Superkoning Posted July 4, 2023 Posted July 4, 2023 33 minutes ago, riscvboy said: Where can I find these images? In the first post of this thread. 0 Quote
balbes150 Posted July 5, 2023 Author Posted July 5, 2023 13 часов назад, riscvboy сказал: Where can I find these images? Nezha_D1 = Mangopi 0 Quote
balbes150 Posted July 6, 2023 Author Posted July 6, 2023 forum MangoPI https://forum.mangopi.org/ 1 Quote
wbn Posted July 7, 2023 Posted July 7, 2023 (edited) @balbes150, thank you for your incredible work on these RISC-V builds. I am using the nezha 20230630-current sid image on my Mango Pi MQ-Pro and it works well. However there seems to be no vector extension (RVV) support. This makes sense because the vector support in the kernel is not yet included mainline (not even 6.4) as far as I can tell. Although @msomeone previously reported RVV support in 6.1.0-rc3 and I am curious how that was accomplished. In any case my `/proc/cpuinfo` does not report the V extension. $ cat /proc/cpuinfo processor : 0 hart : 0 isa : rv64imafdc mmu : sv39 uarch : thead,c906 mvendorid : 0x5b7 marchid : 0x0 mimpid : 0x0 $ uname -a Linux chiyu 6.1.0-rc3-d1 #23.06 Fri Jun 30 21:26:26 MSK 2023 riscv64 GNU/Linux And attempting to run a test program (something like this) that contains a vector instruction will trap and halt the program. Program received signal SIGILL, Illegal instruction. add_data_vec_8 () at test.S:9 9 vsetvli t0, a3, e8,m1 # Vectors of 8b I would like some more information about enabling RVV on these boards, if that is possible. I could rebuild my kernel from the master branch using the config in `/boot` (plus enabling the RVV kernel config params), but I don't know if that would get me anywhere. Edited July 7, 2023 by wbn 0 Quote
balbes150 Posted July 7, 2023 Author Posted July 7, 2023 10 часов назад, wbn сказал: but I don't know if that would get me anywhere. I have a lot of work right now and a vacation is coming soon, try it, maybe there will be a result. 0 Quote
wbn Posted July 10, 2023 Posted July 10, 2023 I went and recompiled the kernel from master using the existing configuration file, `make menuconfig` to turn on the RVV-related params, `make` and then `make bindeb-pkg` to generate dpkg archives. But no luck - installing the packages prevented my Mango Pi from booting so I'm on my backup SD card. I'm not able to connect to uart0 either, so I'm rather in the dark on what is going wrong during the boot process. I'll leave my modified kernel config file here for anyone who's interested, and keep experimenting with kernel builds. config-6.4.0+ 0 Quote
Superkoning Posted July 10, 2023 Posted July 10, 2023 (edited) @wba did you read & watch It seems like a big task. But what can I say: that youtube video was already too complicated for me. Other posts https://www.reddit.com/r/RISCV/new/ seem to indicate it also involves the compiler and other tools Edited July 10, 2023 by Superkoning 0 Quote
balbes150 Posted July 10, 2023 Author Posted July 10, 2023 kernel 6.5-rc1 info https://forum.mangopi.org/t/armbiantv-and-altlinux-for-allwinner-d1-risc-v/2171/2?u=balbes-150 1 Quote
wbn Posted July 10, 2023 Posted July 10, 2023 3 hours ago, Superkoning said: @wba did you read & watch It seems like a big task. But what can I say: that youtube video was already too complicated for me. Other posts https://www.reddit.com/r/RISCV/new/ seem to indicate it also involves the compiler and other tools Thanks. No, I didn't see that before. Having watched a bit of it, now I understand that there is a difference between the vector ISA extension implemented by the T-head core inside the D1 (0.7.1-draft) and the vector ISA extension targeted by the mainline kernel (1.0.0). I failed to catch this up until now. Well, it's not mentioned anywhere on the linux-sunxi wiki page for the D1, which is odd. But now looking through the comments on Reddit and Youtube and some kernel mailing list threads etc. I see that there has been an ongoing discussion about this for a while. In any case, of course this means that just compiling a mainline kernel with RVV support flags enabled won't make vector work on my Mango Pi MQ-Pro. Also, it won't do to use any random test program for RVV to test the D1's vector instructions, since those are likely to target the 1.0.0 spec as well. It looks like there are some demo programs that target the spec implemented by T-head specifically (xuantie-vector-demos), so I will try with those instead. But I don't expect to make much progress in light of this... 0 Quote
