Will Santana Posted May 18, 2022 Posted May 18, 2022 Hi, gotta ask a question Recently I just reinstalled all my XU4 based server from scratch. Brand new armbian Bullseye with OMV on top installed via armbian-config Then I noticed as seem bellow that half the cores (the low power ones) are idling, even when the system is fully under load on the high power cores The cores are enabled in the /sys/devices/system/cpu/cpuX/online files So the question is "what's wrong"? I don't have prints but I remember all the cores working before Thanks in advance Will
Igor Posted May 19, 2022 Posted May 19, 2022 15 hours ago, Will Santana said: So the question is "what's wrong"? That nobody knows anything about your situation: https://www.armbian.com/bugs/ 1
blacki2 Posted May 22, 2022 Posted May 22, 2022 Hi, I could not reproduce this behavior on my ODROID-XU4 with current Armbian (Armbian 22.02.1 Bullseye) : top - 14:41:54 up 1:22, 2 users, load average: 3,15, 0,77, 0,26 Tasks: 138 total, 9 running, 129 sleeping, 0 stopped, 0 zombie %CPU0 : 19,5 us, 79,8 sy, 0,0 ni, 0,0 id, 0,0 wa, 0,7 hi, 0,0 si, 0,0 st %CPU1 : 24,1 us, 75,2 sy, 0,0 ni, 0,0 id, 0,0 wa, 0,7 hi, 0,0 si, 0,0 st %CPU2 : 16,5 us, 82,8 sy, 0,0 ni, 0,0 id, 0,0 wa, 0,7 hi, 0,0 si, 0,0 st %CPU3 : 18,5 us, 81,1 sy, 0,0 ni, 0,0 id, 0,0 wa, 0,3 hi, 0,0 si, 0,0 st %CPU4 : 32,5 us, 66,9 sy, 0,0 ni, 0,0 id, 0,0 wa, 0,7 hi, 0,0 si, 0,0 st %CPU5 : 33,4 us, 65,6 sy, 0,0 ni, 0,0 id, 0,0 wa, 1,0 hi, 0,0 si, 0,0 st %CPU6 : 35,1 us, 63,9 sy, 0,0 ni, 0,0 id, 0,0 wa, 1,0 hi, 0,0 si, 0,0 st %CPU7 : 36,8 us, 62,3 sy, 0,0 ni, 0,0 id, 0,0 wa, 1,0 hi, 0,0 si, 0,0 st MiB Spch: 1990,5 total, 1496,8 free, 130,3 used, 363,3 buff/cache MiB Swap: 995,2 total, 995,2 free, 0,0 used. 1792,8 avail Spch xxx@odroidxu4:~$ uname -a Linux odroidxu4 5.4.181-odroidxu4 #22.02.1 SMP PREEMPT Sun Feb 27 08:55:42 UTC 2022 armv7l GNU/Linux I guess your application does not have multiple threads so it does not occupy all cores at once? 1
Will Santana Posted May 23, 2022 Author Posted May 23, 2022 On 5/22/2022 at 9:52 AM, blacki2 said: Hi, I could not reproduce this behavior on my ODROID-XU4 with current Armbian (Armbian 22.02.1 Bullseye) : top - 14:41:54 up 1:22, 2 users, load average: 3,15, 0,77, 0,26 Tasks: 138 total, 9 running, 129 sleeping, 0 stopped, 0 zombie %CPU0 : 19,5 us, 79,8 sy, 0,0 ni, 0,0 id, 0,0 wa, 0,7 hi, 0,0 si, 0,0 st %CPU1 : 24,1 us, 75,2 sy, 0,0 ni, 0,0 id, 0,0 wa, 0,7 hi, 0,0 si, 0,0 st %CPU2 : 16,5 us, 82,8 sy, 0,0 ni, 0,0 id, 0,0 wa, 0,7 hi, 0,0 si, 0,0 st %CPU3 : 18,5 us, 81,1 sy, 0,0 ni, 0,0 id, 0,0 wa, 0,3 hi, 0,0 si, 0,0 st %CPU4 : 32,5 us, 66,9 sy, 0,0 ni, 0,0 id, 0,0 wa, 0,7 hi, 0,0 si, 0,0 st %CPU5 : 33,4 us, 65,6 sy, 0,0 ni, 0,0 id, 0,0 wa, 1,0 hi, 0,0 si, 0,0 st %CPU6 : 35,1 us, 63,9 sy, 0,0 ni, 0,0 id, 0,0 wa, 1,0 hi, 0,0 si, 0,0 st %CPU7 : 36,8 us, 62,3 sy, 0,0 ni, 0,0 id, 0,0 wa, 1,0 hi, 0,0 si, 0,0 st MiB Spch: 1990,5 total, 1496,8 free, 130,3 used, 363,3 buff/cache MiB Swap: 995,2 total, 995,2 free, 0,0 used. 1792,8 avail Spch xxx@odroidxu4:~$ uname -a Linux odroidxu4 5.4.181-odroidxu4 #22.02.1 SMP PREEMPT Sun Feb 27 08:55:42 UTC 2022 armv7l GNU/Linux I guess your application does not have multiple threads so it does not occupy all cores at once? I'm using OMV ontop of armbian with multiple containers despite the processes (like greyhole and mariadb) running in the host itself Maybe it's something related to the kernel mods that OMV does to Armbian I've been using armbian + OMV for a few years now and never noticed this behaviour before. If it wasn't such a job switching back to an old release to test again, I would do it I moved some containers to a C2 I had for the moment but using "half" the processing power of the XU4 is such a shame
blacki2 Posted May 24, 2022 Posted May 24, 2022 I just found this OMV forum entry: https://forum.openmediavault.org/index.php?thread/30093-configure-cpus-cores/ maybe you can convince OMV to use all cores with this (taskset). Since I am no OMV user I did not dig further in this. 1
Will Santana Posted May 24, 2022 Author Posted May 24, 2022 Just an update I made a fresh install of the same (armbian image 22.01 and then upgraded all available packages), on another SD card and proceeded to load test again with armbianmonitor All cores peaked arount 100% as usual. Installed OMV and even greyhole and no change. All kept working Got back to my installation and thought the only big piece missing was the docker serivce. Stoped docker (and thus it's containers) and all the cores got back to normal. At least for a few minutes. After 1 or 2 tests I realized two cores stuck at 0% again A few reboots (no changes made) and I was able to use all cores even with docker and some containers running as shown bellow Unfurnatelly after some load tests, some cores got stuck again The last thing I'm thinking of is that the new installation runs out of an SSD and a new USB to SATA bridge. The SSD is healthy and fine, but maybe it's causing an overrun. Or maybe a faulty SATA brigde stalling IO operations and locking the cores I'll be back as soon I can with further tests Att, Will
