Narly9999 Posted April 21, 2022 Posted April 21, 2022 need a case for the Opi? 3D printer case. https://www.thingiverse.com/thing:5361375
Werner Posted April 21, 2022 Posted April 21, 2022 moved to offtopic since I assume you do not need any help with that. 1
Narly9999 Posted April 23, 2022 Author Posted April 23, 2022 Not sure how that happened. Meh, Okay. This OPi ZERO2 still without GUI desktop?
Werner Posted April 24, 2022 Posted April 24, 2022 Not sure what this has to do with a 3D printed case but anyways yes, it seems like no desktop targets are enabled. I assume maintainer did tests on such and came to conclusion that the board is not ready yet to have a proper desktop experience. You can always build your own image with pre-installed DE but that comes without any support whatsoever. H616 itself is kind a barely supported by utilizing the vendor provided kernel. Take notes here: https://www.armbian.com/orange-pi-zero-2/ Also take note of board support rules: https://docs.armbian.com/User-Guide_Board-Support-Rules/
NeoFax Posted April 29, 2022 Posted April 29, 2022 On 4/20/2022 at 11:56 PM, Narly9999 said: need a case for the Opi? 3D printer case. https://www.thingiverse.com/thing:5361375 It doesn't look like this will work with the USB daughterboard. 1
Narly9999 Posted May 31, 2022 Author Posted May 31, 2022 On 4/29/2022 at 7:47 AM, NeoFax said: It doesn't look like this will work with the USB daughterboard. Which? I put up images with it assembled. I've reprinted and edited many times. Rev 8.6 currently.
