Josep Posted June 10, 2022 Posted June 10, 2022 I am not able install and boot ARMBIAN on an Orange Pi 3 LTS I am new to Orange Pi and only have basic experience as a Linux user. / I downloaded this image file from Armian website :-I Armbian_22.05.1_Orangepi3_bullseye_current_5.15.43.img.xz / Formated a Scandisk 32GB A1 card using SDcardformatterv5 / Used usbimager_1.0.8_wo-i686-win-gdi to write the image to the card Problem: I repeated thew procedure above 3 times but OS doesn't install, This is the log I get on the screen.. (unable to send screenshot - error 200), but the last lines are as fgollows:' "Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmd line) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=f20b78ef-d46e=4767-aa4c-33d3f7db7350 does not exist. Droping to shell! (initranfs) I will appreciate if someone can give me some hints on what I am doing wrong. Board: Not on the list
Myron Posted June 13, 2022 Posted June 13, 2022 Clutching at straws here as I'm not familiar with this SBC. What is the rated output of the PSU you are using to power your SBC? I believe it needs to be a minimum of 3 amps at 5 volts. Also, some of the hardware on the LTS version is different to the non-LTS version of the Orange Pi 3. I'm assuming the device tree will be different? At an absolute guess, is the device tree for the Orange Pi 3 incompatible with Orange Pi 3 LTS?
pierre-pret Posted June 13, 2022 Posted June 13, 2022 Orange PI 3 image won't work on Orange PI 3 LTS board. See these images instead: https://imola.armbian.com/dl/orangepi3-lts/nightly/ https://github.com/armbian/build/pull/3628 From my experience 5.16 worked, then 5.17 had WiFi issues, but latest master 5.18 works again. Currently working on submitting pull request for bluetooth support.
