.000116] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003 [ +0.000015] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ +0.000012] usb usb6: Product: xHCI Host Controller [ +0.000013] usb usb6: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd [ +0.000011] usb usb6: SerialNumber: xhci-hcd.8.auto [ +0.000799] hub 6-0:1.0: USB hub found [ +0.000042] hub 6-0:1.0: 1 port detected [ +0.005069] ehci-platform fe380000.usb: EHCI Host Controller [ +0.000386] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 3 [ +0.000153] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000 [ +0.008751] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [ +0.000325] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ +0.000020] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ +0.000017] usb usb3: Product: EHCI Host Controller [ +0.000016] usb usb3: Manufacturer: Linux 4.4.213-rk3399 ehci_hcd [ +0.000016] usb usb3: SerialNumber: fe380000.usb [ +0.000973] hub 3-0:1.0: USB hub found [ +0.000059] hub 3-0:1.0: 1 port detected [ +0.001056] vendor storage:20190527 ret = 0 [ +0.000417] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [ +0.000462] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 4 [ +0.000242] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000 [ +0.061031] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ +0.000041] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ +0.000025] usb usb4: Product: Generic Platform OHCI controller [ +0.000024] usb usb4: Manufacturer: Linux 4.4.213-rk3399 ohci_hcd [ +0.000023] usb usb4: SerialNumber: fe3a0000.usb [ +0.001667] hub 4-0:1.0: USB hub found [ +0.000119] hub 4-0:1.0: 1 port detected [ +0.001850] input: adc-keys as /devices/platform/adc-keys/input/input1 [ +0.003226] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ +0.000084] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ +0.000034] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ +0.000067] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ +0.000060] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated. [ +0.000032] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree [ +0.000030] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed [ +0.000073] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree [ +0.000029] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed [ +0.000047] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ +0.000021] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ +0.000041] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp [ +0.000023] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup [ +0.000029] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe310000[0]' [ +0.000027] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe310000[0]' [ +0.000023] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup [ +0.000025] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed [ +0.000545] platform sdio-pwrseq: GPIO lookup for consumer reset [ +0.000024] platform sdio-pwrseq: using device tree for GPIO lookup [ +0.000077] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0) [ +0.000077] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq [ +0.015007] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ +0.015875] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized [ +0.000742] rockchip-dmc dmc: Looking up center-supply from device tree [ +0.000386] rockchip-dmc dmc: Failed to get leakage [ +0.000050] rockchip-dmc dmc: Looking up center-supply from device tree [ +0.000032] vdd_center: could not add device link dmc err -17 [ +0.000014] vdd_center: Failed to create debugfs directory [ +0.000013] rockchip-dmc dmc: Failed to get pvtm [ +0.000539] rockchip-dmc dmc: avs=0 [ +0.000044] rockchip-dmc dmc: failed to get vop pn to msch rl [ +0.001285] rockchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 [ +0.000031] rockchip-dmc dmc: could not find power_model node [ +0.004180] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/rt5651-sound[0]' [ +0.000016] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/rt5651-sound[0]' [ +0.018873] asoc-simple-card rt5651-sound: rt5651-aif1 <-> ff890000.i2s mapping ok [ +0.000100] asoc-simple-card rt5651-sound: ASoC: no source widget found for MICBIAS1 [ +0.000019] asoc-simple-card rt5651-sound: ASoC: Failed to add route MICBIAS1 -> direct -> Mic Jack [ +0.000333] rt5651 1-001a: ASoC: mux INL1 Mux has no paths [ +0.000029] rt5651 1-001a: ASoC: mux INR1 Mux has no paths [ +0.000025] rt5651 1-001a: ASoC: mux INL2 Mux has no paths [ +0.000025] rt5651 1-001a: ASoC: mux INR2 Mux has no paths [ +0.007796] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]' [ +0.000033] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]' [ +0.000951] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok [ +0.003935] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]' [ +0.000033] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]' [ +0.000588] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0 [ +0.000036] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22 [ +0.000019] asoc-simple-card spdif-sound: ASoC: can't create pcm ff870000.spdif-dit-hifi :-22 [ +0.000016] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22 [ +0.000316] asoc-simple-card: probe of spdif-sound failed with error -22 [ +0.000381] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply from device tree [ +0.000026] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply property in node /power-management@ff310000/power-controller failed [ +0.000103] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply from device tree [ +0.000022] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply property in node /power-management@ff310000/power-controller failed [ +0.000079] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply from device tree [ +0.000022] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply property in node /power-management@ff310000/power-controller failed [ +0.000256] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1) [ +0.000016] ======== dhd_wlan_init_plat_data ======== [ +0.000009] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ +0.000012] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=72, oob_irq_flags=0x414 [ +0.000007] dhd_wlan_init_gpio: WL_REG_ON=-1 [ +0.000007] dhd_wifi_platform_load: Enter [ +0.000007] Power-up adapter 'DHD generic adapter' [ +0.000051] wifi_platform_set_power = 1 [ +0.000006] ======== PULL WL_REG_ON(-1) HIGH! ======== [ +0.000007] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ +0.000008] [WLAN_RFKILL]: wifi turn on power. -1 [ +0.000818] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/button@0[0]' - status (0) [ +0.000089] gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set_debounce() operations [ +0.000429] input: gpio-keys as /devices/platform/gpio-keys/input/input2 [ +0.008953] mmc2: queuing unknown CIS tuple 0x80 (2 bytes) [ +0.001605] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ +0.001603] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ +0.002862] mmc2: queuing unknown CIS tuple 0x80 (7 bytes) [ +0.003401] mmc2: queuing unknown CIS tuple 0x81 (9 bytes) [ +0.052873] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0) [ +0.028758] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:11 UTC (1358499011) [ +0.000026] of_cfs_init [ +0.000109] of_cfs_init: OK [ +0.029945] PM: Hibernation image not present or could not be loaded. [ +0.000055] vcc_sd: disabling [ +0.000014] vcc_lcd: disabling [ +0.000108] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply from device tree [ +0.000023] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply property in node /power-management@ff310000/power-controller failed [ +0.000177] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply from device tree [ +0.000018] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply