mjasner Posted May 10, 2022 Posted May 10, 2022 Armbianmonitor: http://ix.io/3Xsq I am attempting to install the v4l2loopback module for my device (Le Potato running Armbian 22.02.1 Bullseye) and am running to some issues. I installed linux-headers-5.10.102-meson64 since that matches the kernel image installed: marc@lepotato:/usr/src$ dpkg -l |grep linux-image ii linux-image-current-meson64 22.02.1 arm64 Linux kernel, armbian version 5.10.102-meson64 current marc@lepotato:/usr/src$ dpkg -l |grep linux-headers ii linux-headers-current-meson64 22.02.1 arm64 Linux kernel headers for 5.10.102-meson64 on arm64 current But when I try and install the v4l2loopback-dkms package I get the following: marc@lepotato:/usr/src$ sudo apt-get install v4l2loopback-dkms Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages were automatically installed and are no longer required: caffeine python3-ewmh python3-xlib Use 'sudo apt autoremove' to remove them. Suggested packages: v4l2loopback-utils The following NEW packages will be installed: v4l2loopback-dkms 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/36.2 kB of archives. After this operation, 115 kB of additional disk space will be used. Selecting previously unselected package v4l2loopback-dkms. (Reading database ... 195673 files and directories currently installed.) Preparing to unpack .../v4l2loopback-dkms_0.12.5-1_all.deb ... Unpacking v4l2loopback-dkms (0.12.5-1) ... Setting up v4l2loopback-dkms (0.12.5-1) ... Loading new v4l2loopback-0.12.5 DKMS files... Building for 5.10.102-meson64 Building initial module for 5.10.102-meson64 Error! Bad return status for module build on kernel: 5.10.102-meson64 (aarch64) Consult /var/lib/dkms/v4l2loopback/0.12.5/build/make.log for more information. dpkg: error processing package v4l2loopback-dkms (--configure): installed v4l2loopback-dkms package post-installation script subprocess returned error exit status 10 Errors were encountered while processing: v4l2loopback-dkms E: Sub-process /usr/bin/dpkg returned an error code (1) Looking into the error logs I see: marc@lepotato:/usr/src$ cat /var/lib/dkms/v4l2loopback/0.12.5/build/make.log DKMS make.log for v4l2loopback-0.12.5 for kernel 5.10.102-meson64 (aarch64) Tue 10 May 2022 01:21:37 PM EDT Building v4l2-loopback driver... make -C /lib/modules/5.10.102-meson64/build M=/var/lib/dkms/v4l2loopback/0.12.5/build modules make[1]: Entering directory '/usr/src/linux-headers-5.10.102-meson64' CC [M] /var/lib/dkms/v4l2loopback/0.12.5/build/v4l2loopback.o MODPOST /var/lib/dkms/v4l2loopback/0.12.5/build/Module.symvers make[3]: *** No rule to make target 'scripts/module.lds', needed by '/var/lib/dkms/v4l2loopback/0.12.5/build/v4l2loopback.ko'. Stop. make[3]: *** Waiting for unfinished jobs.... CC [M] /var/lib/dkms/v4l2loopback/0.12.5/build/v4l2loopback.mod.o make[2]: *** [scripts/Makefile.modpost:130: __modpost] Error 2 make[1]: *** [Makefile:1726: modules] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-5.10.102-meson64' make: *** [Makefile:43: v4l2loopback.ko] Error 2 I googled around for that error and found a lot of posts about it and found a suggested solution of downloading the module.lds file from git using: sudo wget https://raw.githubusercontent.com/torvalds/linux/master/scripts/module.lds.S -O /usr/src/[your linux header version here]/scripts/module.lds sudo sed -i '$ d' /usr/src/[your linux header version here]/scripts/module.lds but when I try and reinstall the v4l2loopback module after that I now get the following: marc@lepotato:/usr/src$ sudo apt-get install v4l2loopback-dkms Reading package lists... Done Building dependency tree... Done Reading state information... Done v4l2loopback-dkms is already the newest version (0.12.5-1). The following packages were automatically installed and are no longer required: caffeine python3-ewmh python3-xlib Use 'sudo apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] y Setting up v4l2loopback-dkms (0.12.5-1) ... Removing old v4l2loopback-0.12.5 DKMS files... ------------------------------ Deleting module version: 0.12.5 completely from the DKMS tree. ------------------------------ Done. Loading new v4l2loopback-0.12.5 DKMS files... Building for 5.10.102-meson64 Building initial module for 5.10.102-meson64 Error! Bad return status for module build on kernel: 5.10.102-meson64 (aarch64) Consult /var/lib/dkms/v4l2loopback/0.12.5/build/make.log for more information. dpkg: error processing package v4l2loopback-dkms (--configure): installed v4l2loopback-dkms package post-installation script subprocess returned error exit status 10 Errors were encountered while processing: v4l2loopback-dkms E: Sub-process /usr/bin/dpkg returned an error code (1) marc@lepotato:/usr/src$ cat /var/lib/dkms/v4l2loopback/0.12.5/build/make.log DKMS make.log for v4l2loopback-0.12.5 for kernel 5.10.102-meson64 (aarch64) Tue 10 May 2022 01:27:58 PM EDT Building v4l2-loopback driver... make -C /lib/modules/5.10.102-meson64/build M=/var/lib/dkms/v4l2loopback/0.12.5/build modules make[1]: Entering directory '/usr/src/linux-headers-5.10.102-meson64' CC [M] /var/lib/dkms/v4l2loopback/0.12.5/build/v4l2loopback.o MODPOST /var/lib/dkms/v4l2loopback/0.12.5/build/Module.symvers CC [M] /var/lib/dkms/v4l2loopback/0.12.5/build/v4l2loopback.mod.o LD [M] /var/lib/dkms/v4l2loopback/0.12.5/build/v4l2loopback.ko ld:scripts/module.lds:6: ignoring invalid character `#' in expression ld:scripts/module.lds:6: syntax error make[3]: *** [scripts/Makefile.modfinal:40: /var/lib/dkms/v4l2loopback/0.12.5/build/v4l2loopback.ko] Error 1 make[2]: *** [scripts/Makefile.modpost:130: __modpost] Error 2 make[1]: *** [Makefile:1726: modules] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-5.10.102-meson64' make: *** [Makefile:43: v4l2loopback.ko] Error 2 At this point I am stuck. Am I missing something obvious? Can someone point me in the right direction? Thanks in advance!
Werner Posted May 10, 2022 Posted May 10, 2022 I think this is a known issue. Still odd since Armbian does not touch modules.lds on packaging IIRC...
mjasner Posted May 10, 2022 Author Posted May 10, 2022 Is there a workaround or does this just not work at the moment?
