mr412 Posted May 24, 2022 Posted May 24, 2022 Hi, does anyone have experience with video playback? is playing 1080p in anyway possible? Which image would you recommend for Orange Pi Zero 2 H616 1GB? Is a desktop x11 mandatory? 0 Quote
qiurui Posted May 29, 2022 Posted May 29, 2022 x11 may be ok,but decode may be not supported. should be test. 0 Quote
Werner Posted May 29, 2022 Posted May 29, 2022 Just basic functionality has been mainlined yet. Do not expect things like graphics/video work well/work at all yet. 0 Quote
mr412 Posted June 2, 2022 Author Posted June 2, 2022 thank you for your answers. i have tried everything possible. every vaapi driver with vlc and mpv compiled etc. at 720p is the maximum. no hardware decoding possible. very sad. 0 Quote
nnb1972 Posted June 3, 2022 Posted June 3, 2022 I am playing around this. Скрытый текст pi@orangepioneplus:~$ uname -a Linux orangepioneplus 5.17.11-sunxi64 #22.05.1 SMP Sat May 28 08:25:47 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux pi@orangepioneplus:~$ vainfo libva info: VA-API version 1.14.0 libva info: User environment variable requested driver 'v4l2_request' libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/v4l2_request_drv_video.so libva info: Found init function __vaDriverInit_1_14 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.14 (libva 2.12.0) vainfo: Driver version: v4l2-request vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointVLD VAProfileH264High : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointVLD VLC media player 3.0.16 Vetinari (revision 3.0.13-8-g41878ff4f2) [0000aaaaddd88ca0] dummy interface: using the dummy interface module... [0000ffff40004ec0] gl gl: Initialized libplacebo v4.192.1 (API v192) libva info: VA-API version 1.14.0 libva info: User environment variable requested driver 'v4l2_request' libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/v4l2_request_drv_video.so libva info: Found init function __vaDriverInit_1_14 libva info: va_openDriver() returns 0 v4l2-request: VIDIOC_CREATE_BUFS ioctl create 32 buffers of type=1 v4l2-request: Unable to query buffer: Invalid argument (index=32 type=1) v4l2-request: surface.c: Unable to query buffer: (index=32 type=1, surfaces_count=36) [0000ffff40004ec0] glconv_vaapi_x11 gl error: vaCreateSurfaces: resource allocation failed [0000ffff5009a7f0] main video output error: video output creation failed [0000ffff58c1ae40] main decoder error: failed to create video output 0 Quote
ALIGMSTEN Posted April 27, 2023 Posted April 27, 2023 8 hours ago, garfius said: What have you used? SEE: fellow member @mcerveny efforts I tried to setup/enable some other components and I am successful with upstream linux kernel 6.2RC5: - displayengine (drm, fb, mixer, tcon, hdmi) (seems to have some I2C/EDID problems) - videoengine (cedrus) (in testing now) - gpu (3d mali, panfrost) 0 Quote
sakesm Posted June 15, 2024 Posted June 15, 2024 This I tried in Zero3 was no problem, although it was a long time ago @mr412 0 Quote
