Hi, I've flashed new 4.1.6 image on r1 but u-boot won't start,here a tty com screen:
U-Boot SPL 2015.10-rc2-00119-g7d31c6a-dirty (Aug 26 2015 - 06:23:09)
DRAM: 1024 MiB
CPU: 912000000Hz, AXI/AHB/APB: 3/2/2
DRAM: 1024 MiB
DRAM: 1024 MiB
DRAM: 1024 MiB
i have the same issue, but not only with the 4.1.6.
I tryed :
Armbian_4.2_Lamobo-r1_Ubuntu_trusty_4.1.6
Armbian_4.2_Lamobo-r1_Debian_jessie_4.1.6
Armbian_4.2_Lamobo-r1_Debian_jessie_3.4.108
still the same problem.
Please leave a message if the new immages are uploaded.
Thank You
Con
Yes, they are all re-uploaded. Maybe you download them too fast? (server needs up to one hour for mirroring)
Everything is the same but build date must be today.
Build date: 31.08.2015 (armbian.txt inside zip)
I test some of them.
Hi Igor,
I'm hitting the same issue(u-boot loop) when I build armbian with uboot-latest from source.
Was there a fix for this in armbian git as well?
thanks
Ram
Primary git is not yet updated, new (branch second) is under testing and last fixing ...
Set u-boot tag to v2014.04 and it will work. R1 has troubles with current uboot. I haven't got time to look into details.
it doesn't work.
U-Boot 2015.04-dirty (Aug 31 2015 - 15:47:15) Allwinner Technology
CPU:   Allwinner A20 (SUN7I)
I2C:   ready
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0
In:    serial
Out:   serial
Err:   serial
SCSI:  SUNXI SCSI INIT
SATA link 0 timeout.
AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part ccc apst
Net:   dwmac.1c50000
starting USB...
USB0:   USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
USB1:   USB EHCI 1.00
scanning bus 1 for devices... 2 USB Device(s) found
6944 bytes read in 142 ms (46.9 KiB/s)
RLE Bitmap unsupported in video mode 0xea000016
bmp - manipulate BMP image data
Usage:
bmp info <imageAddr>          - display image info
bmp display <imageAddr> [x y] - display image at x,y
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
1821 bytes read in 212 ms (7.8 KiB/s)
0 bytes read in 121 ms (0 Bytes/s)
25412 bytes read in 213 ms (116.2 KiB/s)
5349616 bytes read in 474 ms (10.8 MiB/s)
Kernel image @ 0x46000000 [ 0x000000 - 0x51a0f0 ]
## Flattened Device Tree blob at 49000000
   Booting using the fdt blob at 0x49000000
   Using Device Tree in place at 49000000, end 49009343
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
I will try the debian image at next.
con
OK. All images must work :P They are tested ... some problems might occur only with Jessie on certain Cubietruck boards as reported.
