Werner Posted May 30, 2022 Posted May 30, 2022 Board Dimensions: 90mm x 122mm x 16mm Heatsink Dimensions: 100mm x 123mm x 19mm Weight: 253 g including heatsink Rockchip RK3568 Processor L1 instruction cache: 32 KB, 4-way set associative (128 sets), 64 byte lines, shared by 1 processor L1 data cache: 32 KB, 4-way set associative (128 sets), 64 byte lines, shared by 1 processor L3 data cache: 512KB , 16-way set associative (512 sets), 64 byte lines, shared by 4 processorsQuad-Core Cortex-A55 (1.992GHz) ARMv8-A architecture with Neon and Crypto extensions Mali-G52 MP2 GPU with 4 x Execution Engines (650Mhz) 0.8Tops@INT8, integrated high-performance AI accelerator RKNN NPU Supports one-click switching of Caffe/TensorFlow/TFLite/ONNX/PyTorch/Keras/Darknet 4 or 8GiB LPDDR4 with 32-bit bus width memory Data rate: 3120 MT/s, up to 1,560MHz 1 x eMMC slot 1 x Micro SD slot (DS/HS mode up to UHS-I SDR104) 1 x NVME M.2 SSD (PCIe 3.0 x 2) 1 x SATA3.0 1 x GbE LAN ports (RJ45, supports 10/100/1000 Mbps) Realtek RTL8211F (Ethernet transceiver) LED indicators Green LED: Flashing by data traffics at 100Mbps connection Amber LED: Flashing by data traffics at 1000Mbps connection 1 x HDMI 2.0 (up to 4K@60Hz with HDR, EDID) 1 x MIPI-DSI (works with 800 x 1280 LCD) 1 x 3.5mm phone jack 1 x mono speaker output 1 x HDMI sound 2 x USB 2.0 host port 2 x USB 3.0 host port (or 1 x USB 3.0 host + 1 x USB 2.0 OTG port) 1 x Debug serial console (UART, 1.5Mbps N81) 1 x SATA Connector 1 x MIPI-CSI Camera Interface (15 pin) 1 x MIPI-DSI LCD Interface (31 pin) 1 x 40pin GPIO header IR receiver for remote controller RTC and backup battery holder (to keep time and date for several months without main power input) System LED Indicators: Red (POWER) – Solid light when DC power is connected Blue (ALIVE) – Flashing “heartbeat” while Kernel is running. Solid On when in the u-boot stage. 1 x DC jack : outer (negative) diameter 5.5mm, inner (positive) diameter 2.1mm DC input : 7.5V ~ 15.5V DC 12V/2A power adapter is recommended IDLE : ≃ 1.25W CPU Stress : ≃ 4.44W (Performance governor) Power Off : ≃ 0W https://www.hardkernel.com/shop/odroid-m1-with-8gbyte-ram/
