Gabriel White Posted March 20, 2022 Posted March 20, 2022 (edited) I've been getting these errors when I run apt update / apt upgrade on an OrangePi One Plus: Err:13 https://apt.armbian.com/apt bullseye Release Redirection from https to 'http://imola.armbian.com/apt/apt/dists/bullseye/Release' is forbidden [IP: 173.45.128.12 443] if I edit /etc/apt/sources.list.d/armbian.list to be https://imola... it works fine. EDIT: armbian.list originally looked like this: deb https://apt.armbian.com/ bullseye main bullseye-utils bullseye-desktop and I changed it to look like this: deb https://imola.armbian.com/apt bullseye main bullseye-utils bullseye-desktop It seems that the https is being downgraded to http in the redirect, and this is making apt fail. Is this a server bug, or something I can solve at my end? Thanks, Gabe Edited March 20, 2022 by Gabriel White
therwastl07 Posted March 24, 2022 Posted March 24, 2022 I had similar problems. My solution was to run armbian-config and change the apt-mirrors to "EU mirrors" (I am in Germany) Maybe pick other ones better suited for you
Igor Posted March 24, 2022 Posted March 24, 2022 Usually this is a temporally problem. No need to change to specific mirrors. Problem is: deb https://apt.armbian.com/ bullseye main bullseye-utils bullseye-desktop APT re-director has issues with that and we have some dirty workaround in place ... which is not working best. New solution is in development. BTW. Full mirror list: https://github.com/armbian/mirror#packages
Gabriel White Posted March 24, 2022 Author Posted March 24, 2022 Just to be clear, the redirection was working, it's just that it was downgrading the connection to http (from https) in the process. It seems that the default configuration for the armbian repository has changed from "http" to "https" (I have an older armbian install, and the config points to "http" not "https"), and this was causing the apt error.
