Isaac Dias Posted September 17, 2016 Posted September 17, 2016 I've just installed the Armbian 5.20 in the Banana PI M2. No boot. The message "Waiting for PHY auto negotiation to complete .....Timeout! Could not initialize PHY ethernet@01c30000" shows up over and over again and the boot freezes in sequence. Somebody knows what is going on?
Igor Posted September 18, 2016 Posted September 18, 2016 I made a test boot and it works for me. Try one older image to see if that works for you: http://image.armbian.com/ and if it works issue and upgrade. Full bootlog from serial console would help to diagnose.
Isaac Dias Posted September 20, 2016 Author Posted September 20, 2016 Was a defective micro-sd card. I've changed the micro-sd card and now it's all ok. Unfortunately the Armbian 5.20 seems doesn't run 100% ok in the Banana PI M2. I have noted many artifacts in the screen, per exemple.
tkaiser Posted September 20, 2016 Posted September 20, 2016 Was a defective micro-sd card. @Igor: What about only recommending Etcher as burning tool from now on? Verify is mandatory there. Instantly 10 percent less support cases and more happy users.
