Volker Posted June 13, 2022 Posted June 13, 2022 Hi ! Is there any chance to flash an armbian to the 16MB SPI Flash-Chip? regards, volker.
Solution schwar3kat Posted June 18, 2022 Solution Posted June 18, 2022 On 6/14/2022 at 2:36 AM, Volker said: Hi ! Is there any chance to flash an armbian to the 16MB SPI Flash-Chip? regards, volker. It's only 16MB. Smallest Armbian is about 1GB and it needs more space to operate. SPI flash is big enough for a boot loader, but the OS would have to be on other storage like USB drive.
Volker Posted June 27, 2022 Author Posted June 27, 2022 okay, thx for info! is there any benefit to store the bootloader inside the SPI?
schwar3kat Posted June 28, 2022 Posted June 28, 2022 If you don't want to use an SD card and you are booting from a USB drive, then yes, otherwise not really. I did it on a couple of old boards that boot off a partition on USB 3TB hard drives and serve as backup storage, but SD cards are now so cheap, so it's not really necessary. Disadvantage is that boot loader upgrade is slightly more difficult.