Superkoning Posted July 10, 2023 Posted July 10, 2023 Yes, RVV 0.7.1 versus RVV 1.0. Enabling RVV 0.7.1 seems like a minefield / swamp. With a lot of tools that need to be enabled for RVV 0.7.1, and the powers that be are not in favour of that. On https://www.reddit.com/r/RISCV/new/ follow the wise but sobering words of Bruce Hoult. 1 Quote
DarkevilPT Posted September 15, 2023 Posted September 15, 2023 Hey Balbes none of the 6.5.0 Images work. Only those of the 5.19 kernel do. This has been getting updates and updates but... we are way stuck behind.. 0 Quote
balbes150 Posted September 16, 2023 Author Posted September 16, 2023 15.09.2023 в 03:08, DarkevilPT сказал: none of the 6.5.0 Images work. I checked the startup - the system is working. I pay attention to this message, HDMI does not work for the EDGE kernel. If you need HDMI, use LEGACY and CURRENT versions. 0 Quote
DarkevilPT Posted September 16, 2023 Posted September 16, 2023 (edited) 11 hours ago, balbes150 said: If you need HDMI, use LEGACY and CURRENT versions. You are right CURRENT version 6.1 kernel xcfe did worked now. I feel stupid ... I tried so many images wtf.. Edited September 16, 2023 by DarkevilPT 0 Quote
balbes150 Posted September 17, 2023 Author Posted September 17, 2023 Ver 20230917-edge kernel 6.6.-rc1 for Nezha (Allwinner D1) (HDMI not work) 0 Quote
balbes150 Posted September 29, 2023 Author Posted September 29, 2023 Ver 20230929-current kernel 6.6.-rc3 for VisionFive V1 (jh7100) 0 Quote
balbes150 Posted October 1, 2023 Author Posted October 1, 2023 Version 20230930-current for Nezha and other models based on Allwinner D1. U-boot has changed. Added support for direct system startup from USB. This will make it easy to run additional systems without changing the SD card, simply by connecting a USB flash drive with the new system. Launch from USB on Nezha and Mangope MQ Pro models has been tested. On theLicheRVr model, the USB flash drive has not been determined, perhaps another USB flash drive model is needed. 0 Quote
artiFL Posted November 1, 2023 Posted November 1, 2023 Good afternoon, there was a problem when assembling the image for the Lichee RV Nezha board on the Ubuntu system 04.22.3 error ] ERROR in function compile_uboot [ main.sh: 588 -> main.sh:481 -> compilation.sh:238 -> general.sh:0 ] error ]U-boot compilation failed Spoiler [ o.k. ] Prepare config [ grub-riscv64-d1 ]rinting │ │ [ o.k. ] Prepare config Ubuntu [ grub-riscv64-d1 ]esktop │ │ [ o.k. ] Preparing [ host ] Shells │ │ [ o.k. ] Build host OS release [ jammy ] System-info-tools │ │ [ .... ] Installing build dependencies Terminals │ │ [ o.k. ] Syncing clock [ host ]──────────────────────────────────100%────┘ │ [ o.k. ] Checking for external GCC compilers ──────────────────────────────┤ [ warn ] Low free space left [ 4 GiB ] <Cancel> │ Press <Ctrl-C> to abort compilation, <Enter> to ignore and continue────────┘ [ o.k. ] Downloading sources [ o.k. ] Checking git sources [ u-boot d1-wip ] [ .... ] Up to date [ o.k. ] Checking git sources [ linux-riscv riscv/d1-wip ] [ .... ] Up to date [ o.k. ] Cleaning /home/arti/Desktop/sipeed/build/output/debs for [ nezha current ] [ o.k. ] Cleaning [ u-boot/d1-wip ] [ o.k. ] Compiling u-boot [ 2024.01-rc1 ] [ o.k. ] Compiler version [ riscv64-linux-gnu-gcc 11 ] [ .... ] Checking out to clean sources [ o.k. ] Cleaning [ u-boot/d1-wip ] [ o.k. ] Started patching process for [ u-boot d1-nezha-current ] [ o.k. ] Looking for user patches in [ userpatches/u-boot/u-boot-nezha ] HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o YACC scripts/kconfig/zconf.tab.c LEX scripts/kconfig/zconf.lex.c HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf # # configuration written to .config # scripts/kconfig/conf --syncconfig Kconfig UPD include/config.h CFG u-boot.cfg GEN include/autoconf.mk.dep CFG spl/u-boot.cfg GEN include/autoconf.mk GEN spl/include/autoconf.mk ENVC include/generated/env.txt UPD include/generated/timestamp_autogenerated.h ENVP include/generated/env.in HOSTCC scripts/dtc/dtc.o HOSTCC scripts/dtc/flattree.o HOSTCC scripts/dtc/fstree.o HOSTCC scripts/dtc/data.o HOSTCC scripts/dtc/livetree.o HOSTCC scripts/dtc/treesource.o HOSTCC scripts/dtc/srcpos.o PYMOD rebuild HOSTCC scripts/dtc/checks.o HOSTCC scripts/dtc/util.o LEX scripts/dtc/dtc-lexer.lex.c YACC scripts/dtc/dtc-parser.tab.h YACC scripts/dtc/dtc-parser.tab.c ENVT include/generated/environment.h CC lib/asm-offsets.s CC arch/riscv/lib/asm-offsets.s [ error ] ERROR in function compile_uboot [ main.sh:588 -> main.sh:481 -> compilation.sh:238 -> general.sh:0 ] [ error ] U-boot compilation failed [ o.k. ] Process terminated 0 Quote
