Lucas Nishimura Posted September 19, 2016 Posted September 19, 2016 Hello, I Just installed armbian in my cubieboard and dmesg is showing an annoying message: [ 70.366543] rc rc0: IR event FIFO is full! [ 70.382773] rc rc0: IR event FIFO is full! [ 70.398930] rc rc0: IR event FIFO is full! [ 70.414907] rc rc0: IR event FIFO is full! [ 70.430890] rc rc0: IR event FIFO is full! [ 70.446706] rc rc0: IR event FIFO is full! [ 70.462248] rc rc0: IR event FIFO is full! [ 70.477582] rc rc0: IR event FIFO is full! [ 70.492758] rc rc0: IR event FIFO is full! [ 70.507816] rc rc0: IR event FIFO is full! [ 70.522829] rc rc0: IR event FIFO is full! [ 70.537806] rc rc0: IR event FIFO is full! [ 70.552683] rc rc0: IR event FIFO is full! I did a search on forum and havent find anything related to this error: This is some usefull info: root@cubieboard2:~# cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=cubieboard2 BOARD_NAME="Cubieboard 2" VERSION=5.20 LINUXFAMILY=sunxi BRANCH=next ARCH=arm root@cubieboard2:~# And finally here is a link for armhwinfo.log: http://sprunge.us/eGhd
Igor Posted September 19, 2016 Posted September 19, 2016 I guess it must be some glitch in IR driver? To stop this flood try to blacklist the IR module.
Lucas Nishimura Posted September 19, 2016 Author Posted September 19, 2016 Hi Igor, Thanks for your repply, so this is what i Did: First checked with lsmod, loaded modules: root@cubieboard2:~# lsmod Module Size Used by sun4i_codec 11391 3 evdev 12164 1 snd_soc_core 130295 1 sun4i_codec snd_pcm_dmaengine 3455 1 snd_soc_core snd_pcm 77587 2 snd_soc_core,snd_pcm_dmaengine ir_lirc_codec 4920 0 snd_timer 19477 1 snd_pcm lirc_dev 8310 1 ir_lirc_codec snd 47687 3 snd_soc_core,snd_timer,snd_pcm soundcore 922 1 snd sun4i_ts 3990 0 nvmem_sunxi_sid 2159 0 nvmem_core 9078 1 nvmem_sunxi_sid sunxi_cir 3735 0 sun4i_ss 16066 0 cpufreq_dt 3432 0 thermal_sys 58884 2 cpufreq_dt,sun4i_ts uio_pdrv_genirq 3164 0 uio 8000 1 uio_pdrv_genirq bonding 105270 0 root@cubieboard2:~# Added the modules to blacklist: root@cubieboard2:~# cat /etc/modprobe.d/blacklist.conf | grep ir # most apps now use garmin usb driver directly (Ubuntu: #114565) blacklist ir_lirc_codec blacklist lirc_dev root@cubieboard2:~# Updated initramfs: root@cubieboard2:~# update-initramfs -u update-initramfs: Generating /boot/initrd.img-4.7.3-sunxi root@cubieboard2:~# Rebooted.... But still lsmod show me those modules: root@cubieboard2:~# lsmod Module Size Used by sun4i_codec 11391 3 evdev 12164 1 snd_soc_core 130295 1 sun4i_codec snd_pcm_dmaengine 3455 1 snd_soc_core snd_pcm 77587 2 snd_soc_core,snd_pcm_dmaengine ir_lirc_codec 4920 0 snd_timer 19477 1 snd_pcm lirc_dev 8310 1 ir_lirc_codec snd 47687 3 snd_soc_core,snd_timer,snd_pcm soundcore 922 1 snd sun4i_ts 3990 0 nvmem_sunxi_sid 2159 0 nvmem_core 9078 1 nvmem_sunxi_sid sunxi_cir 3735 0 sun4i_ss 16066 0 cpufreq_dt 3432 0 thermal_sys 58884 2 cpufreq_dt,sun4i_ts uio_pdrv_genirq 3164 0 uio 8000 1 uio_pdrv_genirq bonding 105270 0 So for now, i just unloaded them manually, if it works i will try to find out a permanent sollution, so for now thanks root@cubieboard2:~# rmmod ir_lirc_codec root@cubieboard2:~# rmmod lirc_dev [ 242.258275] IR MCE Keyboard/mouse protocol handler initialized [ 242.297565] IR XMP protocol handler initialized [ 249.871891] lirc_dev: module unloaded
Igor Posted September 19, 2016 Posted September 19, 2016 OK. Try blacklisting evdev or remove ir from device tree. I know it's annoying but I think it's safe to ignore ... until next update. Will pay attention to this.
Lucas Nishimura Posted September 20, 2016 Author Posted September 20, 2016 So for the sake of information had to disable these modules: blacklist ir_lirc_codec blacklist lirc_dev blacklist evdev blacklist sunxi-cir The reason i didit was because the board was hanging after a while (4 or 6 hours) after disabling those im already at 17Hour uptime Thanks 1
luiz_siam Posted September 29, 2016 Posted September 29, 2016 I've followed this post to remove that messages, too - and after blacklisting the 4 modules Lucas recommended in the last reply I realized that the power button has stopped working! In order to keep the power button working I had to remove the evdev mode from the blacklist. The button started working again and the FIFO error messages are still not showing up. Not sure about possible other consequences of this , but for now this is enough for me Thanks!
apollon77 Posted October 27, 2016 Posted October 27, 2016 Are there any news on an "official" solution on this? I'm updated to 5.23 on a cubietruck and also/still have this problem. I will try to blacklist the modules too ...
safari Posted November 21, 2016 Posted November 21, 2016 I've found this patch, but not tried, because now I have no need for LIRC: https://patchwork.kernel.org/patch/7715591/
inaciose Posted March 7, 2018 Posted March 7, 2018 This bug is still in debian version used in armbian 5.38. cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=bananapi BOARD_NAME="Banana Pi" BOARDFAMILY=sun7i VERSION=5.38 LINUXFAMILY=sunxi BRANCH=next ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage Tentative to solve it, only by creating the file bellow and reboot. cat /etc/modprobe.d/blacklist.conf blacklist ir_lirc_codec blacklist lirc_dev blacklist sunxi-cir Just one hour up and no more FIFO is full message.
