I'm running Armbian on a Orange pi one.
In htop I found out that the CPU temperature is not correct.
So I tried to figure out what happens. The CPU is define not as hot as the value says.
For me it looks line that the factor is about 2.
I just wanted to inform about it.
I can also deliver more information if required and also support to debug...
I started the following commands for verification.
$ cat /sys/devices/virtual/thermal/thermal_zone0/temp
63809
$ armbianmonitor -m
Running unprivileged. CPU frequency will not be displayed.
Stop monitoring using [ctrl]-[c]
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
13:02:16:   ---      0.00   0%   0%   0%   0%   0%   0% 63,0°C  0/4
13:02:21:   ---      0.00   1%   0%   0%   0%   0%   0% 64,7°C  0/4
$ cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=orangepione
BOARD_NAME="Orange Pi One"
BOARDFAMILY=sun8i
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=03d2395d37
VERSION=22.05.1
LINUXFAMILY=sunxi
ARCH=arm
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=stable
BRANCH=current
$ uname -a
Linux orangepione 5.15.43-sunxi #22.05.1 SMP Sat May 28 08:17:47 UTC 2022 armv7l GNU/Linux
Edited by klaute
Are you perfectly sure that the SoC is not as hot as htop tells?
I have an OPi1 with the same kernel but Buster as userspace and temperature is normal.
Btw. it is Armbian, not Arabian :P
I fixed the typo 😉
I tried to measure the temperature. Both of the two thermometer gave me about 30 degree celsius.
But they are not intendet to measure SoC's.
Maybe I find another way to measure it.
