CPU temperature readout
Go to solution Solved by Robert Heller,
When I login on the console, there is this display with a bunch of information, including the CPU temp.  I have need to keep track of my CPU's temp, since it seems to be overheating (I have a heat sink on it, but does not seem to be enough -- I have a fan on order).  I want to be able to check the temp from time to time, so I would like to run at least the part of the login banner program.  What program is that?  I am not seeing anything obvious in /bin.
2 minutes ago, Werner said:
the motd temp comes from /etc/armbianmonitor/soctemp
OK, that is some large integer (and that is the wrong pathname -- the correct one is /etc/armbianmonitor/datasources/soctemp, which is a symlink to /sys/class/hwmon/hwmon0/temp1_input).  How is that converted to something like centagrade, etc.?  That is what units are the values under /sys/class/hwmon/hwmon0/?
BTW: I was already away of /sys/class/hwmon/.  I am looking for a more "human friendly" output, which I presume exists, since the motd output has it.  Or are you telling me that every time I want to check the CPU temp I need to go to a blank virtual term and log in?
  • Solution
OK, with more groveling I found /etc/update-motd.d/30-armbian-sysinfo, and it looks like /etc/armbianmonitor/datasources/soctemp (aka /sys/class/hwmon/hwmon0/temp1_input) in units of .001 C.  This is all I need.  Thanks.
Yes, my bad.
I know it is a symlink but I was not sure if that does not differ depending on SoC ;)
I just wanted to write about those scripts in /etc/update-motd.d you mentioned but you were faster :)
