beic Posted September 13, 2016 Share Posted September 13, 2016 Hi there, As the topic title says,... Is there any available option to install/setup Domoticz server onto Orange Pi Box using Armbian Desktop or Server version? Thank you! Kind regards Link to comment Share on other sites More sharing options...
zador.blood.stained Posted September 13, 2016 Share Posted September 13, 2016 We don't support third-party software hrer, but I would guess that something similar to official instructions may work: https://www.domoticz.com/wiki/Installing_and_running_Domoticz_on_CubieBoard2 Link to comment Share on other sites More sharing options...
beic Posted September 13, 2016 Author Share Posted September 13, 2016 We don't support third-party software hrer, but I would guess that something similar to official instructions may work: https://www.domoticz.com/wiki/Installing_and_running_Domoticz_on_CubieBoard2 "guess and something similar" wont help me, because I'm a beginner at Armbian! Link to comment Share on other sites More sharing options...
zador.blood.stained Posted September 13, 2016 Share Posted September 13, 2016 "guess and something similar" wont help me, because I'm a beginner at Armbian! Same with me and Domoticz. Instructions on the Wiki are pretty clear, you should try this method first. If there are issues, you can ask here or head to their forum and ask there since Orange Pi is just another ARM based board and Armbian is a Debian/Ubuntu based OS. Link to comment Share on other sites More sharing options...
beic Posted September 13, 2016 Author Share Posted September 13, 2016 Same with me and Domoticz. Instructions on the Wiki are pretty clear, you should try this method first. If there are issues, you can ask here or head to their forum and ask there since Orange Pi is just another ARM based board and Armbian is a Debian/Ubuntu based OS. Ok, I will try and report... But I already tried their pre-build image and it's not booting up! Link to comment Share on other sites More sharing options...
zador.blood.stained Posted September 13, 2016 Share Posted September 13, 2016 But I already tried their pre-build image and it's not booting up! Prebuilt image for which board? Images for Raspberry Pi or other boards like Cubieboard2/Cubietruck won't boot on Orange Pi One. Link to comment Share on other sites More sharing options...
beic Posted September 13, 2016 Author Share Posted September 13, 2016 Prebuilt image for which board? Images for Raspberry Pi or other boards like Cubieboard2/Cubietruck won't boot on Orange Pi One. Yeah, I figured that out now, here is the link what I found regarding Domoticz image. UPDATE: Also tried all on that link what you mentioned, but the script not recognize the board! Link to comment Share on other sites More sharing options...
lanefu Posted September 14, 2016 Share Posted September 14, 2016 Use the Orange Pi One armbian image and get your Opi on the network then follow their generic linux procedure..the dependecies look straightforward https://www.domoticz.com/wiki/Linux this step may step may get a bit bumpy because systemd is used now instead of init.d, but cross that bridge when you get there https://www.domoticz.com/wiki/Linux#Starting_Domoticz_automatically_when_the_system_boots Link to comment Share on other sites More sharing options...
beic Posted September 14, 2016 Author Share Posted September 14, 2016 Thank you! I will try that and report it back! Link to comment Share on other sites More sharing options...
MildaGenius Posted January 5, 2017 Share Posted January 5, 2017 According to tutorial for Linux it works for Orange Pi One, but is looong way. -basic upgrade 1h -compilation 1.5h For succes compilation is neccsenary 1GB RAM and because OPI has only 512MB we must use swap file instead. For more information check my post https://www.domoticz.com/forum/viewtopic.php?f=6&t=14870&p=112378#p112378. But for easy instal is better use: sudo curl -L install.domoticz.com | bash Use the Orange Pi One armbian image and get your Opi on the network then follow their generic linux procedure..the dependecies look straightforward https://www.domoticz.com/wiki/Linux this step may step may get a bit bumpy because systemd is used now instead of init.d, but cross that bridge when you get there https://www.domoticz.com/wiki/Linux#Starting_Domoticz_automatically_when_the_system_boots Link to comment Share on other sites More sharing options...
