I have received an upgrade notification.
While applying changes, I received this message for 1 package (out of 5).
(Reading database ... 73767 files and directories currently installed.)
Preparing to unpack .../armbian-tools-xenial_5.20_armhf.deb ...
Unpacking armbian-tools-xenial (5.20) over (5.14) ...
dpkg: error processing archive /var/cache/apt/archives/armbian-tools-xenial_5.20_armhf.deb (--unpack):
 trying to overwrite '/etc/init.d/brcm40183-patch', which is also in package linux-xenial-root-orangepilite 5.16
Processing triggers for systemd (229-4ubuntu8) ...
Processing triggers for ureadahead (0.100.0-19) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Now, I have 4 packages partially installed and one not installed.
I have not rebooted the device.
What should I do?
Note: It is on an Orange Pi Lite.
Thanks in advance for your help.
Jean-Dominique.
I would give 'sudo apt-get install -f' a try and then reboot (see also this)
SOLVED !!!
after dist-upgrade and before of reboot :
be happy
thanks to
Igor and tkaiser
Thanks for the answer. But I still have an error.
root@orangepilite:~# sudo apt-get install -f
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up armbian-firmware (5.20) ...
Setting up linux-headers-sun8i (5.20) ...
Compiling headers - please wait ...
Setting up linux-image-sun8i (5.20) ...
update-initramfs: Generating /boot/initrd.img-3.4.112-sun8i
Setting up linux-u-boot-orangepilite-default (5.20) ...
root@orangepilite:~# apt-get upgrade
Calculating upgrade... Done
The following packages will be upgraded:
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/15,2 kB of archives.
Do you want to continue? [Y/n] Y
Still not yet rebooted
I'll try to produce an fix for those troubles tomorrow. In the mean time:
dpkg -r linux-xenial-root-orangepilite
apt-get -f install
apt-get upgrade
apt-get install linux-xenial-root-orangepilite
Thanks for this second response. Something has changed, because we get "which is also in... xenial 5.20" instead of "... pilite 5.16".
But I still get an error.
Also, I wonder why we receive a "get .... pilite 5.16" instead of "pilite 5.20". Are you sure that the correct version is available?
root@orangepilite:~# dpkg -r linux-xenial-root-orangepilite
Removing linux-xenial-root-orangepilite (5.16) ...
Processing triggers for initramfs-tools (0.122ubuntu8.1) ...
root@orangepilite:~# apt-get -f install
(Reading database ... 73684 files and directories currently installed.)
Setting up armbian-tools-xenial (5.20) ...
root@orangepilite:~# apt-get install linux-xenial-root-orangepilite
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 372 kB of archives.
After this operation, 1 024 B of additional disk space will be used.
Get:1 http://apt.armbian.comxenial/main armhf linux-xenial-root-orangepilite armhf 5.16 [372 kB]
Fetched 372 kB in 0s (400 kB/s)
Selecting previously unselected package linux-xenial-root-orangepilite.
(Reading database ... 73678 files and directories currently installed.)
Preparing to unpack .../linux-xenial-root-orangepilite_5.16_armhf.deb ...
Unpacking linux-xenial-root-orangepilite (5.16) ...
dpkg: error processing archive /var/cache/apt/archives/linux-xenial-root-orangepilite_5.16_armhf.deb (--unpack):
 trying to overwrite '/etc/default/brcm40183', which is also in package armbian-tools-xenial 5.20
Device still not rebooted.
I just found out that repository is partially broken and I need to rebuilt it. Some files for v5.2 are missing.
Far better with 5.20 :) :
root@orangepilite:~# apt-get --reinstall install linux-xenial-root-orangepilite
Need to get 360 kB of archives.
Get:1 http://apt.armbian.comxenial/main armhf linux-xenial-root-orangepilite armhf 5.20 [360 kB]
Fetched 360 kB in 2s (131 kB/s)
Preparing to unpack .../linux-xenial-root-orangepilite_5.20_armhf.deb ...
Unpacking linux-xenial-root-orangepilite (5.20) ...
Setting up linux-xenial-root-orangepilite (5.20) ...
Rebooted. OK.
Thanks x N… You can close the topic.