property in node /power-management@ff310000/power-controller failed [ +0.000088] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopb-supply from device tree [ +0.000017] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopb-supply property in node /power-management@ff310000/power-controller failed [ +0.000086] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopl-supply from device tree [ +0.000017] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopl-supply property in node /power-management@ff310000/power-controller failed [ +0.000062] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vo-supply from device tree [ +0.000017] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vo-supply property in node /power-management@ff310000/power-controller failed [ +0.000058] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply from device tree [ +0.000016] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply property in node /power-management@ff310000/power-controller failed [ +0.000072] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply from device tree [ +0.000016] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply property in node /power-management@ff310000/power-controller failed [ +0.001258] ALSA device list: [ +0.000011] #0: Dummy 1 [ +0.000009] #1: Loopback 1 [ +0.000008] #2: realtek,rt5651-codec [ +0.000009] #3: rockchip,hdmi [ +0.000892] Freeing unused kernel memory: 1088K [ +0.031827] usb 3-1: new high-speed USB device number 2 using ehci-platform [ +0.047099] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 181 [ +0.007013] mmc2: queuing unknown CIS tuple 0x91 (3 bytes) [ +0.000080] mmc2: new ultra high speed SDR104 SDIO card at address 0001 [ +0.081664] wifi_platform_bus_enumerate device present 1 [ +0.000017] ======== Card detection to detect SDIO card! ======== [ +0.000010] mmc2:mmc host rescan start! [ +0.003074] usb 3-1: New USB device found, idVendor=32e4, idProduct=9520 [ +0.000025] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ +0.000011] usb 3-1: Product: HD USB Camera [ +0.000010] usb 3-1: Manufacturer: HD Camera Manufacturer [ +0.001448] uvcvideo: Found UVC 1.00 device HD USB Camera (32e4:9520) [ +0.011558] bcmsdh_register: register client driver [ +0.000227] bcmsdh_sdmmc_probe: Enter num=1 [ +0.000107] bcmsdh_sdmmc_probe: Enter num=2 [ +0.000010] bus num (host idx)=2, slot num (rca)=1 [ +0.000010] found adapter info 'DHD generic adapter' [ +0.000038] sdioh_attach: set sd_f2_blocksize 256 [ +0.000029] sdioh_attach: sd clock rate = 0 [ +0.000155] dhdsdio_probe : no mutex held. set lock [ +0.000083] F1 signature read @0x18000000=0x15294345 [ +0.002645] F1 signature OK, socitype:0x1 chip:0x4345 rev:0x9 pkg:0x2 [ +0.000474] DHD: dongle ram size is set to 819200(orig 819200) at 0x198000 [ +0.000115] [dhd] dhd_conf_set_chiprev : chip=0x4345, chiprev=9 [ +0.000220] [dhd] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211 [ +0.000491] [dhd] CFG80211-ERROR) wl_setup_wiphy : SAE support [ +0.000941] [dhd] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile [ +0.000799] dhd_attach(): thread:dhd_watchdog_thread:e5 started [ +0.000217] dhd_attach(): thread:dhd_dpc:e6 started [ +0.000155] dhd_attach(): thread:dhd_rxf:e7 started [ +0.000017] dhd_deferred_work_init: work queue initialized [ +0.000010] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 2 [ +0.000043] dhd_bus_set_default_min_res_mask: Unhandled chip id [ +0.000178] sdioh_cis_read: func_cis_ptr[0]=0x10ac [ +0.005676] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1) [ +0.000890] Register interface [wlan0] MAC: 10:2c:6b:16:bd:a4 [ +0.000183] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 -> mode 0 [ +0.000019] dhd_wl_ioctl: returning as busstate=0 [ +0.000010] dhd_dbg_detach_pkt_monitor, 2204 [ +0.000011] dhd_bus_devreset: == Power OFF == [ +0.000211] bcmsdh_oob_intr_unregister: Enter [ +0.000008] bcmsdh_oob_intr_unregister: irq is not