Pasco35 Posted August 27, 2015 Posted August 27, 2015 Hello, I look for the instructions for use to install the new Kernel 3.4.108 for Debian Jessie on Olimex Lime 2 please. He was posted here: http://www.armbian.com/olimex-lime-2/ But he(it) disappeared. He explained us the lines of commands(orders) to create both files : "boot.scr" and "boot.cmd". Could you tell me where are these instructions for use please? Thank you very much... (sorry for bad english, i'm a froggy)
Igor Posted August 27, 2015 Posted August 27, 2015 (edited) I just uploaded new version yesterday where update method is changed / simplified but I haven't updated manual or publish upgrade script yet. I need few days to prepare documentations and to make sure upgrade works on all possible scenarios. Check this: http://forum.armbian.com/index.php/topic/203-416-cubietruck-nexttar-do-not-be-prepared/?p=1174 And this http://www.armbian.com/documentation/ Or wait few days. Edited September 9, 2015 by Igor altered link to proper manual
Pasco35 Posted August 27, 2015 Author Posted August 27, 2015 Hi, i wait few day yes, thank you very much :-)))))) 1
Pasco35 Posted August 27, 2015 Author Posted August 27, 2015 And i have Money for You, in a Few Days, bye.
Pasco35 Posted September 9, 2015 Author Posted September 9, 2015 Hi, please, i search the link and method for instal the new Kernel 3.4.108 for Olimex Lime2 ? thank you very much..
Igor Posted September 9, 2015 Posted September 9, 2015 I made some changes to docs too. Check here: * How to update kernel? http://www.armbian.com/documentation/
Pasco35 Posted November 15, 2015 Author Posted November 15, 2015 I made some changes to docs too. Check here: * How to update kernel? http://www.armbian.com/documentation/ Hello, The script of kernel-update (documentation) no start here. I look for the instructions for use to install the new Kernel 3.4.108 for Debian Jessie on Olimex Lime 2 please. He was posted here: http://www.igorpecov...bian-sd-image/ But he(it) disappeared. He explained us the lines of commands(orders) to create both files : "boot.scr" and "boot.cmd". Could you tell me where are these instructions for use please? The script no start here. Thank you very much Igor.
Igor Posted November 16, 2015 Posted November 16, 2015 If you don't have boot scripts and you are coming from some old kernel or different distribution, rather use this tools to upgrade: wget -q -O - http://upgrade.armbian.com | bash Make sure to make a backup if anything goes wrong. For manual procedure check this ... Boot script is here. Place to /boot/boot.cmd ... than recompile.
Pasco35 Posted November 16, 2015 Author Posted November 16, 2015 Thank you very much for this support Igor. But, It is exactly this procedure which does not work here. The line of following command creates me of multiple errors in the shell (root) : wget -q -O - http://upgrade.armbian.com| bash Ecoutez la traduction I thus look for the former(old) method that you had given there is approximately 6 in 8 months (before what contains the script) please? I remember that this line of command(order) was the last one to make in your former(old) procedure: mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr But before this last line of command(order), you gave it others (you gave the former(old) manual method to make to update the kernel), and that's what I try to find thanks to you today. Thank you very much Igor.
Pasco35 Posted November 17, 2015 Author Posted November 17, 2015 Hello Igor, I do not know if you remember yourselves, but the old method to update the Kernel was on this page http://www.armbian.com/olimex-lime-2/(it contained the old lines of command), thank you very much Igor. I always try to make you a transfer Payal. I wait for your help(assistant), thank you very much Igor...
Igor Posted November 17, 2015 Posted November 17, 2015 I don't understand what problems do you have. The manual procedure is written here. Here goes a copy / paste for your particular case: 1. You need to add repository if you don't already have it and update packages. echo "deb http://apt.armbian.com $(lsb_release -cs) main" > /etc/apt/sources.list.d/armbian.list apt-key adv --keyserver keys.gnupg.net --recv-keys 0x93D6889F9F0E78D5 apt-get update 2. Create boot script cd /boot rm boot.cmd wget https://raw.githubusercontent.com/igorpecovnik/lib/second/config/boot.cmd mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr 3. Install packages apt-get install linux-u-boot-lime2apt-get install linux-image-sun4iapt-get install linux-headers-sun4iapt-get install linux-firmware-image-sun4iapt-get install linux-$(lsb_release -cs)-root-lime2 If some package say some duplicate error or something, remove that package and install that one again. 4. Reboot
Pasco35 Posted November 17, 2015 Author Posted November 17, 2015 Ho Thank you very much, is operating ! My procedure : (i removed all packages with shell error during the install) 1. echo "deb http://apt.armbian.com $(lsb_release -cs) main" > /etc/apt/sources.list.d/armbian.list apt-key adv --keyserver keys.gnupg.net --recv-keys 0x93D6889F9F0E78D5 apt-get update 2. cd /boot rm boot.cmd wget https://raw.githubusercontent.com/igorpecovnik/lib/second/config/boot.cmd mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr 3. apt-get install linux-u-boot-lime2-next apt-get install linux-image-next-sunxi apt-get install linux-headers-next-sunxi apt-get install linux-firmware-image-next-sunxi apt-get install linux-dtb-next-sunxi apt-get install linux-$(lsb_release -cs)-root-next-lime2 4. reboot Thank you very much Igor, good "next"...
Pasco35 Posted November 17, 2015 Author Posted November 17, 2015 Oups... my uname -a root@lime2:/home/bambou2# uname -a Linux lime2 4.2.3-sunxi #2 SMP Sun Oct 11 14:12:18 CEST 2015 armv7l GNU/Linux root@lime2:/home/bambou2#
Igor Posted November 17, 2015 Posted November 17, 2015 Nice to hear that! I need to work further on the script to be more resilient - that it will done the job in absolutely all situations.
Pasco35 Posted November 17, 2015 Author Posted November 17, 2015 No, no, it's my fault, I had kept this old following files (I know it nothing on Linux), I removed them with Synaptic, (at this moment there the kernel 4.2.3 was installed with youre method) : linux-firmware-image-3.4.106 linux-firmware-image-3.4.107 linux-firmware-image-3.4.108and : linux-headers-3.4.106 linux-headers-3.4.107 linux-headers-3.4.108and : hostapd 1:2.3-1+deb8u3It had been months since I tried everything to change kernel,(but it was impossible without the old lines of manual commands). I have to break two three things, and badly to clean. It doesn't matter, see you soon, good continuation Igor, and thank you very much for your work. 1