balbes150 Posted November 1, 2023 Author Posted November 1, 2023 3 часа назад, artiFL сказал: there was a problem when assembling the image for the Lichee RV Nezha board on the Ubuntu system 04.22.3 which GIT (branch) is used? 0 Quote
artiFL Posted November 1, 2023 Posted November 1, 2023 https://github.com/150balbes/build/tree/risc-v 1 Quote
balbes150 Posted November 2, 2023 Author Posted November 2, 2023 This branch is outdated and has not been updated for a long time. What do you want to assemble (what is missing in the latest images 20230930 for this model)? 0 Quote
artiFL Posted November 2, 2023 Posted November 2, 2023 I would like to master embedded linux and learn how to collect images, specifically in version 20230930 I can’t enable uart through the dts file and I decided that it would be more correct to add the image in the assembly, but the image is not assembled without changes. (I apologize for my English, I'm using a translator) 0 Quote
balbes150 Posted November 7, 2023 Author Posted November 7, 2023 02.11.2023 в 08:59, artiFL сказал: I can’t enable uart through the dts file You can build any version of your kernel and use it. https://linux-sunxi.org/Allwinner_Nezha 0 Quote
Gabryx86_64 Posted January 4, 2024 Posted January 4, 2024 The latest current nezha d1 debian version (20230930) refuses to boot (or does not display anything through hdmi) after a system upgrade on the lichee rv dock 0 Quote
le51 Posted February 4, 2024 Posted February 4, 2024 (edited) Hi there, just to clarify; all of you having wlan0 up and running, are you using an USB adapter or the RVdock built in wifi chip I'min the same situation as noticed here: I'm using 23_09_sid_edge_6.6.0, and gotsame problem with current 6.1 -------------EDIT---------------- Got it working finally. For any unknow reason, the arbiam setup script at first boot didn't finished totaly. I have burned a new SD card with 23_09_sid_edge_6.6.0 and everything (at least Wifi) is fine. Thank you @balbes150 great job Edited February 4, 2024 by le51 0 Quote
Nexus Posted May 7, 2024 Posted May 7, 2024 Attempting to build this image gives me the following error: [🐳|🔨] Image 'itb' is missing external blobs and is non-functional: opensbi [🐳|🔨] [🐳|🔨] /binman/itb/fit/images/opensbi/opensbi (fw_dynamic.bin): [🐳|🔨] See the documentation for your board. The OpenSBI git repo is at [🐳|🔨] https://github.com/riscv/opensbi.git [🐳|🔨] You may need to build fw_dynamic.bin first and re-build u-boot with [🐳|🔨] OPENSBI=/path/to/fw_dynamic.bin [🐳|🔨] [🐳|🔨] Some images are invalid [🐳|🔨] make: *** [Makefile:1124: .binman_stamp] Error 103 Any help would be appreciated. 0 Quote
rm_ Posted May 28, 2024 Posted May 28, 2024 (edited) balbes150, There is something wrong with performance. I am trying "Armbian_23.09_Nezha_sid_current_6.1.0_xfce_desktop.img.xz" Doing my simplest performance test: dd if=/dev/zero bs=1M count=256 | md5sum The result is 21 MB/sec. Moving windows in Xfce is really sluggish, even after disabling compositor, leaves trail on screen and lags behind mouse movement. Compared to "licheerv-debian-clean-hdmi.zst" from https://linux-sunxi.org/Sipeed_Lichee_RV#Pre-made_images (last in the list). Using kernel 5.18. The same benchmark returns 51 MB/sec. Moving windows is very responsive. Edited May 28, 2024 by rm_ 0 Quote
rm_ Posted May 28, 2024 Posted May 28, 2024 Tried "Armbian_22.08.0-trunk_Nezha_sid_current_5.19.0_xfce_desktop.img.xz", the result there is much better, 49 MB/sec. But the WiFi onboard of LicheeRV Dock is not detected. 0 Quote
Matej Kovačič Posted September 29, 2024 Posted September 29, 2024 I have LicheeRV Nano (it has RISC-V SG2002 CPU). Is it supported? 0 Quote