registered [ +0.000016] dhd_txglom_enable: enable 0 [ +0.000008] dhd_bus_devreset: WLAN OFF DONE [ +0.000034] wifi_platform_set_power = 0 [ +0.000009] ======== PULL WL_REG_ON(-1) LOW! ======== [ +0.000008] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ +0.000026] [WLAN_RFKILL]: wifi shut off power. [ +0.000011] dhdsdio_probe : the lock is released. [ +0.000196] dhd_module_init: Exit err=0 [ +0.316810] EXT4-fs (mmcblk1p1): INFO: recovery required on readonly filesystem [ +0.000013] EXT4-fs (mmcblk1p1): write access will be enabled during recovery [ +0.015828] EXT4-fs (mmcblk1p1): recovery complete [ +0.001288] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null) [ +0.191124] systemd[1]: System time before build time, advancing clock. [ +0.007280] ip_tables: (C) 2000-2006 Netfilter Core Team [ +0.002210] cgroup: cgroup2: unknown option "nsdelegate" [ +0.003313] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ +0.000443] systemd[1]: Detected architecture arm64. [ +0.004963] systemd[1]: Set hostname to <nanopim4>. [ +0.116408] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ +0.000018] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ +0.056596] systemd[1]: /lib/systemd/system/rk3399-bluetooth.service:10: Support for option SysVStartPriority= has been removed and it is ignored [ +0.009162] systemd[1]: /etc/systemd/system/serial-getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring [ +0.002520] systemd[1]: /etc/systemd/system/getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring [ +0.029931] random: systemd: uninitialized urandom read (16 bytes read, 83 bits of entropy available) [ +0.010076] random: systemd: uninitialized urandom read (16 bytes read, 83 bits of entropy available) [ +0.001169] systemd[1]: Created slice User and Session Slice. [ +0.000424] random: systemd: uninitialized urandom read (16 bytes read, 83 bits of entropy available) [ +0.000300] systemd[1]: Listening on Syslog Socket. [ +0.000207] random: systemd: uninitialized urandom read (16 bytes read, 83 bits of entropy available) [ +0.000228] systemd[1]: Listening on Journal Socket (/dev/log). [ +0.000349] random: systemd: uninitialized urandom read (16 bytes read, 83 bits of entropy available) [ +0.000135] systemd[1]: Listening on Journal Audit Socket. [ +0.000184] random: systemd: uninitialized urandom read (16 bytes read, 83 bits of entropy available) [ +0.000166] systemd[1]: Listening on udev Kernel Socket. [ +0.000187] random: systemd: uninitialized urandom read (16 bytes read, 83 bits of entropy available) [ +0.000032] systemd[1]: Reached target Remote File Systems. [ +0.000192] random: systemd: uninitialized urandom read (16 bytes read, 83 bits of entropy available) [ +0.000218] systemd[1]: Listening on Journal Socket. [ +0.000186] random: systemd: uninitialized urandom read (16 bytes read, 83 bits of entropy available) [ +0.002521] systemd[1]: Starting Nameserver information manager... [ +0.000872] random: systemd: uninitialized urandom read (16 bytes read, 83 bits of entropy available) [ +0.002556] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ +0.010121] systemd[1]: Mounting POSIX Message Queue File System... [ +0.004471] systemd[1]: Starting Load Kernel Modules... [ +0.003760] systemd[1]: Mounting Huge Pages File System... [ +0.004380] systemd[1]: Starting Set the console keyboard layout... [ +0.001194] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ +0.004219] systemd[1]: Starting Restore / save the current clock... [ +0.000565] systemd[1]: Reached target Slices. [ +0.001185] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ +0.001106] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ +0.000485] systemd[1]: Listening on fsck to fsckd communication Socket. [ +0.001353] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ +0.003675] systemd[1]: Starting File System Check on Root Device... [ +0.001391] systemd[1]: Listening on udev Control