OrangePi3-LTS build error
Go to solution Solved by NeoFax,
Two days ago I was able to build a minimal server installation of Bullseye Armbian for this board with no problems.  My sd card crashed and I built the img file in tmp on a VM machine, so no backup (I know, live and learn).  Last night I tried building this img again, minimal server, desktop and all the bells and whistles, but it keeps failing.  Here is what I get:
LD [M] drivers/staging/rtl8723cs/8723cs.o
AR drivers/built-in.a GEN .version
CHK include/generated/compile.h
UPD include/generated/compile.h
CC init/version.o
AR init/built-in.a LD vmlinux.o
MODPOST vmlinux.symvers
MODINFO modules.builtin.modinfo GEN modules.builtin LD .tmp_vmlinux.kallsyms1 scripts/sign-file.c: In function ‘display_openssl_errors’: scripts/sign-file.c:89:9: warning: ‘ERR_get_error_line’ is deprecated: Since OpenSSL 3.0 [-Wdeprecated-declarations] 89 | while ((e = ERR_get_error_line(&file, &line))) { 411 | unsigned long ERR_get_error_line(const char **file, int *line); scripts/sign-file.c: In function ‘drain_openssl_errors’: scripts/sign-file.c:102:9: warning: ‘ERR_get_error_line’ is deprecated: Since OpenSSL 3.0 [-Wdeprecated-declarations] 102 | while (ERR_get_error_line(&file, &line)) {} 411 | unsigned long ERR_get_error_line(const char **file, int *line); scripts/extract-cert.c: In function ‘display_openssl_errors’: scripts/extract-cert.c:46:9: warning: ‘ERR_get_error_line’ is deprecated: Since OpenSSL 3.0 [-Wdeprecated-declarations] 46 | while ((e = ERR_get_error_line(&file, &line))) { 411 | unsigned long ERR_get_error_line(const char **file, int *line); scripts/extract-cert.c: In function ‘drain_openssl_errors’: scripts/extract-cert.c:59:9: warning: ‘ERR_get_error_line’ is deprecated: Since OpenSSL 3.0 [-Wdeprecated-declarations] 59 | while (ERR_get_error_line(&file, &line)) {} 411 | unsigned long ERR_get_error_line(const char **file, int *line);
make: *** [Makefile:1185: vmlinux] Error 1
[ error ] ERROR in function compile_kernel [ main.sh:589 -> main.sh:490 -> compilation.sh:507 -> general.sh:0 ]
[ error ] Kernel was not built [ @host ]
[ o.k. ] Process terminated