Socket. [ +0.006845] systemd[1]: Starting udev Coldplug all Devices... [ +0.003359] systemd[1]: Created slice system-serial\x2dgetty.slice. [ +0.000489] systemd[1]: Reached target Swap. [ +0.004591] systemd[1]: Mounting Kernel Debug File System... [ +0.001495] systemd[1]: Created slice system-getty.slice. [ +0.001470] systemd[1]: Listening on initctl Compatibility Named Pipe. [ +0.000461] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ +0.000091] systemd[1]: Reached target Local Encrypted Volumes. [ +0.000258] systemd[1]: Reached target Paths. [ +0.008869] systemd[1]: Started Create list of required static device nodes for the current kernel. [ +0.005697] systemd[1]: Mounted POSIX Message Queue File System. [ +0.000792] systemd[1]: Mounted Huge Pages File System. [ +0.000648] systemd[1]: Mounted Kernel Debug File System. [ +0.004725] systemd[1]: Started Load Kernel Modules. [ +0.004250] systemd[1]: Started Nameserver information manager. [ +0.003910] systemd[1]: Started Restore / save the current clock. [ +0.005528] systemd[1]: Started File System Check Daemon to report status. [ +0.006497] systemd[1]: Mounting FUSE Control File System... [ +0.005492] systemd[1]: Mounting Kernel Configuration File System... [ +0.006541] systemd[1]: Starting Apply Kernel Variables... [ +0.013998] systemd[1]: Mounted FUSE Control File System. [ +0.004813] systemd[1]: Started File System Check on Root Device. [ +0.002304] systemd[1]: Mounted Kernel Configuration File System. [ +0.009110] systemd[1]: Starting Remount Root and Kernel File Systems... [ +0.011769] systemd[1]: Started Apply Kernel Variables. [ +0.032612] EXT4-fs (mmcblk1p1): re-mounted. Opts: acl,commit=600,errors=remount-ro [ +0.006042] systemd[1]: Started Remount Root and Kernel File Systems. [ +0.004717] systemd[1]: Starting Load/Save Random Seed... [ +0.004871] systemd[1]: Starting Create System Users... [ +0.002590] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ +0.019984] systemd[1]: Started Load/Save Random Seed. [ +0.019415] systemd[1]: Started Create System Users. [ +0.004529] systemd[1]: Starting Create Static Device Nodes in /dev... [ +0.032607] systemd[1]: Started udev Coldplug all Devices. [ +0.005483] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ +0.003175] systemd[1]: Started Set the console keyboard layout. [ +0.014690] systemd[1]: Started Helper to synchronize boot up for ifupdown. [ +0.006938] systemd[1]: Started Create Static Device Nodes in /dev. [ +0.004987] systemd[1]: Reached target Local File Systems (Pre). [ +0.008051] systemd[1]: Mounting /tmp... [ +0.008264] systemd[1]: Starting udev Kernel Device Manager... [ +0.007716] systemd[1]: Mounted /tmp. [ +0.034968] systemd[1]: Started udev Kernel Device Manager. [ +0.068858] dhd_ioctl_entry: Interface is down [ +0.109362] dhd_ioctl_entry: Interface is down [ +0.056264] mali ff9a0000.gpu: Looking up mali-supply from device tree [ +0.002310] mali ff9a0000.gpu: leakage=27 [ +0.000066] mali ff9a0000.gpu: Looking up mali-supply from device tree [ +0.000037] vdd_gpu: could not add device link ff9a0000.gpu err -17 [ +0.000012] vdd_gpu: Failed to create debugfs directory [ +0.016830] mali ff9a0000.gpu: temp=60625, pvtm=122848 (122620 + 228) [ +0.000918] mali ff9a0000.gpu: pvtm-volt-sel=1 [ +0.000491] mali ff9a0000.gpu: avs=0 [ +0.002504] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0 [ +0.000198] mali ff9a0000.gpu: Protected mode not available [ +0.000577] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 [ +0.000048] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model [ +0.000131] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 423; [Func] : kbase_devfreq_init(); success initing power_model_simple. [ +0.001547] mali ff9a0000.gpu: Probed as mali0 [ +0.048605] systemd[1]: Found device /dev/disk/by-label/DATA. [ +0.066066] systemd[1]: Found device /dev/disk/by-label/HOME. [ +0.054366] systemd[1]: Found device /dev/ttyFIQ0. [ +0.043042] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ +0.001566] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ +0.000065] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ +0.000041] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ +0.002522] systemd[1]: Starting File System Check on /dev/disk/by-label/HOME... [ +0.004640] systemd[1]: Starting File System Check on /dev/disk/by-label/DATA... [ +0.002957] systemd[1]: Created slice system-systemd\x2dbacklight.slice. [ +0.005142] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight... [ +0.006596] systemd[1]: Starting Load/Save RF Kill Switch Status... [ +0.021854] systemd[1]: Started Load/Save Screen Backlight Brightness of backlight:backlight. [ +0.028501] [BT_RFKILL]: ENABLE UART_RTS [ +0.021412] systemd[1]: Started File System Check on /dev/disk/by-label/HOME. [ +0.011279] systemd[1]: Mounting /root... [ +0.010031] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: acl [ +0.007812] systemd[1]: Mounted /root. [ +0.041286] random: nonblocking pool is initialized [ +0.016155] [BT_RFKILL]: DISABLE UART_RTS [ +0.000045] [BT_RFKILL]: bt turn on power [ +0.002904] systemd[1]: Started Load/Save RF Kill Switch Status. [ +0.018578] systemd[1]: Started File System Check on /dev/disk/by-label/DATA. [ +0.016184] systemd[1]: Mounting /root/mvisia_edge_data... [ +0.006594] EXT4-fs (mmcblk1p4): mounted filesystem with ordered data mode. Opts: acl [ +0.005873] systemd[1]: Mounted /root/mvisia_edge_data. [ +0.005549] systemd[1]: Reached target Local File Systems. [ +0.008532] systemd[1]: Starting Set console font and keymap... [ +0.002877] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped. [ +0.002582] systemd[1]: Starting Raise network interfaces... [ +0.005109] systemd[1]: Starting Armbian ZRAM config... [ +0.001845] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ +0.001727] systemd[1]: Started Set console font and keymap. [ +0.127075] zram: Added device: zram0 [ +0.002007] zram: Added device: zram1 [ +0.001427] zram: Added device: zram2 [ +0.061455] systemd[1]: Started Raise network interfaces. [ +0.000698] zram1: detected capacity change from 0 to 1009115136 [ +0.023624] Adding 985460k swap on /dev/zram1. Priority:5 extents:1 across:985460k SS [ +0.089687] zram0: detected capacity change from 0 to 52428800 [ +0.028980] systemd[1]: Started Armbian ZRAM config. [ +0.013912] systemd[1]: Starting Armbian memory supported logging... [ +0.053579] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard [ +1.600622] cfg80211: World regulatory domain updated: [ +0.000017] cfg80211: DFS Master region: unset [ +0.000006] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) [ +0.000008] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [ +0.000006] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A) [ +0.000005] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A) [ +0.000005] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A) [ +0.000005] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s) [ +0.000005] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s) [ +0.000005] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A) [ +0.000005] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A) [ +0.330948] systemd[1]: Started Armbian memory supported logging. [ +0.004278] systemd[1]: Starting Journal Service... [ +0.211269] systemd[1]: Started Journal Service. [ +0.038392] systemd-journald[660]: Received request to flush runtime journal from PID 1 [ +1.180768] nr_pdflush_threads exported in /proc is scheduled for removal [ +4.139288] [BT_RFKILL]: ENABLE UART_RTS [ +0.101548] [BT_RFKILL]: DISABLE UART_RTS [ +0.000065] [BT_RFKILL]: bt turn on power [ +0.060274] ttyS0 - failed to request DMA, use interrupt mode [ +0.697800] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ +0.010796] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ +0.000123] dhd_open: Enter ffffffc07458f000 [ +0.000005] dhd_open : no mutex held. set lock [ +0.000008] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1) [ +0.000012] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0 [ +0.000006] wifi_platform_set_power = 1 [ +0.000005] ======== PULL WL_REG_ON(-1) HIGH! ======== [ +0.000006] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ +0.000007] [WLAN_RFKILL]: wifi turn on power. -1 [ +0.303089] sdio_reset_comm(): [ +0.031886] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ +0.023597] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0) [ +0.063895] mmc2: queuing unknown CIS tuple 0x80 (2 bytes) [ +0.006795] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ +0.006063] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ +0.010933] mmc2: queuing unknown CIS tuple 0x80 (7 bytes) [ +0.013545] mmc2: queuing unknown CIS tuple 0x81 (9 bytes) [ +0.203094] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0) [ +0.128876] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 181 [ +0.000050] sdioh_start: set sd_f2_blocksize 256 [ +0.000254] dhd_bus_devreset: == WLAN ON == [ +0.000066] F1 signature read @0x18000000=0x15294345 [ +0.002360] F1 signature OK, socitype:0x1 chip:0x4345 rev:0x9 pkg:0x2 [ +0.000449] DHD: dongle ram size is set to 819200(orig 819200) at 0x198000 [ +0.000097] dhd_bus_set_default_min_res_mask: Unhandled chip id [ +0.000809] dhd_os_open_image: /lib/firmware/rkwifi/config.txt (204 bytes) open success [ +0.000448] [dhd] dhd_conf_read_country : ccode = ALL [ +0.000011] [dhd] dhd_conf_read_country : regrev = 0 [ +0.000012] [dhd] dhd_conf_read_sdio_params : dhd_doflow = 1 [ +0.000018] [dhd] dhd_conf_read_others : srl = 15 [ +0.000010] [dhd] dhd_conf_read_others : lrl = 15 [ +0.000019] [dhd] dhd_conf_set_path_params : Final fw_path=/lib/firmware/rkwifi/fw_bcm43456c5_ag.bin [ +0.000007] [dhd] dhd_conf_set_path_params : Final nv_path=/lib/firmware/rkwifi/nvram_ap6256.txt [ +0.000006] [dhd] dhd_conf_set_path_params : Final clm_path=/lib/firmware/rkwifi/clm_bcm43456c5_ag.blob [ +0.000005] [dhd] dhd_conf_set_path_params : Final conf_path=/lib/firmware/rkwifi/config.txt [ +0.000337] dhd_os_open_image: /lib/firmware/rkwifi/fw_bcm43456c5_ag.bin (585884 bytes) open success [ +0.050686] dhd_os_open_image: /lib/firmware/rkwifi/nvram_ap6256.txt (2099 bytes) open success [ +0.000441] NVRAM version: AP6256_NVRAM_V1.1_08252017 [ +0.000506] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded. [ +0.074738] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us) [ +0.000279] bcmsdh_oob_intr_register: HW_OOB irq=72 flags=0x4 [ +0.000202] dhd_get_memdump_info: File [/data/misc/wifi/.memdump.info] doesn't exist [ +0.000010] dhd_get_memdump_info: MEMDUMP ENABLED = 2 [ +0.000756] Disable tdls_auto_op failed. -1 [ +0.000013] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 1 [ +0.000289] dhd_apply_default_clm: Ignore clm file /lib/firmware/rkwifi/clm_bcm43456c5_ag.blob [ +0.001399] Firmware up: op_mode=0x0005, MAC=10:2c:6b:16:bd:a4 [ +0.002907] dhd_preinit_ioctls Set scancache failed -23 [ +0.007609] Driver: 1.579.77.41.22 (r-20191105-2)(20191120-1) Firmware: wl0: Feb 11 2020 11:54:51 version 7.45.96.61 (be7af2d@shgit) (r745790) FWID 01-a41d86bd es7.c5.n4.a3 CLM: 9.2.9 (2016-02-03 04:34:31) [ +0.000208] dhd_txglom_enable: enable 1 [ +0.000007] [dhd] dhd_conf_set_txglom_params : txglom_mode=copy [ +0.000007] [dhd] dhd_conf_set_txglom_params : txglomsize=36, deferred_tx_len=0 [ +0.000006] [dhd] dhd_conf_set_txglom_params : txinrx_thres=128, dhd_txminmax=-1 [ +0.000006] [dhd] dhd_conf_set_txglom_params : tx_max_offset=0, txctl_tmo_fix=300 [ +0.000011] [dhd] dhd_conf_get_disable_proptx : fw_proptx=1, disable_proptx=-1 [ +0.000813] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64 [ +0.001276] dhd_pno_init: Support Android Location Service [ +0.020085] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created [ +0.000709] dhd_rtt_init : FTM is supported [ +0.000010] dhd_preinit_ioctls: SensorHub diabled 0 [ +0.000583] dhd_preinit_ioctls failed to set ShubHub disable [ +0.001345] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23 [ +0.000005] failed to get wnm_bsstrans_resp [ +0.000468] failed to set WNM capabilities [ +0.000223] [dhd] dhd_conf_set_country : set country ALL, revision 0 [ +0.000007] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created [ +0.000364] [dhd] CONFIG-ERROR) dhd_conf_set_bufiovar : country setting failed -2, len=12 [ +0.000313] [dhd] dhd_conf_set_country : Country code: US (US/0) [ +0.005271] [dhd-wlan0] wl_android_wifi_on : Success [ +0.043276] dhd_open : the lock is released. [ +0.000018] dhd_open: Exit ret=0 [ +0.064965] NET: Registered protocol family 17 [ +0.092172] P2P interface registered [ +0.000026] wl_cfgp2p_add_p2p_disc_if: wdev: ffffffc07a377800, wdev->net: (null) [ +0.015296] WLC_E_IF: NO_IF set, event Ignored [ +0.000913] P2P interface started [ +3.208246] Bluetooth: Core ver 2.21 [ +0.000118] NET: Registered protocol family 31 [ +0.000020] Bluetooth: HCI device and connection manager initialized [ +0.000031] Bluetooth: HCI socket layer initialized [ +0.000024] Bluetooth: L2CAP socket layer initialized [ +0.001439] Bluetooth: SCO socket layer initialized [ +0.014957] Bluetooth: HCI UART driver ver 2.3 [ +0.000028] Bluetooth: HCI UART protocol H4 registered [ +0.000018] Bluetooth: HCI UART protocol LL registered [ +0.000015] Bluetooth: HCI UART protocol ATH3K registered [ +0.000015] Bluetooth: HCI UART protocol Three-wire (H5) registered [ +0.000489] Bluetooth: HCI UART protocol Intel registered [ +0.000373] Bluetooth: HCI UART protocol BCM registered [ +0.000018] Bluetooth: HCI UART protocol QCA registered [ +0.104720] tty_port_close_start: tty->count = 1 port count = 2. [ +0.609035] [dhd-wlan0] wl_cfg80211_connect : Connecting with d8:47:32:72:3d:c4 ssid "FT Home3", len (8), sec=wpa2psk/mfpc/518, channel=6 [ +0.000983] dhd_dbg_start_pkt_monitor, 1724 [Feb24 19:14] [dhd-wlan0] wl_iw_event : Link UP with d8:47:32:72:3d:c4 [ +0.000032] [dhd-wlan0] wl_ext_iapsta_event : [S] Link UP with d8:47:32:72:3d:c4 [ +0.000032] [dhd-wlan0] wl_notify_connect_status : wl_bss_connect_done succeeded with d8:47:32:72:3d:c4 [ +0.092481] [dhd-wlan0] wl_notify_connect_status : wl_bss_connect_done succeeded with d8:47:32:72:3d:c4 vndr_oui: 8C-FD-F0 [ +0.400843] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx [ +2.324580] capability: warning: `python3' uses 32-bit capabilities (legacy support in use) [ +0.122108] gpio-54 (sysfs): gpiod_request: status -16 [ +0.000013] export_store: status -16 [ +0.017301] gpio-55 (sysfs): gpiod_request: status -16 [ +0.000012] export_store: status -16 [ +0.017416] gpio-145 (sysfs): gpiod_request: status -16 [ +0.000013] export_store: status -16 [ +0.000213] gpio-144 (sysfs): gpiod_request: status -16 [ +0.000005] export_store: status -16 [ +2.793376] gpio-54 (sysfs): gpiod_request: status -16 [ +0.000013] export_store: status -16 [ +0.034051] gpio-55 (sysfs): gpiod_request: status -16 [ +0.000021] export_store: status -16 [ +0.024398] gpio-145 (sysfs): gpiod_request: status -16 [ +0.000013] export_store: status -16 [ +0.000203] gpio-144 (sysfs): gpiod_request: status -16 [ +0.000006] export_store: status -16 [ +0.000113] gpio-149 (sysfs): gpiod_request: status -16 [ +0.000005] export_store: status -16 [ +0.000113] gpio-33 (sysfs): gpiod_request: status -16 [ +0.000005] export_store: status -16 [ +0.000097] gpio-50 (sysfs): gpiod_request: status -16 [ +0.000004] export_store: status -16 [ +0.000098] gpio-35 (sysfs): gpiod_request: status -16 [ +0.000005] export_store: status -16 [ +3.198805] tty_port_close_start: tty->count = 1 port count = 2. [ +0.340160] tty_port_close_start: tty->count = 1 port count = 2.
Werner Posted March 8, 2022 Posted March 8, 2022 Moved to P2P help. lacking proper logs 3rd party hardware please use spoiler for large pastes armbian.com/bugs
